TGB1718 #1 Posted March 11, 2021 Am I missing something, I'm using cc65 to open screens in various graphics modes but finding it's not happening correctly. The header file says:- extern int __fastcall__ _graphics (unsigned char mode); /* mode value same as in BASIC */ But in reality it looks like modes 0 through 6 work fine, anything else just doesn't seem to work. I wrote a short program to cycle through all modes and put the value of one of the DL bytes in locations $600-$60F It looks like only modes up to and including "B" (BASIC Mode 6) work, anything higher just doesn't. Here's the DL values for each mode. 0600 02 06 07 08 09 0A 0B 0B 0608 0B 0B 0B 0B 0B 0B 0B Quote Share this post Link to post Share on other sites
Wrathchild #2 Posted March 11, 2021 Take a look at this post Quote Share this post Link to post Share on other sites
danwinslow #3 Posted March 11, 2021 (edited) For this particular subject, you can use a command line setting, but I highly recommend looking at the linker config file stuff. CC65 is very config-file dependent. You won't get far unless you learn at least the basics of the linker config stuff. The payback for this is that CC65 is extremely flexible and powerful, providing full control over all aspects of memory placement and linking operations. Edited March 11, 2021 by danwinslow 1 Quote Share this post Link to post Share on other sites
tschak909 #4 Posted March 11, 2021 When doing graphics calls, either via tgi or via the atari OS, you need to ensure that your CC65 program doesn't grab all of the memory for itself by reserving the top part of memory for your graphics. The RESERVED_MEMORY variable in the atari linker configs can do this. -Thom Quote Share this post Link to post Share on other sites
TGB1718 #5 Posted March 11, 2021 3 minutes ago, tschak909 said: RESERVED_MEMORY variable in the atari linker configs can do this. I have tried this but unfortunately it still doesn't work, also changed the start address as the link @Wrathchild gave suggested, again still no joy. I've looked at the config files but can't see anything related to screen memory or anything else that might help cl65 -t atari -O -Wl "-D__RESERVED_MEMORY__=8196" --listing art.lst --static-locals art.c -o art.xex also tried the atarixl config, same result Quote Share this post Link to post Share on other sites
Wrathchild #6 Posted March 11, 2021 (edited) 1 hour ago, TGB1718 said: still no joy Seems OK to me? You'll need to share your test code. #include <atari.h> #include <fcntl.h> #define MYDBG ((unsigned int *) 0x600) #define SDLSTL ((unsigned int *) 0x230) void main(void) { unsigned char i; int fd; for(i=0; i<16; ++i) { fd = _graphics(i); *(MYDBG+i) = *(SDLSTL); close(fd); } while(1); return; } Edited March 11, 2021 by Wrathchild Quote Share this post Link to post Share on other sites
TGB1718 #7 Posted March 11, 2021 I don't think it's working for you, if you look at the DL pointers, only the first 7 change addresses, after that they are all the same $B782, as the DL sits in front of the screen, the higher rezz modes should put the DL lower in memory somewhere around $A27A btw, your code is the same I am using I cut everything else out when it didn't work to try debug it. Thanks for the help. Quote Share this post Link to post Share on other sites
danwinslow #8 Posted March 11, 2021 Rapidly looping through all of the screen modes was never a use case I tried...there may be some subtleness going on with that aspect. Quote Share this post Link to post Share on other sites
Wrathchild #9 Posted March 11, 2021 (edited) I had the wrong picture up originally which corresponded to just calling _graphics but not recording the response and using it to close the IOBC channel Edited March 11, 2021 by Wrathchild Quote Share this post Link to post Share on other sites
TGB1718 #10 Posted March 11, 2021 Just now, danwinslow said: Rapidly looping through all of the screen modes was never a use case I tried...there may be some subtleness going on with that aspect. Only did that to see what modes worked and what didn't, initially I was trying just ANTIC mode 9 and 11 and they didn't work, so tried $F and that failed too. Quote Share this post Link to post Share on other sites
TGB1718 #11 Posted March 11, 2021 I finally got it working, the only thing that seemed weird is the _RESERVED_MEMORY_ didn't look like it was working even though I had reserved 8K, all I did was use Hex notation for the memory reservation cl65 -t atari -O -Wl -D__RESERVED_MEMORY__=0X2000 --listing art.lst --static-locals art.c -o art.xex and now it works !!! all help appreciated, got me thinking 1 Quote Share this post Link to post Share on other sites
Wrathchild #12 Posted March 11, 2021 (edited) Changing the loop code to: for(i=0; i<16; ++i) { fd = _graphics(i); *(MYDBG+i) = *(SDLSTL); *(MYDBG+(16+i)) = fd; // close(fd); } Shows that the _graphics call is returning an error (i.e. no free IOCB) after the 7th open so that probably explains your issue (compiling with the decimal arg on the command line works fine too) [Edit] and the addresses stay the same as it hasn't changed mode Edited March 11, 2021 by Wrathchild Quote Share this post Link to post Share on other sites
danwinslow #13 Posted March 12, 2021 Probably missing the point, but...of course, since you commented out the close? 1 Quote Share this post Link to post Share on other sites
TGB1718 #14 Posted March 12, 2021 Interestingly if I now call _graphics(9), it works ok, _graphics(9+16), works ok, _graphics(9+32) doesn't ??? it doesn't open a graphics screen, it just stays in text screen, strange. Even with the reserved memory which is plenty for this mode. Quote Share this post Link to post Share on other sites
Wrathchild #15 Posted March 12, 2021 Works fine for me ™ (btw there is no 9+16 as modes 9,10 & 11 don't have split screens) The graphics seen being the residual of the dlist for gr.0 from the request not to clear the screen test.zip Quote Share this post Link to post Share on other sites
TGB1718 #16 Posted March 12, 2021 32 minutes ago, Wrathchild said: Works fine for me ™ Can I ask you for your build script please, I think it's all down to that, maybe your using a switch or something I'm not. Thanks Tim Quote Share this post Link to post Share on other sites
Wrathchild #17 Posted March 12, 2021 same command as from post #5 cl65 -t atari -O -Wl "-D__RESERVED_MEMORY__=8196" --listing test.lst --static-locals test.c -o test.xex Quote Share this post Link to post Share on other sites
TGB1718 #18 Posted March 12, 2021 1 hour ago, Wrathchild said: same command as from post #5 Think I'm going to bang my head against a wall Just tried that old build script and it worked both normal open and +32 open.😲 Going for a long lie down, once again thanks for your input. 1 Quote Share this post Link to post Share on other sites
Wrathchild #19 Posted March 12, 2021 13 hours ago, danwinslow said: Probably missing the point, but...of course, since you commented out the close? Yes, was looking to show why the issue in the OP may have occurred Quote Share this post Link to post Share on other sites
CuloMajia #20 Posted March 12, 2021 I am trying to figure out how to do something like a V = USR( routine , parameter 1 , parameter 2, ... ) in cc65. The documentation for cc65 is poor and lacks samples of how to use. Quote Share this post Link to post Share on other sites
Wrathchild #21 Posted March 12, 2021 11 minutes ago, CuloMajia said: I am trying to figure out how to do something like a V = USR( routine , parameter 1 , parameter 2, ... ) in cc65. Start a new thread for this and we can help but more context please, e.g. are you wanting to write routines that you can call from your basic program or replicate what you would do in Basic in C? 13 minutes ago, CuloMajia said: The documentation for cc65 is poor and lacks samples of how to use. Not really, could you say the same of GCC for example? Quote Share this post Link to post Share on other sites
tschak909 #22 Posted March 12, 2021 30 minutes ago, CuloMajia said: I am trying to figure out how to do something like a V = USR( routine , parameter 1 , parameter 2, ... ) in cc65. The documentation for cc65 is poor and lacks samples of how to use. There is no USR, because you... ...just call the function. -Thom Quote Share this post Link to post Share on other sites
CuloMajia #23 Posted March 12, 2021 I will try it. Does the parameters get pushed as 2 byte integer values on the stack like Basic does? I have old Turbo Basic, Atari Basic, Commodore Basic game program around for years that I like to port into something faster and put up on the internet. Some decent quality stuff if I can make stuff run faster. For graphics modes. I find it easier to just create a custom display list with the desired graphics mode. Have the option of placing the text window at the top or bottom also. Quote Share this post Link to post Share on other sites
Wrathchild #24 Posted March 12, 2021 Take a look at some of the Fast Basic topics in this programming forum, they would seem pretty well suited Quote Share this post Link to post Share on other sites
danwinslow #25 Posted March 12, 2021 (edited) Yeah, moving it to FB would be a much better experience for you I think. CC65 and C language port would be a lot more technically intensive. To answer the stack question - the parameters for a function call, generally speaking, are stored on the C memory stack, which is not the same as the system call stack. Small calls like void foo( char a,x,y ) can be made to show up in the registers...using fastcall I think? I forget exactly, but its something like that. Edited March 12, 2021 by danwinslow Quote Share this post Link to post Share on other sites
