pirx #26 Posted March 26 beautiful development, kudos! Quote Share this post Link to post Share on other sites
apc #27 Posted Tuesday at 10:26 PM Config loader update! After exercising with all the helper scripts and tools, here is an image which contains loader & FujiNet CONFIG (and config tools): autorun-zx0.atr As the name indicates the new ZX0 compression is used. With ZX0 the compressed CONFIG is smaller and it loads a bit quicker compared to LZ4 variant. ZX0 decompression routine was embedded into boot loader. Both Config loader and CONFIG are decompressed while being read from disk. As it was before, HISIO is enabled as soon as possible to speedup SIO transfers and CONFIG is loaded with banner and growing progress bar. Build process was automated, "make dist" should do all the hard work. For this purpose I prepared Python script which acts as very simplified SuperPacker (and other script to prepare somehow relocatable code and other script to update final ATR, and ... it was interesting to get all this working together) As a bonus, once the CONFIG is compressed with ZX0 the file segments are "decorated" to make the result Atari DOS compatible/loadable again. However DOS cannot decompress file segments (there are some exceptions ) so decompression routine is bundled and called prior passing the control to CONFIG. I.e. Same CONFIG file can be loaded by ZX0 capable loader (during boot) with inline decompression and it can be loaded as a regular DOS program later from disk. Credits: @xxl for ZX0 decompression port to 6502 and boot loader @HiassofT for high speed SIO @bocianu for FujiNet banner @pirx for compression ideas 🙂 Source code: https://github.com/a8jan/fujinet-config-loader - branch "zx0" (If everything works fine, will be glad to move into FN repos) Jan 2 1 Quote Share this post Link to post Share on other sites
tschak909 #28 Posted Tuesday at 11:01 PM how do I test? -Thom Quote Share this post Link to post Share on other sites
mozzwald #29 Posted Tuesday at 11:14 PM 11 minutes ago, tschak909 said: how do I test? -Thom replaced autorun.atr with the new one above in fujinet-platformio/data/ then upload filesystem soooper fast, me likes 1 Quote Share this post Link to post Share on other sites
apc #30 Posted Tuesday at 11:21 PM (edited) 23 minutes ago, tschak909 said: how do I test? -Thom - mount as D1: and boot - CONFIG should load - mount as D2: with some DOS disk in D1: boot DOS and load CONFIG - CONFIG should load - replace autorun.atr with autorun-zx0.atr (rename to autorun.atr), build firmware image, test with firmware @mozzwald can you test if the loader build process works (git clone ... make dist) on your side? then we can test if build process works on WSL .. would be nice Edited Tuesday at 11:25 PM by apc Quote Share this post Link to post Share on other sites
mozzwald #31 Posted Tuesday at 11:25 PM 3 minutes ago, apc said: - mount as D1: and boot - CONFIG should load - mount as D2: with some DOS disk in D1: boot DOS and load CONFIG - CONFIG should load - replace autorun.atr with autorun-zx0.atr (rename to autorun.atr), build firmware image, test with firmware @mozzwald can you test if the loader build process works (git clone ... make dist) on your side? Building relocatable ZX0 decompressor ../tools/relgen.py zx0unpack-1000-f.obj zx0unpack-1201-f.obj ../tools/pack/a8/zx0unpack.obj Traceback (most recent call last): File "../tools/relgen.py", line 208, in <module> main() File "../tools/relgen.py", line 142, in main with open(fnout, 'wb') as fout: FileNotFoundError: [Errno 2] No such file or directory: '../tools/pack/a8/zx0unpack.obj' Makefile:60: recipe for target '../tools/pack/a8/zx0unpack.obj' failed this is as far as I got Quote Share this post Link to post Share on other sites
apc #32 Posted Tuesday at 11:31 PM 4 minutes ago, mozzwald said: Building relocatable ZX0 decompressor ../tools/relgen.py zx0unpack-1000-f.obj zx0unpack-1201-f.obj ../tools/pack/a8/zx0unpack.obj Traceback (most recent call last): File "../tools/relgen.py", line 208, in <module> main() File "../tools/relgen.py", line 142, in main with open(fnout, 'wb') as fout: FileNotFoundError: [Errno 2] No such file or directory: '../tools/pack/a8/zx0unpack.obj' Makefile:60: recipe for target '../tools/pack/a8/zx0unpack.obj' failed this is as far as I got ok, give me a minute, i guess, git does not store empty directory ... Quote Share this post Link to post Share on other sites
apc #33 Posted Tuesday at 11:34 PM workaround: mkdir tools/pack/a8 going to put some placeholder file there to keep the a8 dir in git Quote Share this post Link to post Share on other sites
mozzwald #34 Posted Tuesday at 11:37 PM 3 minutes ago, apc said: workaround: mkdir tools/pack/a8 going to put some placeholder file there to keep the a8 dir in git indeed, adding the dir makes it work Quote Share this post Link to post Share on other sites
apc #35 Posted Tuesday at 11:39 PM Just now, mozzwald said: indeed, adding the dir makes it work good, should be fixed in repo 1 Quote Share this post Link to post Share on other sites
xxl #36 Posted yesterday at 09:30 AM 11 hours ago, apc said: Config loader update! After exercising with all the helper scripts and tools, here is an image which contains loader & FujiNet CONFIG (and config tools): autorun-zx0.atr 90.02 kB · 2 downloads As the name indicates the new ZX0 compression is used. With ZX0 the compressed CONFIG is smaller and it loads a bit quicker compared to LZ4 variant. ZX0 decompression routine was embedded into boot loader. Both Config loader and CONFIG are decompressed while being read from disk. As it was before, HISIO is enabled as soon as possible to speedup SIO transfers and CONFIG is loaded with banner and growing progress bar. Build process was automated, "make dist" should do all the hard work. For this purpose I prepared Python script which acts as very simplified SuperPacker (and other script to prepare somehow relocatable code and other script to update final ATR, and ... it was interesting to get all this working together) As a bonus, once the CONFIG is compressed with ZX0 the file segments are "decorated" to make the result Atari DOS compatible/loadable again. However DOS cannot decompress file segments (there are some exceptions ) so decompression routine is bundled and called prior passing the control to CONFIG. I.e. Same CONFIG file can be loaded by ZX0 capable loader (during boot) with inline decompression and it can be loaded as a regular DOS program later from disk. Credits: @xxl for ZX0 decompression port to 6502 and boot loader @HiassofT for high speed SIO @bocianu for FujiNet banner @pirx for compression ideas 🙂 Source code: https://github.com/a8jan/fujinet-config-loader - branch "zx0" (If everything works fine, will be glad to move into FN repos) Jan video or didn't happen 1 Quote Share this post Link to post Share on other sites
tschak909 #37 Posted 20 hours ago My RetroTink actually takes a few moments to sync up to my Atari's display, and by that time, the status bar is already gone and status loading. (Of course, I am running HSIO) -Thom Quote Share this post Link to post Share on other sites
tschak909 #38 Posted 20 hours ago Normal 1X Speed: WIN_20210421_10_22_42_Pro.mp4 High Speed: WIN_20210421_10_21_42_Pro.mp4 2 Quote Share this post Link to post Share on other sites
