tane Posted April 24, 2021 Share Posted April 24, 2021 14 minutes ago, pps said: Zip contains all atari.hea ? Quote Link to comment Share on other sites More sharing options...
+skr Posted April 24, 2021 Share Posted April 24, 2021 13 hours ago, tschak909 said: The graphic itself is a standard Micropainter image, that is, 160x192, 2 bits per pixel. The last four bytes of the palette data aren't used, and all the colors, save COLUBK are set to $0E. If someone has a better pic, then fold it in. -Thom The rainbow looked kind of wrong to me, so I´ve changed your code a bit. In the main loop you now can set the rainbow to appear on on the Logo, the Text or the Background. Or all at once. Just didn´t change the picture. ;; Atari Logo with rainbow Fuji ;; Author: Thom Cherryhomes <thom.cherryhomes@gmail.com> ;; Edited by skr <sascha@abbuc.de> C0 = $D01A DL = $F4 DH = $Ff5 SDLSTL = $0230 SDLSTH = $0231 VCOUNT = $D40A ORG $2200 START LDA SDLSTL STA DL LDA SDLSTH STA DH ;; SET COLOR REGISTERS LDA #$0E ;Color STA $02C4 ;Set Color for Logo STA $02C5 ;Set Color for Text ;; SET DISPLAY LIST LDA #$00 STA SDLSTL LDA #$29 STA SDLSTH LOOP lda $d40b ;Load VCOUNT clc adc 20 ;Add counter sta VCOUNT ;sta $d01a ;Rainbow on Background sta $d016 ;Rainbow on Logo sta $d017 ;Rainbow on Text jmp loop ORG $2900 DLST .BYTE $70,$70,$70 .BYTE $4E,$50,$31 .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E .BYTE $4E,$00,$40 .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $41,$00,$29 ORG $3150 ;Load image to this address INS "atari.mic" RUN START 1 Quote Link to comment Share on other sites More sharing options...
pps Posted April 24, 2021 Share Posted April 24, 2021 16 minutes ago, tane said: atari.hea ? It's just the definition of all the system variables. You can use the .h file of any g2f picture (created when saved as asm). 1 Quote Link to comment Share on other sites More sharing options...
tane Posted April 24, 2021 Share Posted April 24, 2021 ? atari.hea Quote Link to comment Share on other sites More sharing options...
pps Posted April 24, 2021 Share Posted April 24, 2021 btw, if you want to scroll the rainbow up, a simple change from dey to iny in DLI has to be done: .proc dli sta rega stx regx sty regy mva >fnt chbase sta wsync ldy $14 ldx #85 lp sty color1 sty color2 sty color0 sta wsync iny ;this was dey for rainbow down dex bpl lp mva #0 color2 mva #$e color1 sta wsync ldy regy ldx regx lda rega rti .endp rainbow_fuji2.mp4 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 24, 2021 Share Posted April 24, 2021 (edited) 37 minutes ago, pps said: btw, if you want to scroll the rainbow up, a simple change from dey to iny in DLI has to be done: .proc dli sta rega stx regx sty regy mva >fnt chbase sta wsync ldy $14 ldx #85 lp sty color1 sty color2 sty color0 sta wsync iny ;this was dey for rainbow down dex bpl lp mva #0 color2 mva #$e color1 sta wsync ldy regy ldx regx lda rega rti .endp rainbow_fuji2.mp4 1.17 MB · 0 downloads suggestion- add velocity and have it reverse, going one way and then the other ! Edited April 24, 2021 by _The Doctor__ 2 Quote Link to comment Share on other sites More sharing options...
+skr Posted April 24, 2021 Share Posted April 24, 2021 Changing direction in Thom´s code works with using SBC instead of ADC. You can also have both directions at once. I´ve just made Subroutines "SD" (Scroll Down) and "SU" (Scroll Up). Looks like this: ;; Atari Logo with rainbow Fuji ;; Author: Thom Cherryhomes <thom.cherryhomes@gmail.com> ;; Edited by skr <sascha@abbuc.de> C0 = $D01A DL = $F4 DH = $Ff5 SDLSTL = $0230 SDLSTH = $0231 VCOUNT = $D40A ORG $2200 START LDA SDLSTL STA DL LDA SDLSTH STA DH ;; SET COLOR REGISTERS LDA #$0E ;Color STA $02C4 ;Set Color for Logo STA $02C5 ;Set Color for Text ;; SET DISPLAY LIST LDA #$00 STA SDLSTL LDA #$29 STA SDLSTH LOOP JSR SD sta $d01a ;Rainbow on Background JSR SU sta $d016 ;Rainbow on Logo sta $d017 ;Rainbow on Text jmp loop SD lda $d40b ;Load VCOUNT clc adc 20 ;Add counter sbc scrolls down, adc scrolls up sta VCOUNT RTS SU lda $d40b ;Load VCOUNT clc sbc 20 ;Add counter sbc scrolls down, adc scrolls up sta VCOUNT RTS ORG $2900 DLST .BYTE $70,$70,$70 .BYTE $4E,$50,$31 .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E .BYTE $4E,$00,$40 .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $0E,$0E,$0E,$0E,$0E,$0E,$0E .BYTE $41,$00,$29 ORG $3150 ;Load image to this address INS "atari.mic" RUN START updown.mp4 downup.mp4 allscroll.mp4 1 Quote Link to comment Share on other sites More sharing options...
pps Posted April 24, 2021 Share Posted April 24, 2021 1 hour ago, _The Doctor__ said: suggestion- add velocity and have it reverse, going one way and then the other ! not exactly velocity, but... rainbow_fuji2_up_down.mp4 new DLI code for that: .proc dli sta rega stx regx sty regy mva >fnt chbase sta wsync lda $13 cmp store bne chg furth ldy $14 ldx #85 lp sty color1 sty color2 sty color0 sta wsync what iny dex bpl lp mva #0 color2 mva #$e color1 sta wsync ldy regy ldx regx lda rega rti ;------- chg lda what cmp #$88 ;dey? bne c_dey ;c_iny lda #$c8 ;iny sta what mva $13 store jmp furth c_dey lda #$88 ;dey sta what mva $13 store jmp furth .endp store is additional .zpvar .byte rainbow_fuji_up_down.xex 1 1 Quote Link to comment Share on other sites More sharing options...
+skr Posted April 24, 2021 Share Posted April 24, 2021 Just using different colors affects the direction of the rainbow. skr.m4v skrabbuc.mp4 Quote Link to comment Share on other sites More sharing options...
+skr Posted April 24, 2021 Share Posted April 24, 2021 atariRainbow.mp4 1 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted April 24, 2021 Share Posted April 24, 2021 I also made my version, since all the ones published here I find with details in the length, shape and font. I also publish the source code in MADS. Fuji.xex 2 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted April 24, 2021 Share Posted April 24, 2021 26 minutes ago, ascrnet said: I also made my version, since all the ones published here I find with details in the length, shape and font. I also publish the source code in MADS. Fuji.xex 888 B · 1 download Nice logo shape. Perhaps scrolling is too fast (worst in NTSC machines). Quote Link to comment Share on other sites More sharing options...
+skr Posted April 24, 2021 Share Posted April 24, 2021 Thank you all guys, I´ve learned so much (I´m a total noob, srsly). I very much like @ascrnet´s way using text mode. Have to check out later, how to have two different scroll directions in one line with that. The last thing I didn´t understand was the "compressed" graphics, but changing the DL to Antic Mode D did the trick, as it uses 2 scanlines. So this is my last video: modeD.mp4 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 24, 2021 Author Share Posted April 24, 2021 See, this is what makes me smile, people jumping in and hacking on stuff. -Thom 1 Quote Link to comment Share on other sites More sharing options...
+skr Posted April 24, 2021 Share Posted April 24, 2021 12 minutes ago, tschak909 said: See, this is what makes me smile, people jumping in and hacking on stuff. -Thom You make me feel like 12 years old again. Wanted to do exactly this stuff then, but no other Atarians around, no literature, no internet etc. Little Sascha will go to bed with a big smile in his face. 4 1 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted April 25, 2021 Share Posted April 25, 2021 6 hours ago, Philsan said: Nice logo shape. Perhaps scrolling is too fast (worst in NTSC machines). it's direct so it's super fast ? thanks to all who have shared their source code, you learn a lot. i share my second improved version with the rainbow in DLI with VBI. is there a way to disable the VBI before exiting the program? ? Fuji.xex 1 Quote Link to comment Share on other sites More sharing options...
pps Posted April 25, 2021 Share Posted April 25, 2021 13 minutes ago, ascrnet said: it's direct so it's super fast ? thanks to all who have shared their source code, you learn a lot. i share my second improved version with the rainbow in DLI with VBI. is there a way to disable the VBI before exiting the program? ? Fuji.xex 974 B · 0 downloads Simply include another VBI, that just jumps to xitvbv and set it as VBI before exit or better save original VBI and DL and reset them before exit. 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 25, 2021 Author Share Posted April 25, 2021 (edited) 17 minutes ago, ascrnet said: it's direct so it's super fast ? thanks to all who have shared their source code, you learn a lot. i share my second improved version with the rainbow in DLI with VBI. is there a way to disable the VBI before exiting the program? ? Fuji.xex 974 B · 1 download save original VBI and DL and reset before exit. Edited April 25, 2021 by tschak909 Quote Link to comment Share on other sites More sharing options...
tane Posted April 25, 2021 Share Posted April 25, 2021 38 minutes ago, ascrnet said: improved version + exit also with Start & Trigger. Quote Link to comment Share on other sites More sharing options...
pps Posted April 25, 2021 Share Posted April 25, 2021 (edited) Ok, last one by me... ATARI would have added the registration mark back in the days, so I added it. Rainbow is taller here and you can exit to a warm reset. rainbow_fuji_r_up_down.mp4 rainbow_fuji_r_up_down.xex Source code for all will be added to my github place in a few minutes. Link is in my signature. Edited April 25, 2021 by pps edit: correted wrong .xex 5 2 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted April 25, 2021 Share Posted April 25, 2021 16 hours ago, pps said: Simply include another VBI, that just jumps to xitvbv and set it as VBI before exit or better save original VBI and DL and reset them before exit. thanks for the information ? 16 hours ago, tschak909 said: save original VBI and DL and reset before exit. thanks for the information ? 16 hours ago, tane said: + exit also with Start & Trigger. ok now I share my third version ? Fuji.xex Leaving the rainbow in DLI and VBI leaves it compatible for PAL and NTSC I learned.? I also improved the blackout effect of the ATARI word and last but not least, thanks to all of you who made your own versions, we learn a lot from you. 4 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted April 25, 2021 Share Posted April 25, 2021 2 hours ago, ascrnet said: ok now I share my third version I like that one very much! Looks great on both my PAL and NTSC machines. 1 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted April 27, 2021 Share Posted April 27, 2021 On 4/25/2021 at 6:34 PM, DrVenkman said: I like that one very much! Looks great on both my PAL and NTSC machines. Thanks for the feedback ? Now my fourth version with the rainbow down and up. next challenge to put some music....? Fuji.xex 1 Quote Link to comment Share on other sites More sharing options...
tane Posted July 28, 2021 Share Posted July 28, 2021 On 4/24/2021 at 11:12 PM, ascrnet said: is there a way to disable the VBI before exiting the program? ? On 4/26/2021 at 9:27 PM, ascrnet said: Now my fourth version with the rainbow down and up. This version (latest checked in Github) is not working with some programs. For example when adding an image (G2F) thereafter, it will not work all times, the image doesn't start. Is there a way to restore the system to its default before exit the program? What to add here?: exit jmp WARMSV If in the G2F code is commented this line, it helps, but I'd like to have a full compatible Fuji Rainbow Logo program instead of to make hacks to other programs. ; lda:cmp:req $14 ;wait 1 frame It breaks out of the loop at $2C05: 2C03: A5 14 LDA RTCLOK+2 2C05: C5 14 L2C05 CMP RTCLOK+2 2C07: F0 FC BEQ $2C05 2C09: 78 SEI Note: not tested specifically with this small G2F code. Pasted here in order to know what commands are used with G2F. /***************************************/ /* Use MADS http://mads.atari8.info/ */ /* Mode: DLI (char mode) */ /***************************************/ icl "test.h" org $f0 fcnt .ds 2 fadr .ds 2 fhlp .ds 2 cloc .ds 1 regA .ds 1 regX .ds 1 regY .ds 1 WIDTH = 40 HEIGHT = 30 ; --- BASIC switch OFF ; org $2000\ mva #$ff portb\ rts\ ini $2000 ; --- MAIN PROGRAM org $2000 ant dta $44,a(scr) dta $04,$04,$04,$04,$04,$04,$04,$04,$04,$04,$04,$04,$04,$04,$04,$04 dta $04,$04,$04,$04,$04,$04,$04,$04,$04,$04,$04,$04,$04 dta $41,a(ant) scr ins "test.scr" .ds 0*40 .ALIGN $0400 fnt ins "test.fnt" ift USESPRITES .ALIGN $0800 pmg .ds $0300 ift FADECHR = 0 SPRITES els .ds $500 eif eif main ; --- init PMG ift USESPRITES mva >pmg pmbase ;missiles and players data address mva #$03 pmcntl ;enable players and missiles eif lda:cmp:req $14 ;wait 1 frame sei ;stop IRQ interrupts mva #$00 nmien ;stop NMI interrupts sta dmactl mva #$fe portb ;switch off ROM to get 16k more ram mwa #NMI $fffa ;new NMI handler mva #$c0 nmien ;switch on NMI+DLI again ift CHANGES ;if label CHANGES defined _lp lda trig0 ; FIRE #0 beq stop lda trig1 ; FIRE #1 beq stop lda consol ; START and #1 beq stop lda skctl and #$04 bne _lp ;wait to press any key; here you can put any own routine els null jmp DLI.dli1 ;CPU is busy here, so no more routines allowed eif stop mva #$00 pmcntl ;PMG disabled tax sta:rne hposp0,x+ mva #$ff portb ;ROM switch on mva #$40 nmien ;only NMI interrupts, DLI disabled cli ;IRQ enabled rts ;return to ... DOS ; --- DLI PROGRAM .local DLI ?old_dli = * ift !CHANGES dli1 lda trig0 ; FIRE #0 beq stop lda trig1 ; FIRE #1 beq stop lda consol ; START and #1 beq stop lda skctl and #$04 beq stop lda vcount cmp #$02 bne dli1 :3 sta wsync jmp NMI.quit eif dli_start .endl ; --- CHANGES = 1 FADECHR = 0 SCHR = 127 ; --- .proc NMI bit nmist bpl VBL jmp DLI.dli_start dliv equ *-2 VBL sta regA stx regX sty regY sta nmist ;reset NMI flag mwa #ant dlptr ;ANTIC address program mva #@dmactl(standard|dma|lineX1|players|missiles) dmactl ;set new screen width inc cloc ;little timer ; Initial values lda >fnt+$400*$00 sta chbase c0 lda #$00 sta colbak c1 lda #$04 sta color0 c2 lda #$06 sta color1 c3 lda #$08 sta color2 c4 lda #$0E sta color3 lda #$02 sta chrctl lda #$04 sta gtictl x0 lda #$00 sta hposp0 sta hposp1 sta hposp2 sta hposp3 sta hposm0 sta hposm1 sta hposm2 sta hposm3 sta sizep0 sta sizep1 sta sizep2 sta sizep3 sta sizem sta colpm0 sta colpm1 sta colpm2 sta colpm3 mwa #DLI.dli_start dliv ;set the first address of DLI interrupt ;this area is for yours routines quit lda regA ldx regX ldy regY rti .endp ; --- run main ; --- opt l- .MACRO SPRITES missiles .ds $100 player0 .ds $100 player1 .ds $100 player2 .ds $100 player3 .ds $100 .ENDM USESPRITES = 0 .MACRO DLINEW mva <:1 NMI.dliv ift [>?old_dli]<>[>:1] mva >:1 NMI.dliv+1 eif ift :2 lda regA eif ift :3 ldx regX eif ift :4 ldy regY eif rti .def ?old_dli = * .ENDM example G2F.zip Quote Link to comment Share on other sites More sharing options...
Jetboot Jack Posted July 29, 2021 Share Posted July 29, 2021 (edited) On 4/24/2021 at 1:27 AM, ascrnet said: First of all thanks for sharing the code on github ?, but it is strange your version of fuji. There is a game that has a very good one of course it doesn't use the whole screen. Regards This the one Atari UK provided to developers - used on several of the final games produced for the 8bit line... It was the same data as the Xanth F/X Swan demo - https://demozoo.org/productions/98552/ sTeVE Edited July 29, 2021 by Jetboot Jack 4 1 Quote Link to comment Share on other sites More sharing options...
