acadiel
15kHz VGA Monitor
Got this from Amazon, and it does support 15kHz on my Amiga 1200.  Which leads me to wondering if we can get a VGA -> socket made for the Geneve/Mechatronic/EVPC/EVPC2/AVPC and try it on these systems, or least crowdsource the cable pinout and stick them here in this thread.  (Sidebar:  I went looking for the SNUG website to see if they had pinouts, but my bookmark must be old - I can't find it.  Anyone have the current link?)
At $139, it's a pretty good deal.  The only negative thing is I can't seem to consistently force 4:3 mode.  Has a gorgeous screen!
https://www.amazon.com/gp/product/B01GV9H1RS/
The Mechatronic and EVPC look somewhat alike.  Anyone want to check me on these and fill in the missing ones?
Mechatronic (DE9):
Pin 1 = Ground to Composite Input "Ground" / Sync input "Ground"
Pin 2 - not used
Pin 3 = Red
Pin 4 = Green
Pin 5 = Blue
Pin 6 - not used
Pin 7 = +5V
Pin 8 = Sync
Pin 9 = not used
Geneve (8 pin DIN):
Pin 1 = +12V for RF Modulator
Pin 2 = Ground
Pin 3 = Audio
Pin 4 = Composite Video
Pin 5 = Ground for RF Mod, else Red
Pin 6 = Green
Pin 7 = Blue
Pin 8 = Composite Sync
EVPC (DE9):
Pin 1 = N/C
Pin 2 = GND
Pin 3 = Red
Pin 4 = Green
Pin 5 = Blue
Pin 6 = Sound
Pin 7 = 5V
Pin 8 = Csync
Pin 9 = N/C
VGA Pinout:
Pin Name Dir Description
1 RED --> Red Video (75 ohm, 0.7 V p-p)
2 GREEN --> Green Video (75 ohm, 0.7 V p-p)
3 BLUE --> Blue Video (75 ohm, 0.7 V p-p)
4 N/C
5 GND --- Ground
6 RGND --- Red Ground
7 GGND --- Green Ground
8 BGND --- Blue Ground
9 KEY - Key (No pin)
10 SGND --- Sync Ground
11 N/C
12 N/C
13 HSYNC or CSYNC --> Horizontal Sync (or Composite Sync)
14 VSYNC --> Vertical Sync
15 N/C
  • Like 4
Hi acadiel,
 very interesting monitor. Do you connect it to the Amiga using a scandoubler or with the simple Amiga-to-VGA adapter?
May I ask you more information about the connection to the Amiga? If it is considered off-topic may I contact you privately?
I've purchased a couple of these for use as 15khz monitors, and they also work fairly well (one on my Amiga, one on my Atari ST, both with just passive adapters). (Note I bought from Canada, so check the model number: VE228H)
https://www.amazon.com/ASUS-VE228H-1920x1080-Back-lit-Monitor/dp/B00413PHDM
I've used this list a couple of times to go shopping now :)
http://15khz.wikidot.com/
I keep this 15khz link on my phone for whenever I’m thrifting. Easily found two NEC MultiSync 19” 4*3 LCD monitors — 1970gx and 1970nx. Both work great with classic Macs, Atari ST, etc. No add on or converters needed.
With this the list I was able find them in a few months during weekly stops at the local Goodwill.  Cost: $9.99 each.
Very impressed with the quality of NEC MultiSync monitors. Especially considering they’re both over 15 years old.
  • Like 4
Me too. I once checked every monitor in the Goodwill computer annex (I think all computers from Austin donations go to that one place.) No finds though.
i've ordered some 15khz VGA test boards. (PCBs only).  Powered by a lithium battery to take around and be able to test monochrome and color to see if a thrift store find monitor supports 15khz.
I've ordered 5 of each.  So I will have 4 available of each Monochrome and 4 each for the color board.  $2.00 each + shipping (blank pcb only).  PM me if interested.  I only needed one of each.
Read about it as well as the code files HERE
This may need to be moved to a new thread. I replaced the 9938 and a leaking capacitor on a EVPC, then I wired up a 9 pin to scart cable based on the info on post #1.
I am finally getting something, a white screen with faint greyish stripes in the first picture, after I turn on the PEB box, then in the second picture after I turn on the console the strips get thicker and have a greyish, blue- like cyan color. Is this a sync issue or do I need to do some more work on my interface. I took a Scart plug, set up for composite on 8 pin din and rewired it to do rgb on a DE9 that fits the EVPC port.
