Sign in to follow this
Count9929A
Help with FW with nanoPEB
Hi,
 I would like to use FW with my real TI+nanoPEB. I have a single 40 tracks disk-image version of FW that works fine in MAME.
So I copied that image in one of the volumes in the nanoPEB's CF card. Doesn't work well. Here is what happens, starting from LOAD (in TI XB):
- the XB screen is displayed (like in MAME)
- the configure FW option works well (like in MAME) except that it hangs in writing the configuration into FW and UTIL1 (but no problem in writing back LOAD)
- the WP / ED do not work: when I run them, the screen goes blank and the TI does not respond anymore
- the "loaders" menu is displayed, but then the TI hangs (the screen does not go blank, but nothing happens anymore when i press any key).
Any hint about what's the problem? My first guess was some configuration problem, but it seems all options are setted like in the working disk-image
Second guess: any file got corrupted in the CF write process? Could be but strange, but the files in the other CF volumes seem all ok. Could you suggest how to proceed to quickly find the issue?
In this case, forum search is your friend ;)    Here is some info that should answer some of your questions.  One of the referenced topics should contain a patched F'web image.
S
