str0m Posted April 15, 2021 Share Posted April 15, 2021 Hi Saint, Had the below but seems OK now but thought I would let you know. Put the new firmware on my SD card this is for the original Jag SD, turned it on, it updated. Then before navigating and folders or trying to load anything I hit 0 to show the version (attached). Hitting B to ok/exit made it do a memory test then back to version info. Hit B again, another test. No way to get back to dir list. Turned it off and on and now B exits the version info fine, tried it a few times and more power cycles. Not even sure how you instigate the test! So all seems OK now, was just on the first boot after firmware update Thanks. CD testing now 1 Quote Link to comment Share on other sites More sharing options...
SainT Posted April 15, 2021 Share Posted April 15, 2021 That’s really weird. If you press 7+9 at the same time it does a memory check. It might be something odd to do with the multi-controller input I’ve added for the launcher. You can now use either pad 1 or 2 to navigate the menu, perhaps something weird going on with the 2nd pad read in some circumstances. Quote Link to comment Share on other sites More sharing options...
str0m Posted April 15, 2021 Author Share Posted April 15, 2021 Ah yes 7+9. I do have a USB mouse adapter in port 2 but it's not happened again, just that first time after the couple of update reboots 1 Quote Link to comment Share on other sites More sharing options...
