a6502 Posted July 1, 2021 Share Posted July 1, 2021 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted July 1, 2021 Share Posted July 1, 2021 Crack it open, lets see whats inside! Is that a momentary contact button at the top? Quote Link to comment Share on other sites More sharing options...
a6502 Posted July 1, 2021 Author Share Posted July 1, 2021 I found more information about it. It’s a Jumpstart, a cartridge with a push button on top to do coldstarts. Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted July 1, 2021 Share Posted July 1, 2021 Show any software within ROM chips ? Quote Link to comment Share on other sites More sharing options...
a6502 Posted July 1, 2021 Author Share Posted July 1, 2021 I don’t have the cart in hands, but I believe there is no ROM involved. Somehow it tricks the computer to reset using the cartridge pin connector. I’m sure a search for coldstart here in the forum will reveal more accurate information. Quote Link to comment Share on other sites More sharing options...
a6502 Posted July 1, 2021 Author Share Posted July 1, 2021 Jumpstart by Logic One Quote The Jumpstart Module is a cartridge with a small push button on the top. Although it plugs into the cartridge slot, it uses no memory. The module works as advertised. You simply hold down that button and press [RESET]. It's more convenient on the 800XL than the XE because of the location of the cartridge slots. Unfortunately, you can't use the Jumpstart Module with other cartridges. The Jumpstart Module works by telling the OS that a cartridge has been inserted. That forces a coldstart, but it can also confuse the computer about the cartridge status. Sometimes this causes a problem and you must press [RESET] again. To prevent confusion, I find that an always reliable method is to press [RESET] a second time (without the Jumpstart switch) as soon as the disk starts to spin. The Jumpstart Module is not exactly the same as a hardware generated coldstart. The Jumpstart Module uses the OS to reset the computer. In a very severe program crash, the OS might not be able to regain control. A true hardware reset, like turning the computer off, then on again, will always reset the computer. from: https://www.atarimagazines.com/v7n9/productreviews.html Quote Link to comment Share on other sites More sharing options...
Tillek Posted July 1, 2021 Share Posted July 1, 2021 Obviously part of a conspiracy to put the power switch manufacturers out of business! 1 1 Quote Link to comment Share on other sites More sharing options...
DavidMil Posted July 2, 2021 Share Posted July 2, 2021 I would still like to see what is inside of that cartridge. DavidMil Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 2, 2021 Share Posted July 2, 2021 (edited) On XL/XE there's a connection from the RD5 line on the cartridge to TRIG3 - the OS sets GINTLK Ram shadow to reflect the cartridge status on coldstart. On a warmstart and every VBlank a comparison is performed. If it's different in VBlank, the OS will either instantly coldstart or go into a wait loop depending on revision (loop on later ones). If it's different on warmstart, the computer will do a coldstart. Where you can get problems is if you have the older rev - the coldstart initiates and you release the button, so the cartridge state reverses again. The VBlank comparison only takes place if CRITIC is clear which isn't the case if SIO operations are occurring, so that would account for problematic operation. So, inside the cartridge - probably very little to no hardware. Maybe a component or 2 or 3 to stop power spikes or provide some sort of debounce but probably no more. A worthwhile modification to such a device might be to add a memory write protect switch which would allow loading unmodified Roms into Ram and running them without having to remove any self-destruct copy protection code. Edited July 2, 2021 by Rybags 3 Quote Link to comment Share on other sites More sharing options...
a6502 Posted July 3, 2021 Author Share Posted July 3, 2021 On 7/1/2021 at 8:07 PM, DavidMil said: I would still like to see what is inside of that cartridge. DavidMil me too @DavidMil I even asked the seller if he would sell only that cartridge, but looks like he sold the whole lot already $$$ https://www.ebay.com/itm/373616337347?mkcid=16&mkevt=1&_trksid=p2047675.l2557&mkrid=711-127632-2357-0&nma=true&si=gnhEl1mYVYmJo%2FaSfL%2BN33C9lZg%3D&orig_cvip=true&nordt=true&rt=nc Quote Link to comment Share on other sites More sharing options...
