rossum
Runes of Moria - WIP 3D First Person on Vanilla 4k
7 hours ago, Thomas Jentzsch said:
What did you change?
A few suggestions:
  • Allow moving sideways (Fire + Left/Right)
  • I don't know how you determine the color of a wall (there seems to be some logic behind it), but it would help navigating and mapping if the colors do not repeat on consecutive walls.
  • The walls sometimes look lacerated at top and bottom, can that be avoided?
The change exploits a visual artifact on CRTs that produces nice vertical hairlines between blocks. This gives an impression of much higher resolution. I don't know if the effect is as visible on PAL CRTs. A few clumsy pictures from my NTSC CRT enclosed.
I like the idea of strafe but have other plans for the fire button. will try it and see how it feels.
The map is evolving to make navigation clearer (but not too clear).
Wall laceration is a consequence of cheating on the math, am looking at ways of improving it. Moria is old and crumbly after all....
  • Like 5
This works in Stella too if you enable TV effects.
One day you have to explain your math. It is really impressive.
Posted (edited)
Omg are you kidding?
Have been waiting for this since Merlins Walls!
Now I can turn my TV right side up!
Edited by 4ever2600
Maybe you could have left/right be for rotating left and right, and down+left/down+right be for strafing left and right.  So you won't be able to back up without turning around.  Just an idea.
Speak friend and enter!
I'll be honest - for a system meant to play primitive games like Asteroids and Space Invaders, this is amazing.  I liked the 3D maze effect!
This is new to me.
I can see that the pics have wall steps of 4 dots and sometimes 1 of those dots is turned off to make the vertical black lines.
Can you explain (or point to an explanation) how this works?
Thanks.
The dots are not turned off. The lines are solely resulting from flickering on a CRT.
ok, but I still don't know what's happening.
Can you go into more details.
I don't think the reason has been fully explored. The vertical lines are there where two interlaced lines meet. I suppose the change from bright to dark and vice versa isn't spot on. So when a horizontal line ends, it ends slightly earlier. When it starts, it starts slightly later. And the resulting gaps form the vertical lines.
If you use Stella, you can experiment with the various TV filtering presets. Or switch to Custom preset and play with the TV effect parameters. You can do this live by selecting any setting via POS1/End hotkeys and changing it via Page-Up and Down.
Thanks.
I still don't understand but at least I'm in good company.
Perhaps it's something to do with how fast the TIA can change the signal level or how fast a typical TV can follow the change.
After all, TV's are designed for continuous tone images rather than sharp edges.
Cleverly exploited though.
Definitely the latter.
Yes, the bandwidth of the analog signal is limited. Also the cathode ray cannot change infinitely fast.
I suppose the effect varies quite a lot between CRTs. Probably it is even more pronounced on bad ones. :)
AFAIK @johnnywc was the first who used this effect for the bricks in Zookeeper.
