Fierodoug5 Posted April 1, 2021 Share Posted April 1, 2021 I am trying to compile and flash a Wrover 8MB Devkit to use in the throughole Fujinet kit and my build is failing for #include "esp_netif.h" so I guess I nee to add a folder with the SSID info like in the old days of the wroom boards? Quote Link to comment Share on other sites More sharing options...
mozzwald Posted April 1, 2021 Share Posted April 1, 2021 2 hours ago, Fierodoug5 said: so I guess I nee to add a folder with the SSID info like in the old days of the wroom boards? Nope 2 hours ago, Fierodoug5 said: build is failing for #include "esp_netif.h" Can you paste the actual error from the build? Quote Link to comment Share on other sites More sharing options...
hideehoo Posted April 1, 2021 Share Posted April 1, 2021 Make sure you are using v3.0 of the Espressif 32 platform. The docs at https://github.com/FujiNetWIFI/fujinet-platformio stating to using v2.0 are out of date. I've been building with v3.0.0, but I see there is also now an update to 3.2.0. Quote Link to comment Share on other sites More sharing options...
Fierodoug5 Posted April 1, 2021 Author Share Posted April 1, 2021 5 hours ago, hideehoo said: Make sure you are using v3.0 of the Espressif 32 platform. The docs at https://github.com/FujiNetWIFI/fujinet-platformio stating to using v2.0 are out of date. I've been building with v3.0.0, but I see there is also now an update to 3.2.0. Ah, didn't see that. Thanx Quote Link to comment Share on other sites More sharing options...
Fierodoug5 Posted April 2, 2021 Author Share Posted April 2, 2021 19 hours ago, hideehoo said: Make sure you are using v3.0 of the Espressif 32 platform. The docs at https://github.com/FujiNetWIFI/fujinet-platformio stating to using v2.0 are out of date. I've been building with v3.0.0, but I see there is also now an update to 3.2.0. Yup, that fixed it, thanx Just waiting on a couple parts and I will be able to test it. Working on a 3D printed case for it 1 Quote Link to comment Share on other sites More sharing options...
hideehoo Posted April 2, 2021 Share Posted April 2, 2021 A case would be sweet. I actually starting playing with FreeCAD a bit this week, but it was a bit challenging coming from Fusion 360 so I moved on to something else If you want a really nice button extender/LED light pipe design, check out what this guy did on his PetSD+ case design. https://www.tinkercad.com/things/iu8w26e5DdN-petsd-case-top-button-rev-13 I printed one out last week and was really impressed with how fix together and worked. 1 Quote Link to comment Share on other sites More sharing options...
