Harry Potter
AtaSimpleIO/cc65 doesn't work.
Hi!  I am working on a cc65 library called AtaSimpleIO.  It supplies a simplified way of handling keyboard input and text output that decreases overhead by using the ROM routines.  The test program beeps many times, then the emulator (Altirra 2.50) crashes with a program error.  I attached three files that could be causing the error.  Any help would be appreciated.
crt0.s getkey.s test.c
I think that the first thing anyone will say is to use a more up to date version of Altirra. Maybe your hardware setup doesn't allow it...
Posted (edited)
Much more likely that he's crashed Altirra the old fashioned way. But yeah, grab the latest altirra.
HP, that's the standard crt0.s from CC65.  Did you change it?
What's in your simple_io.c file?
Edited by danwinslow
If you provide a complete example incl. how you compile it, I will take a look.
13 hours ago, Harry Potter said:
I changed the crt0.s file but disabled the change.  Sorry about the repeat!  And if you mean the header file, I attached it here.
Yeah, don't mess with the crt0.s file unless you really know what you're doing. Not implying you don't, just saying it's dangerous.
Posted (edited)
You commented out your store of the printc jmp address in crt0.s, so now you have a JMP $0000 in there which is definitely going to be an issue. Looks like you were trying to jmp to the address in $E406 with a 1 added to it (?), which I guess is some kind of E: handler entry point, and the same thing for $E414. You don't have to do it like that, you could set printc up in C as a function pointer and set the address at that time, or just drop into ASM and jmp yourself, look at the options for the asm() function to see how to get symbol addresses/values into your asm statement. Your C program will start directly after crts0.s jsr to your main, so you can put any initialization you like there rather than messing with crt0.s itself.
Let me just say I think (if I understand) what your seem to be trying to do is probably not a great idea...if you are trying to jump around the CIO handlers by directly calling OS routines to save time, then (a) it's likely to cause problems, and (b) not sure you'll save all that much time. If you want REALLY fast screen writes then write your own code to do direct screen memory writes, or better yet wrap the conio.h calls in your functions, those are already pretty fast. Looks like you are moving a library from a commodore version, but Atari, generally speaking, you don't want to skip handlers and directly call OS functions, they were mostly all designed to be called by handlers or by the OS itself.
I thank you for your input.  My SimpleIO libraries are meant to save code by calling the OS directly with minimal extra work.  It's not necessary for most purposes.  I will stop working on it.
+1
I agree that bypassing the CIO handlers is bad idea: it will likely break on machines running upgrades that include alternate OSes.
Posted (edited)
Please don't quit on my opinion - I am often wrong :) If you are trying to save code space rather than execution time, then yeah maybe it's not needed. But if you want to use your simple_io as a basis to work in a familiar environment or convert something that is written to use those calls, then setting them up to call the CIO handlers won't really add much code, and you can probably reduce the code space used by conio.h functions somewhat by setting up your own, specifically optimized, CIO calls.
