Wyluli Wolf Posted June 30, 2021 Share Posted June 30, 2021 I have a two port Atari 5200 console. It's in really nice shape (like new). It's been working fine. Its been several months since I last played it. Today I fired it up and I now have a garbled gray screen. You can make out a little bit of the game picture, so it's not all static. I've always had the console connected to a CRT television via the coaxial cable (channel 3). I did try adjusting the color adjustment pot, but it made no difference. I'll use a test cart to recalibrate if I can get it back up and running proper. Any idea on where I should start with troubleshooting? Thanks -Wolf Quote Link to comment Share on other sites More sharing options...
AtariBrian Posted June 30, 2021 Share Posted June 30, 2021 Power supply going bad?? Quote Link to comment Share on other sites More sharing options...
BIGHMW Posted June 30, 2021 Share Posted June 30, 2021 (edited) Check the channel switch on the console, it may be (inadvertently) set on channel 2 rather than 3 so try that, you may also want to flip between channels 2 and 3 on the TV itself to see if I'm right or not, but it just might simply be that, no sense of your unit going out on you for (what appears to be) no reason at all. Edited June 30, 2021 by BIGHMW Quote Link to comment Share on other sites More sharing options...
Wyluli Wolf Posted June 30, 2021 Author Share Posted June 30, 2021 1 hour ago, BIGHMW said: Check the channel switch on the console, it may be (inadvertently) set on channel 2 rather than 3 so try that, you may also want to flip between channels 2 and 3 on the TV itself to see if I'm right or not, but it just might simply be that, no sense of your unit going out on you for (what appears to be) no reason at all. Gave that a try and no joy. Quote Link to comment Share on other sites More sharing options...
Wyluli Wolf Posted June 30, 2021 Author Share Posted June 30, 2021 1 hour ago, AtariBrian said: Power supply going bad?? Probably worth checking this. I'll see if I can find info on how to test. Quote Link to comment Share on other sites More sharing options...
Wyluli Wolf Posted July 1, 2021 Author Share Posted July 1, 2021 21 hours ago, AtariBrian said: Power supply going bad?? Appears that the power supply is the culprit. Thanks! Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted July 2, 2021 Share Posted July 2, 2021 17 hours ago, Wyluli Wolf said: Appears that the power supply is the culprit. Thanks! Did you try a different one and it works? Curious as your picture does show the system powering on and as you stated we can kinda see the game through the mess. Quote Link to comment Share on other sites More sharing options...
