Quiver Posted April 6, 2021 Share Posted April 6, 2021 I can't for the life of me figure out how to declare a string array and initialize it. If I try something like this: DIM strARR$(5) strARR$() = "Hello", "this", "will", "not", "work", "to initalize" This will not work naturally. Alright I'll try a DATA statement: DATA strArr() byte = "How","do","I","access","this?" FOR I=1 TO 10 PRINT strArr(I) NEXT I This will produce numerical output. Having the READ statement from the Atari basic is looking more attractive at this point. So how does one use string arrays in Fast Basic? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 6, 2021 Share Posted April 6, 2021 (edited) In your first statement, you are trying to set 6 different strings into a single string, maybe something like DIM strARR$(5,12) I assume Fast Basic arrays start at 0 so you have 6 strings each 13 bytes long to accommodate the largest string. Same problem with the second method, you need a 2 dimensional array. Not too sure about this initialising method as I don't use FB, but you definitely need 2 dimensional arrays to start with. Edit: I also think you have to "DIM" the array first then initialise it afterwards. e.g. DIM a$(10,10) a$(0)="hello" a$(1)="world" etc... or have DATA statements and read them in in a for/loop. Edited April 6, 2021 by TGB1718 Quote Link to comment Share on other sites More sharing options...
vitoco Posted April 6, 2021 Share Posted April 6, 2021 String variables in FastBasic are always of 255 bytes lenght, which uses 256 bytes in RAM (with a leading byte that stores the current length). String arrays stores a list of addresses where each of the elements is stored. To initialize a strings array, you must assign a value to each element, but you can include the list of strings in a DATA array: DIM A$(10) DATA B() BYTE = "Cero","Uno","Dos","Tres","Cuatro","Cinco","Seis","Siete","Ocho","Nueve","Diez" X = ADR(B) FOR I = 0 TO 10 A$(I) = $(X) X = X + PEEK(X) + 1 NEXT FOR I = 0 TO 10 ? A$(I), ADR(A$(I)) NEXT Quote Link to comment Share on other sites More sharing options...
vitoco Posted April 6, 2021 Share Posted April 6, 2021 15 minutes ago, vitoco said: To initialize a strings array, you must assign a value to each element, but you can include the list of strings in a DATA array: DIM A$(10) DATA B() BYTE = "Cero","Uno","Dos","Tres","Cuatro","Cinco","Seis","Siete","Ocho","Nueve","Diez" X = ADR(B) FOR I = 0 TO 10 A$(I) = $(X) X = X + PEEK(X) + 1 NEXT FOR I = 0 TO 10 ? A$(I), ADR(A$(I)) NEXT If the values of the array would be constant during the program execution, there is a problem with this approach, because the data would use too much memory: the "packed" data in the B() array, and extra 256 bytes per element of every used array element (as it could be seen in the PRINT statement). I could figure out a trick to save those pages of memory from the initialization: DIM AA(-1), A$(10) DATA B() BYTE = "Cero","Uno","Dos","Tres","Cuatro","Cinco","Seis","Siete","Ocho","Nueve","Diez" X = ADR(B) FOR I = 0 TO 10 AA(I) = X X = X + PEEK(X) + 1 NEXT FOR I = 0 TO 10 ? A$(I), ADR(A$(I)) NEXT This trick assigns the same memory location for both the AA() WORD array and A$() string array (which it is a WORD array of pointers). So, assigning a memory location to AA(I) makes A$(I) point to a string that starts at that location (remember that the first byte is actually the string length). In this example, the PRINT shows the original memory location of the initialization data. If you use this method, AVOID assigning new values to the elements of the string array, because those are pointers to data inside the bytecode area (the tokens of the compiled program), without a filler to complete 256 bytes per element, and the program will crash!!! Quote Link to comment Share on other sites More sharing options...
dmsc Posted April 7, 2021 Share Posted April 7, 2021 Hi! 3 hours ago, vitoco said: String variables in FastBasic are always of 255 bytes lenght, which uses 256 bytes in RAM (with a leading byte that stores the current length). String arrays stores a list of addresses where each of the elements is stored. To initialize a strings array, you must assign a value to each element, but you can include the list of strings in a DATA array: 3 hours ago, vitoco said: DIM A$(10) DATA B() BYTE = "Cero","Uno","Dos","Tres","Cuatro","Cinco","Seis","Siete","Ocho","Nueve","Diez" X = ADR(B) FOR I = 0 TO 10 A$(I) = $(X) X = X + PEEK(X) + 1 NEXT FOR I = 0 TO 10 ? A$(I), ADR(A$(I)) NEXT I prefer this, it is more "idiomatic", as it does not uses PEEK: DIM A$(10) DATA B() BYTE = "Cero","Uno","Dos","Tres","Cuatro","Cinco","Seis","Siete","Ocho","Nueve","Diez" X = ADR(B) FOR I = 0 TO 10 A$(I) = $(X) X = X + LEN($(X)) + 1 NEXT FOR I = 0 TO 10 ? A$(I), ADR(A$(I)) NEXT As Vitoco said, in the above example, FastBasic allocates 256 bytes for each string assignment (the "A$(I) = ...." in the loop), and copies the "constant" string from the DATA array to the new allocated string. If your strings are always constants, and you don't want to use much memory, you can instead store the pointers (address) to the strings in a new array: DIM A(10) DATA B() BYTE = "Cero","Uno","Dos","Tres","Cuatro","Cinco","Seis","Siete","Ocho","Nueve","Diez" X = &B FOR I = 0 TO 10 A(I) = X X = X + LEN( $(X) ) + 1 NEXT FOR I = 0 TO 10 ? $( A(I) ) NEXT Quote Link to comment Share on other sites More sharing options...
Quiver Posted April 7, 2021 Author Share Posted April 7, 2021 Thanks. This really clears things up. The manual seemed as clear as mud in regards to using string arrays, at least to me. Been working through "Your Atari Computer" translating the example programs to Fast Basic. I figure I'll really know the language if I can "port" every example. Strings though are done differently enough in Fast Basic compared to Atari Basic that it was getting frustrating. Again thanks. Quote Link to comment Share on other sites More sharing options...
dmsc Posted April 7, 2021 Share Posted April 7, 2021 Hi! 7 hours ago, Quiver said: Thanks. This really clears things up. The manual seemed as clear as mud in regards to using string arrays, at least to me. Yes, the manual is not very deep in arrays and strings. Perhaps you can suggest some edits to make it better? I would appreciate it. 7 hours ago, Quiver said: Been working through "Your Atari Computer" translating the example programs to Fast Basic. I figure I'll really know the language if I can "port" every example. Strings though are done differently enough in Fast Basic compared to Atari Basic that it was getting frustrating. I decided to implement strings differently to make it easier to use strings in simple programs - without the need for DIM using strings is more natural, IMHO. The main problem is that FastBasic string support is really simple, so it does not do garbage-collection like in other BASIC with automatic strings, so I opted for statically allocated strings - basically, whenever you perform a string assignment the code generated is: ' Code for A$="hello" IF NOT ADR(A$) THEN DIM A$(256) MOVE ADR("hello"), ADR(A$), LEN("hello") + 1 The advantage of statically allocates strings are: - you can edit the contents and concatenate it in the same buffer (for example, you can do A$ += "world" to append a word) - you don't loose memory on each assignment - the address is fixed, so you can store machine code or binary data inside. The obvious disadvantages are: - the string always use 256 bytes, even for short strings. - you can't store "constant" strings in a string variable, as they can't be overwriten. Have Fun! Quote Link to comment Share on other sites More sharing options...
