DavidMil
Going Back in Time...
Ok folks:
How many of you know what this is?  And... How many of you have ever used one?
DavidMil
String between two cans for communications, old style?🤣
Wire wrapping kit. never used it myself.
james
Yup.  Built circuits using the little manual tool shown, as well as the spiffy gun.
These days, I mainly just use the wire as jumpers, soldered at each end.
Used something similar to wire PCB's into a chassis (military equipment)
Dental floss for people with large gaps between their teeth?
  • Haha 3
8mm video reel.  My dad took alot of film of family back in the 70's/early 80's with one.  Like 2.5 mins of film per roll.  I bought a projector and converted all my old videos by pointed a camcorder at the screen and playing the videos.  Blast from the past :)
wire-wrapping?
for magnetic core memory perhaps?
I grew up on point-to-point soldering. One boss made me wire wrap a prototype board. That was my first time... and my last!
Only problem with 8 mm is that this reel is 36mm wide.  I used to have a lot of 8mm moves too.  I have no idea what ever happened to them.
All good answers here!  I'll add one.  This could be a good device to to sell to the CIA.  Imagine using this as a device to question prisoners.
Put that up the prisoners nose and start twisting.  I'll talk, I'll talk!!!
Posted (edited)
I was going to suggest it's an old reel for splicing tape for repairing/editing old movie reels, as I had a job as a projectionist while I was in college.
But looking closer I see that it is only the shadow of the white insulated wire, or whatever it is, that I'm seeing and not a slight side perspective of splicing tape.
Edited by Gunstar
I once had to go into a machine in the plant that I worked in and solder all the wire wraps as vibration in the system had caused them to start getting loose causing intermittent problems.  There were hundreds of them.
The soldering solved all of the problems we had with that system...
Oh god they taught us wire wrapping in school way back in 1984. Hatted it then, even more so now. Still have the tool somewhere…
A few years ago, Curt Vendel posted photos of his wire-wrapped 520ST prototype he had found when he was doing his dumpster-diving and hard-core collecting thing back in the early 90’s. IIRC, he was holding the board and posing with Leonard Tramiel in more recent years. And Landon Dyer’s long-time blog Dadhacker has some great stories about the anguish and frustration of bringing those first wire wrap boards up and trying to get them to run for more than a couple minutes while they worked on driver firmware for the disk drive and bootstrapping the OS … Ugh. :)
30 ga. Kynar wire used to wire-wrap circuits. Spent many a midnite wrapping in changes and fixes to wire-wrap boards.
Used electric guns, of course. Wire came pre-stripped in every length by 1/2 inch.
Bob
To this day, when I do RAM (or other) upgrades, I will still wrap a couple of turns around a lifted IC leg before soldering.  It makes
it so much easier to keep the wire on the IC leg!  As my hands have stared to shake more, this has become a much better way to
do the upgrades.
David
In the 90s i worked for a company called VERO Electronics and we sold this type of equipe.
And there are rare inquiries for this as today.
Posted (edited)
I remember Vero, they did prototyping strip boards etc..Sure we sold a lot of their gear..
We also sold wire wrapping pens and obviously wire wrapping wire and IC sockets but none of it looked like the picture (as far as I remember).
Edited by Mclaneinc
I still remember debugging a board that turned out to have a broken wire-wrap wire right at the first turn (so it looked OK).  And, of course, it was the bottom wire, with a couple more wrapped above it on the pin.  It was really tricky to find as everything looked correct when tracing out all of the wires.
The plastic spool looks very much like a 35 mm. microfilm reel (complete with the slot to start the film), though it has apparently been repurposed here.
Bob
yes it is for wire wrapping.. but it seems to work only well with square shaped pins. the wire bites onto the square edges of the pins and those pins are extra long to wrap more than one signal on them.
No I don't have a punch-card as a bookmark!
