gobo
Dead 600 XL with upgrades
Hi
I bought a good looking 600Xl off of ebay months ago on a whim (never had a 600xl). It came with a 64K upgrade and an S-Video upgrade. I finally got around to trying it and it's dead as a door-nail. The power supply tested at steady 5.1v that works on another 800xl . I also tried a modern USB PS as well that works on the 800xl. The 600xl's LED stays off when powered on, nothing on the screen, no sound.  I've never worked on fixing an Atari on the hardware side and I don't know what I'm doing overall but I did use a multi-meter on all of the chips and they are all getting about 4.2 volts. Should it still be 5v by the time it gets to the chips or is that normal? I re-seated the chips and that did nothing. Not sure if the upgrades have anything to do with it either but it was sold as tested and working. None of the chips get very hot to touch. The motherboard itself looks clean other than the spaghetti. I've attached some pics but not sure that will help. The voltage is even 4.2 at the SIO port and the keyboard cable that supposedly powers the LED. Is that low enough to keep it from even turning on?
Posted (edited)
No offence, but what a mess! ;)
It looks like it has the oldskool stereo mod - I see the stacked Pokey's and the RCA's out. I also see the jumper to the CPU for it.
Not sure why they removed the Basic A chip ( top left ).. B doesn't look custom..
I have seen many bad PIA's lately, but it could be anything. 4050.. any of the main chips..
This is my 64k upgrade :
Edited by Paul Westphal
Posted (edited)
Your power supply is too low, 4 volts is not going to cut it.
Your 6520 has a pin out of it's socket (maybe to support the mod) and you have a missing chip.
There are pictures and schematics strew all about the AA forums showing what chips belong where and what's acceptable
Edited by _The Doctor__
Posted (edited)
the rf out connector and the added rca jack next to it are the right and left stereo out.
un-insulated wire need attention or you may end up with another damaged machine or power supply
a video out is the jack next to the cartridge port.
Posted (edited)
The pia pin is lifted for the stereo mod as is the jumper to the CPU. Just buy a basic A then start from there. Best Electronics has them. I'm looking now. Rf out should still work - it has to :)
Brad at Best Electronics has those, but you will have to be patient with him and set up an account. He has a $20 minimum as well.
Posted (edited)
1 hour ago, _The Doctor__ said:
don't buy a BASIC rev A... Buy a BASIC rev C
Best Electronics is SOLD OUT of the Rev.C BASIC IC, they still have the cartridge version for $20.
The lack of BASIC is not the problem, there's no point in getting BASIC until the machine is otherwise working.
This 600XL has the jumpers/IC socket footprint to choose between ROM/EPROM for BASIC, updating the BASIC socket to 28 pins and changing the 2 jumpers will allow use of a programmed 2764 EPROM instead of the original 24 pin ROM.
Edited by BillC
  • Like 5
Apocalypse Now (Colonel Kurt). "The Horror, the horror".
Worst example of a bodge job ever
Can you say it's and accident waiting to happen that actually did.
LOL Guys, tell me what you REALLY think! 😀😃 And she's such a beauty...on the outside! :)
Maybe I should just rip it all out and go back to stock. Would almost feel bad undoing all that hard work! Weird thing is both power supplies are putting out 5v. The USB one is rated at 3 amps. Even the SIO port says 4.2v. Maybe that capacitor by the power switch? The 4.2v it seems to be system wide. Would it not even turn on without an BASIC chip? The back panel has an S-video and an audio jack. The RF jack is still there. It does look scary in there!!
make sure none of the bodges are touching anything when case is open or closed...
make sure none of the chips are HOT to the touch after it's been on a bit...
make sure no lose piece of metal, wire trimmings, solder flakes or balls have worked their way under or across anything..
make sure nothing is touching a bottom side of the board shield if it still exists.
any HOT chip may be shorted
any bad cap near the power supply could also pull power lower...
You are losing voltage because of an excess draw.
You don't wanna be less than 4.75 anywhere normally...
Well there may be life in it yet. I switched out the keyboard and now the LED comes on. Guess even the keyboard was bad! This thing might turn into Princess Fiona next!  Still nothing on screen, not even a blip when powered on with both S-Video or RF. The multi-meter says 5v at the power port input inside the XL and on the lower lead of the power switch when it's in the off position but when I turn it on the voltage drops to 4.2 on the power switch (lower and middle lead) and everywhere I check on the motherboard that should be 5v. I wonder why someone would go through the trouble of doing all that work in such a nice looking case. I guess I'm shallow because if it was ugly and beat up it would be easier to let it go! ;) Next step is to get rid all of the upgrades.
Thanks Sugarland. I'm going to try both of those ideas. I'm new at troubleshooting electronic circuits and ICs so I appreciate all the help I get!
Why the pick off points on the PBI contacts and the immensely heavy wire?
Every time I watch that movie, I think "I should quote this line more."
I know there is a different system already called the Medusa, but this really is an Atari Medusa...
^This
Brad has been sold out of Basic Rev C for a while now. Marlin at The Brewing Academy sold me one that he'd made himself, along with the converter to make it fit my Basic socket. I can't remember exactly what it cost, but he's always reasonable and it's probably a better choice than trying to find one on ebay. While I agree that you definitely have other issues, you are still going to need a Basic chip later, assuming you're able to revive this machine.
