fan4899 Posted June 25, 2021 Share Posted June 25, 2021 Hello all. I've recently been playing alot of paddle games and noticed something peculiar. On every game I've played so far, the player 1 paddle is almost as twice as sensitive as the player 2 paddle. Is this normal? Both sets of paddles I own have this same behavior. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 25, 2021 Share Posted June 25, 2021 No, that's not normal. Maybe your console has a problem? Quote Link to comment Share on other sites More sharing options...
fan4899 Posted June 25, 2021 Author Share Posted June 25, 2021 5 minutes ago, Thomas Jentzsch said: No, that's not normal. Maybe your console has a problem? Thats what I'm thinking is the case. The paddles have the same sensitivity as one another when plugged into the second controller port. I'm not really sure what could be causing the issue though. I've taken the console apart and everything looks fine, both ports are identical and all of the solder joints look fine. Quote Link to comment Share on other sites More sharing options...
Steve Guidi Posted June 26, 2021 Share Posted June 26, 2021 (edited) 12 hours ago, fan4899 said: Thats what I'm thinking is the case. The paddles have the same sensitivity as one another when plugged into the second controller port. I'm not really sure what could be causing the issue though. I've taken the console apart and everything looks fine, both ports are identical and all of the solder joints look fine. The paddles are built with a 1M-Ohm potentiometer, which is given 5V from pin 7 in the controller. The system detects the "resistance" by measuring the time taken to charge an internal capacitor. If the capacitor is out of spec, then the charge time will vary and produce a different and incorrect reading of the controller's potentiometer. I suspect this is the case since you've verified the correct behavior on the other joystick port, using the same controller. Here's a link to the schematics showing a .068uF capacitor used on the analog input pins (5,9 for paddle inputs). Perhaps you can just replace the ones used on the misbehaving port. https://www.atariage.com/2600/archives/schematics/Schematic_2600_Low.html Edited June 26, 2021 by Steve Guidi 1 Quote Link to comment Share on other sites More sharing options...
