Adamj91 #1 Posted May 25, 2021 Does anyone know how to open up the mini din shell? I have my 3do rgb modded using this genesis bnc 9pin cable for it but has a resistor/capacitor in its head that needs to come out so the image isnt so dark. Thanks! Quote Share this post Link to post Share on other sites
actionarcade #2 Posted July 21, 2021 If I was you, I would just get the HD Retrovision Genesis cable as I believe it works directly with the 9 pin as is and will give you component output. I assume you are otherwise attempting to use a Genesis SCART cable with the 3DO for RGB is that right? As other Genesis cables would be just provide composite that the 3DO already has. I'm considering the RGB mod myself and am yet learning all about it and if difficult to install. Quote Share this post Link to post Share on other sites
