oddemann Posted March 18, 2021 Share Posted March 18, 2021 K-POWER - Collection, 10 AWESOME, UNUSUAL, SUPER, FANTASTIC COMPUTER PUZZLES AND GAMES! Finally!!! Now you can make the best music for your games and have it recorded! I recon that NOW, there will be unleashed a ton of great music hehehehe (Beginning with the last prog) MUSIC RECORDER The MUSIC RECORDER changes your computer into a computer-tape recorder. By pressing the computer keys pictured under notes on the screen, you make up songs. When you’re ready to record, press the key pictured -next to START RECORDING, enter the notes of the song, then press the key next to PLAY BACK SONG, to hear the tune. When you're tired of hearing a tune, press the key pictured next to ERASE SONG MEMORY to get rid of the song. Up to 100 notes can stored at one time in the recorder. If the number exceeds 100, the note memory is erased and set at one again. Bugs... Yes! But it works! Spoiler 1 REM *** MUSIC RECORDER TI99/4A *** 9 REM *** DIMENSION NOTE ARRAYS *** 10 DIM H(100),Q(26),V(26),R(26),CH(175) 20 GOTO 350 29 REM *** PLAY NOTE ROUTINE *** 30 IF V(T)=0 THEN 180 40 CALL HCHAR(3,T,88) 50 CALL SOUND(100,V(T),0) 60 CALL HCHAR(3,T,33) 69 REM *** RECORD NOTE *** 70 IF F<>1 THEN 80 ELSE 90 80 RETURN 90 IF C>99 THEN 300 100 H(C)=T 110 C=C+1 120 RETURN 130 F=0 140 FOR B=1 TO C-1 150 T=H(B) 160 GOSUB 30 170 NEXT B 180 T=25 189 REM *** READ KEYBOARD *** 190 CALL KEY(3,K,P) 200 IF P=0 THEN 190 210 IF K=Q(T)THEN 220 ELSE 230 220 GOSUB 30 230 T=T-1 240 IF T>6 THEN 200 250 IF K=32 THEN 260 ELSE 270 260 F=1 270 IF K=83 THEN 130 280 IF K=68 THEN 300 290 GOTO 180 299 REM *** ERASE NOTES *** 300 FOR X=0 TO 100 310 H(X)=0 320 NEXT X 330 C=1 340 GOTO 180 349 REM. *** DEFINE CHARACTERS *** 350 A$="FFFFFFFFFFFFFFFF" 360 CALL CLEAR 370 B$="2424FF2424FF2424" 380 C$="00C3241810101010" 390 X=26 400 C=1 410 CALL CHAR(88,A$) 420 CALL CHAR(33,A$) 430 FOR X=8 TO 25 439 REM *** LOAD ARRAYS *** 440 READ V(X),Q(X),CH(X),R(X) 450 CALL CHAR(CH(X),A$) 460 NEXT X 470 CALL CHAR(96,B$) 480 CALL CHAR(42,C$) 490 FOR X=8 TO 16 500 READ F,B 510 CALL COLOR(X,F,B) 520 NEXT X 530 CALL COLOR(1,3,3) 539 REM *** SCREEN DISPLAY *** 540 CALL CLEAR 550 PRINT TAB(6);"C#D#EF#G#A#BC#D#EF" 560 FOR X=1 TO 13 570 PRINT 580 NEXT X 590 PRINT TAB(6);"Q2W3ER5T6Y7UI9O0P1" 600 PRINT 610 PRINT 620 PRINT " PRESS SPACEBAR TO RECORD" 630 PRINT 640 PRINT " PRESS S TO PLAY BACK SONG" 650 PRINT 660 PRINT " PRESS D TO ERASE SONG" 670 FOR X=8 TO 25 680 CALL VCHAR(4,X,CH(X),R(X)) 690 NEXT X 700 GOTO 180 710 DATA 262,81,104,11,277,50,97,9,294,87,112,11 720 DATA 311,51,97,9,330,69,120,11 730 DATA 349,82,128,11,370,53,97,9,392,84,136,11 740 DATA 415,54,97,9,440,89,144,11,466,55,97,9 750 DATA 494,85,152,11,523,73,104,11,554,57,97,9 760 DATA 587,79,112,11,622,48,97,9,659,80,120,11 770 DATA 698,47,128,11 780 DATA 16,16,2,1,5,5,7,7,8,8,11,11,14,14,15,15,10,10 1 Quote Link to comment Share on other sites More sharing options...
