Schmitzi
TI99DIR (TIDIR) Troubleshooting, Questions & Answers
( https://www.ti99-geek.nl/Projects/ti99dir/ti99dir.html#tidir )
Hi, I have a printing issue with TI99DIR, actual version 8.2a: The printouts (PDFs and real printer) are cut at the end of the documents.
Edit: In Windows7-64 ALL pages are empty
Description:
I open a DIS/VAR type file (like README) by doubleclicking it, and get it in the small Editor/Viewer coming with TI99DIR.
When I print it via the menu, (into PDF or on one of my real printers), in any cases some text from the end of the textfile is cut,
or, if the source document  is somwhow longer that 3 or 4 pages maybe, I miss 1 or 2 pages at the end.
I have tried different settings (pageformat A4, Letter, a.s.o) on my different PDF-proggies, and I have 2 printers tested here
This all on Windows 8.1-x64
I also tried most options on my older Win7-64 laptop, THERE I got empty pages, PDF an rela iron printer.
Any idea ?
Here is an actual testfile (I tested with some older, totally different files too) : UPDATE730  (a TIFILE, remove .DSK if given)
Can somebody please try to print that (or just something) with TI99DIR v8.2a (and / or an older version ?) and let me know please.
thanks
EDIT: I installed the older TI99DIR 7.2a on one machine, same issue. Win81 cuts, Win7 empty printouts.
         Maybe it is me and my printers and drivers ?
Another issue or question is, today I tried to rename a file inside a .DSK (from SYSTEM-SYS to SYSTEM/SYS),
but my "/"-key does not work in TI99DIR (Shift-7 for the Slash-sign on german keyboard).
I also tried to copy and past it from another file, but this gave me a strange character.
Is there something that I don´t know ? Are my systems corrupted maybe ?
TIDIR has an issue with the “\” key.  It also does not like the “!” Key as well, at least at the beginning of a filename in a Windows sub directory.
It appears the issue is not inside a DSK image, but only at paths to Windows and PI folders.
Yes, / and \ are valid TI filename characters, therefore no problem inside a DSK. For a future boot EPROM, we should definitely change names (as I suggested, like @SYSTEM; @ should not cause troubles with the PC file systems).
what about the exclamation mark  "!"  ?
It looks good, as the usual dot is given/included  :)   "SYSTEM!SYS"
And it somehow says " Be carful, it´s a system file ! "  ;)
Excl. mark is a special character in Unix shells. Just in case you had a TIFILES file with that name, it would be again somewhat uncomfortable.
<snip>
</snip>
Printing from a Ti99Dir view window stops at the line with PI.STATUS for some reason. TI99DIR is doing nothing with the content of the file, just calling some default print function.
Workarround:
Open the file in a viewer in TI99DIR.
Select all, ctrl-a
Copy, ctrl-c
Open notepad (or other simple editor)
Paste, ctrl-v
and print from there.
Fred ;-)
Workarround:
Select all, ctrl-a
Copy, ctrl-c
Paste, ctrl-v
Fred ;-)
yes, that was my Plan-B :) thanks
I also noticed this problem today Ralph. Offcourse it must be possible to use the /\'";:<>,[email protected]#%^&*()-_=+ characters in TI file names on a DSK ir HD image.
I will change this in Ti99Dir for renaminf files on DSK/HD images.
Another problem wich I encountered with my system is that my disk drive will not step beyond sector 20. I could create a copy on my lotharek drive though and boot MDOS730 with OLDDOS from MDOS650. Sofar it works great. Good job Tim & Beery!!!
First I must make notes of my current configuration and move my IDE device to >1900 and see how to get SYSTEM/SYS on my RAM disk again.
Fred ;-)
Fred ;-)
If you have a TIPI, copy SYSTEM/SYS to the TIPI.  Then, use DM2K in rompage mode, and you can copy to IDE  and Ramdisk as well.
With the proper use of SCSMAP or REMAP depending upon disk i/o or hard drive i/o, you can copy to your ramdisk or ram harddrive.
You will need the LOAD-IDE or LOAD-TIP files in the eprom file and the eprom v0.99 to boot from either of those devices if you go that route.
Keep in mind with the new eprom, SYSTEM/SYS needs to be renamed to SYSTEM-SYS
Fred ;-)
yes I had another problem that sounds a little bit like this, but in the TI99DIR when updating my MDOS650-Work-Disk
It´s my 650.DSK for HFE, with some tools, and I deleted the */SYS-files and some tools no longer needed with MDOS730,
and then I copied all the files from the new MDOS730 ZIP-file. At last, when I copied the SYSTEM/SYS, the .DSK "crashed".
There were strange files, very strange files to see in TI99DIR. This happened every time at the point when I copied the SYSTEM/SYS.
Then I thought, the solution is to take a fresh new empty .DSK, and then copy all files again. DID NOT WORK
Then I took my old .DSK again, copied all new files but not the SYSTEM/SYS to it,
took another, new & empty .DSK and copied ONLY the SYSTEM/SYS to it,
made .HFEs from both .DSKs, and sent them to the SD-card,
fired on and booted the Geneve from the updated DSK (now HFE) but still with MDOS650 on it,
mounted the other HFE as second drive B: in my Lotharek EmuDrive, and just said "COPY B:SYSTEM/SYS A:"
Then I rebootet and it works.
I don´t know what the problem was, first I thought my Work-Disk was mangled or so, but it happened on this one file only,
happened in TI99DIR only, and after the real-iron-copy by hand it still works....
No problem at all, just for you information
ah PS: yesterday? I posted that ready-2-go-DSK in the other tropic where MDOS730 was provided
I had a utility that came with my Lotharek unit that would take a DSK image and convert it to a HFE image.  I'm not aware of any problems copying the file with TIDIR to a DSK image, so in the future, that may be an option to try.
yes, maybe my .DSK was already mangled ? It was the boot & test disk for all my controller-actions in the last weeks....
and yes, Jean-Francois´ HxC Floppy Emultor Soft, actual version is the 2.5.6.6.
( The latest firmware change for the drive v1.881a was made on my request last week, better handling on navigating with the 3 buttons :) )
I also use it to convert the SCP-stream files from my SuperCard Pro.
( By chance, does it also convert files from the KryoFlux ? Still have to check my Kryo, but the SCP runs very good )
Ralph,
Ti99Dir version 81b can be downloaded from my website ti99-geek.nl
If renaming a TI file on a DSK, CF7DSK or HD image then all characters ( inclusive [email protected]#$%^&*()_-=+[]{};:'"\|/?,.<> )  are allowed except the dot and space characters.
  • Thanks 2
