Dopeyman06 #1 Posted Saturday at 07:24 AM Isn't SpartaDOS Pro 3.3a Y2K compliant? The date is supposed to be Saturday 05/22/2021. Quote Share this post Link to post Share on other sites
+Nezgar #2 Posted Saturday at 07:58 AM You can try RealDOS & TDLINE2 (which is basically a newer version of SD 3.3), or the TDLINE from CTHTDL.... which I can't find at the moment.... Try TDLINE.LZH from http://www.mixinc.net/atari/download_a8/sdcom.htm If you are running with U1MB or SIDE2, you can try this driver for the DS1305, which also calculates the day of week: Quote Share this post Link to post Share on other sites
flashjazzcat #3 Posted Saturday at 08:36 AM The driver does not use the weekday stored on the DS1305. You'll still need a patched TD line as well. Quote Share this post Link to post Share on other sites
Dopeyman06 #4 Posted Saturday at 09:17 AM Apparently I was using the incorrect TDLINE.COM. I now have the correct one. Also, this is through emulation (Atari800MacX 6.0.0). Thank you guys for the input. Quote Share this post Link to post Share on other sites
+Nezgar #5 Posted Saturday at 09:31 AM 12 minutes ago, Dopeyman06 said: I now have the correct one. Just for reference, which source yielded the "CTH Y2K" version? Quote Share this post Link to post Share on other sites
Dopeyman06 #6 Posted Saturday at 10:24 AM 52 minutes ago, Nezgar said: Just for reference, which source yielded the "CTH Y2K" version? I looked through a couple disk images that I had and I found it Quote Share this post Link to post Share on other sites
a8isa1 #7 Posted yesterday at 03:00 PM SJCarden dropped me a note last night in chat (currently at ##atari channel on Freenode but the users are are likely moving 100% to Libera Chat). SJCarden probably intended the message to be in response to this thread. He said, "Please pas it along that TDline2 will work with sd2.2c,d,m sd3.3a,b,c,d all versions of RealDOS" I'm pretty sure TDLINE2 has a fixed DOW function. I don't use it myself because my DS1307/DS3231 non-driver conflicts with TDLINE2 and I can't code my way out of a paper bag. -SteveS Quote Share this post Link to post Share on other sites
flashjazzcat #8 Posted yesterday at 03:23 PM (edited) 1 hour ago, a8isa1 said: I'm pretty sure TDLINE2 has a fixed DOW function. Is that the one that's 7.5K in size? EDIT: Well, after using exceptional Google-fu to find a copy (6.7K in size) and after it spammed the screen upon installation, it appears to work. TDLINE2 raises MEMLO by about 750 bytes. I think a lightweight y2k-compliant TDLINE could be useful here, to complement the ULTD.SYS driver. Edited yesterday at 04:06 PM by flashjazzcat 2 Quote Share this post Link to post Share on other sites
itzmike #9 Posted 23 hours ago Back in the good 'ol days of 19, I posted a fix I'd done to SpartadosX 4.22 to solve the same problem (back in the year 01). Re-posting my fix even though there are MUCH better patches out there. I know the newer TDLINE 's from the Sparta update project do work much better. That being said, about 20 years ago I patched my TDLINE.com on SDX 4.22 and renamed it TDD.com and it worked fine for years following Y2K . From Comp.Sys.Atari.8bit Okay ... I want you to go to the archives and find a program called "Bedit.com" by Bill Aycock I believe. Next, pull a copy of TD.COM from your SDX cart (type car:td.com >>td.com) Now, using Bedit, edit your TD.COM. (R) reads the file into Bedit. Go to byte 426 using the goto command (G). This is the start of a 12 byte table. Increment the 12 bytes by 1. e.g 00, 03, 03, 06, 01 becomes 01, 04, 04, 07, 02 the command is, =01 or what ever the required byte is. Write the file to a disk (W) a name other than TD.COM (TDD.COM) .. and load it insted of TD.COM when you next boot SDX ... you're day of the week is now correct. The existing 12 bytes will be: 00 03 03 06 01 04 06 02 05 00 03 05 followed by the days of the week first letter table SSMTWTF Hope this helps 1 1 Quote Share this post Link to post Share on other sites
+Stephen #10 Posted 22 hours ago 52 minutes ago, itzmike said: Back in the good 'ol days of 19, I posted a fix I'd done to SpartadosX 4.22 to solve the same problem (back in the year 01). Re-posting my fix even though there are MUCH better patches out there. Hope this helps That's really cool - thanks for sharing. Quote Share this post Link to post Share on other sites
+Nezgar #11 Posted 16 hours ago The perfectionist in me was a little disappointed that even though the date byte can be 0-255 and 99 = 1999, that the "fixed" TDline code didn't take 100 as 2000, but merely started over from 0 again... Technically, the year byte could have differentiated from 1900 all the way to 2155, and the weekday would have continued to calculate correctly, and my BBS wouldn't stop deleting inactive users because their last calls were 100 years in the future... But this way is probably for the best - otherwise all the other software starts showing garbage in the year field... semicolons, etc... Quote Share this post Link to post Share on other sites
