+Gemintronic Posted April 8, 2021 Share Posted April 8, 2021 Hey there fellas! I think I found an undocumented "feature" of CTRLPF $03 in the Multi Sprite Kernel. Basically, any value of p (where CTRLPF is $bp) at 3 or above also causes sprites to move behind the playfield. https://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#ctrlpf I was trying to use the dual playfield colors to hide either the left or right copy of the playfield. The theory being sprites can show on one side and an effectively asymmetrical playfield display on the other. Problem is: when the sprites are behind the playfield the hidden playfield pixels block out the sprites. Is there any way to revert the sprites back to being in the foreground AND retain the dual colors feature of CTRLPF $03 Or, any assembly hack to just disable playfield drawing for one of the screen sides? Thank you in advance for any clues! playsprite001.bas playsprite001.bas.asm playsprite001.bas.bin 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 8, 2021 Share Posted April 8, 2021 "Split color playfield" is really SCORE MODE. When turned on: left half of playfield takes on the color player 0 right half of playfield takes on the color player 1 It's for displaying scores via the playfield where each player's score matches their color. Besides taking on the color, the two sides of the playfield take on the priority of the respective players in score mode. Player 0 always has priority over player 1, so the left playfield will have priority over player 1 when using score mode. 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted April 8, 2021 Author Share Posted April 8, 2021 9 minutes ago, SpiceWare said: "Split color playfield" is really SCORE MODE. Thank you for the explanation! So, the work around would have to be either: * Rewrite the multi sprite kernel to stop drawing the playfield when it reaches the center or * Rewrite the multi sprite kernel to use player0 for virtual sprites instead of player1 Is that it? 1 Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted April 8, 2021 Share Posted April 8, 2021 4 minutes ago, Gemintronic said: Thank you for the explanation! So, the work around would have to be either: * Rewrite the multi sprite kernel to stop drawing the playfield when it reaches the center or * Rewrite the multi sprite kernel to use player0 for virtual sprites instead of player1 Is that it? Or you switch the design of the game and us the left side for displaying the playfield and the right side for the virtual sprites? 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted April 8, 2021 Author Share Posted April 8, 2021 4 minutes ago, Al_Nafuur said: Or you switch the design of the game and us the left side for displaying the playfield and the right side for the virtual sprites? With batari BASIC using player1 for the virtual sprites that means those virtual sprites become background color (and therefore invisible). Plus, player0 would have to be the main foreground color making the whole game unicolor. Quite a catch 22 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 8, 2021 Share Posted April 8, 2021 15 minutes ago, Gemintronic said: * Rewrite the multi sprite kernel to use player0 for virtual sprites instead of player1 that would be easier than zeroing out half the playfield. 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted April 9, 2021 Author Share Posted April 9, 2021 Working with instead of against score mode I came up with this mock up I compiled and ran in Stella. Not terrible! 1 Quote Link to comment Share on other sites More sharing options...
