Maury Markowitz Posted June 11, 2021 Share Posted June 11, 2021 In the early 1980s I visited a neighbour’s house here in Canada. His father was an engineer (SPAR Aerospace IIRC) and the house was filled with every gadget of the era. Among these was a computer trainer I had seen in catalogs and I’m trying to identify it. The key feature of the system was a display consisting of a 4x4 (or 5x5?) grid of red LEDs lamps in a panel that was raised above the main desk-top console on two cylindrical supports. This placed the display at eye level. I recall the panel itself was oval shaped. This is the key feature, if you’re going to suggest a potential system and it does not include this display, it is not the system in question. I recall 8-segment LEDs being for score keeping but I am no longer sure if they were on the display panel or on the base unit. The rest of the unit was a simple desktop box with a hex pad in the lower right. Poking about in Google Images, it is overall similar in layout as the ELF II and I would not be surprised if it was based on this system. All I recall running on it was a Pong clone where the ball moved back and forth on the LED lamps. As I had seen it in a catalog, that almost certainly suggests it was Tandy/Radio Shack, but looking through historical catalogs from 1978 to 1982 I cannot find anything similar - just those 150-in-1 kits where you wire together using springs. That might suggest Heathkit, but they were not terribly popular in Canada and I can’t find anything like that in their catalogs either. I have a dim memory of the system being offered by two companies, that it was actually produced by one and was being white labeled by another… again, that strongly suggests the second company was Tandy. Anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
