pwwit1 Posted June 20, 2021 Share Posted June 20, 2021 Hello, I think I know the answer to this, Suzi can mirror and flip, but does anyone know if you can use her to rotate a sprite 90 degrees? Something like this: A B C C F I D E F = B E H G H I A D G I could do it with the CPU, kind-of like a matrix transpose. If that is the only way to do it, what would be the best way to approach this (for speed) with a screen sized sprite? Appreciate any thoughts! Quote Link to comment Share on other sites More sharing options...
+karri Posted June 20, 2021 Share Posted June 20, 2021 I would draw the screen with Suzy in normal position and copy the draw buffer to the display buffer with the cpu in the rotated orientation. Not really what you wanted. But it works. Quote Link to comment Share on other sites More sharing options...
sage Posted June 20, 2021 Share Posted June 20, 2021 6 hours ago, pwwit1 said: I think I know the answer to this, Suzi can mirror and flip, but does anyone know if you can use her to rotate a sprite 90 degrees? not without changing the circuits. Quote Link to comment Share on other sites More sharing options...
Positron5 Posted June 20, 2021 Share Posted June 20, 2021 Just a thought?. You could arrange the palette into 2 * 2bit blocks of a 4 bit color sprite so that both images - the original and one shifted 90degrees- are together in the sprite data. Then you just turn on the relevant palette pens to display either representations. Of course it will only work for 4 color sprites. 1 Quote Link to comment Share on other sites More sharing options...
Pokeypy Posted June 20, 2021 Share Posted June 20, 2021 Proposal of an algorithm. Seems to work so far; but not sure, if in any cases: #!/usr/bin/perl use warnings; use strict; sub printArray { my @a = @_; my $i; for ($i=0; $i<=$#a; $i++) { print $a[$i]; if ($i == $#a) { print "\n"; } else { print " "; } } } my @a = qw(A B C D E F G H I); my $lines = 3; my $chars_per_line = 3; my @b = (); my $s = $chars_per_line - 1; my ($i, $u, $x); for ($i=0; $i<$lines; $i++) { $x = 0; for ($u=0; $u<$chars_per_line; $u++) { push(@b, $a[$s + $x]); $x += $chars_per_line; } $s -= 1; } printArray(@a); printArray(@b); Quote Link to comment Share on other sites More sharing options...
LX.NET Posted June 20, 2021 Share Posted June 20, 2021 6 hours ago, Pokeypy said: Proposal of an algorithm. Seems to work so far; but not sure, if in any cases: Sprite structures cannot be transposed like that as their data structure is heavily dependent on the bits in the sprite data. Quote Link to comment Share on other sites More sharing options...
LordKraken Posted June 20, 2021 Share Posted June 20, 2021 unless the sprite has been generated using the -u option (unpacked) Quote Link to comment Share on other sites More sharing options...
42bs Posted June 21, 2021 Share Posted June 21, 2021 On 6/20/2021 at 2:42 AM, pwwit1 said: Hello, I think I know the answer to this, Suzi can mirror and flip, but does anyone know if you can use her to rotate a sprite 90 degrees? Something like this: A B C C F I D E F = B E H G H I A D G I could do it with the CPU, kind-of like a matrix transpose. If that is the only way to do it, what would be the best way to approach this (for speed) with a screen sized sprite? Appreciate any thoughts! The card space is huge, so why not store the rotated sprite? Quote Link to comment Share on other sites More sharing options...
sage Posted June 22, 2021 Share Posted June 22, 2021 It is only a small patch to to the microcode to enable this feature. firmware.hex 1 1 Quote Link to comment Share on other sites More sharing options...
pwwit1 Posted June 27, 2021 Author Share Posted June 27, 2021 On 6/22/2021 at 2:04 PM, sage said: It is only a small patch to to the microcode to enable this feature. firmware.hex 4.7 kB · 13 downloads How does this work? On 6/21/2021 at 12:12 PM, 42bs said: The card space is huge, so why not store the rotated sprite? I'm generating the image at runtime via suzy! On 6/20/2021 at 12:27 PM, karri said: I would draw the screen with Suzy in normal position and copy the draw buffer to the display buffer with the cpu in the rotated orientation. Not really what you wanted. But it works. This is the approach I've taken. Not sure how fast it will be on real hardware though. Trickier than I first thought because of the pixel packing, but it works. Not optimized at all either! My code is below: ; ; ==================================== ; sys_Copy3DScreenWithRotate ; Copes an area of 72x72 and transposes it ; ==================================== sys_CopyScreenWithRotate ldx #36; inner loop ldy #0 ; outer loop stz z_C ; stores the column ; backup dst address lda z_dst_L sta z_AL lda z_dst_H sta z_AH lda #0 sta z_C .copyline: lda z_C and #1 beq .drawLeft jsr plotRightPixel jmp .endPlot .drawLeft: jsr plotLeftPixel .endPlot: jsr sys_NextDstLine jsr sys_NextSrcPixel dex bne .copyline; ; Woo! Completed a line! ; Next destination source clc lda #44; adc z_src_L sta z_src_L bcc .L3 inc z_src_H .L3: ldx #36 lda z_C and #1 beq .skipY iny .skipY: inc z_C ; reset dest Plus next pixel clc tya adc z_AL sta z_dst_L lda z_AH sta z_dst_H cpy #36; we only do half the vertical lines bne .copyline rts sys_NextDstLine clc lda #80; Divide by two is because each byte is actually two pixels!! So to offset 160 pixels it's actually 80 bytes adc z_dst_L sta z_dst_L bcc .L0 inc z_dst_H .L0: rts sys_NextSrcPixel ; Next source pixel(16-bit add) inc z_src_L bne .L1 inc z_src_H .L1: rts ; Plot 2 horizontal pixels (left) plotLeftPixel lda (z_src) asl asl asl asl sta (z_dst) jsr sys_NextDstLine ; Second pixel lda (z_src) asl asl asl asl sta (z_dst) rts ; Plot 2 horizontal pixels (right) plotRightPixel lda (z_src) and #%00001111 ora (z_dst) sta (z_dst) jsr sys_NextDstLine ; Second pixel lda (z_src) and #%00001111 ora (z_dst) sta (z_dst) rts 1 Quote Link to comment Share on other sites More sharing options...
42bs Posted June 27, 2021 Share Posted June 27, 2021 50 minutes ago, pwwit1 said: This is the approach I've taken. Not sure how fast it will be on real hardware though. Trickier than I first thought because of the pixel packing, but it works. Not optimized at all either! I used to do it in the driving school program. Printed all text and then converted it into an literal sprite for easy scrolling. Quote Link to comment Share on other sites More sharing options...
42bs Posted June 27, 2021 Share Posted June 27, 2021 52 minutes ago, pwwit1 said: lda z_C and #1 beq .skipY lda z_C lsr bcc .skipY Saves you a byte. Quote Link to comment Share on other sites More sharing options...
solo/ng Posted June 29, 2021 Share Posted June 29, 2021 On 6/21/2021 at 6:12 AM, 42bs said: The card space is huge, so why not store the rotated sprite? this! unless you want to pre-rotate tons of sprites already in assets - I would just add another sprite frame rotated by 90. Quote Link to comment Share on other sites More sharing options...
pwwit1 Posted July 1, 2021 Author Share Posted July 1, 2021 On 6/30/2021 at 3:36 AM, solo/ng said: this! unless you want to pre-rotate tons of sprites already in assets - I would just add another sprite frame rotated by 90. I'd love to, but it's rotating a 72x72 buffer that is generated at runtime! Quote Link to comment Share on other sites More sharing options...
