Rickster8 Posted July 28, 2021 Author Share Posted July 28, 2021 Quick DF / WW Update: (Thru Post #76) Dreadnaught Factor 14,670 - IntyFanMatt 11,000 - Wolfy62 7,343 - mr_me 4,506 - Rickster8 3,413 - t0spmad 2,884 - ed1475 2,487 - jblenkle 1,789 - Sprazzi 1,566 - fakecortex 638 - Lupovax 1 - CParsley White Water Game 1 43.8 secs - RogerPoco 43.8 secs - Sprazzi 44.8 secs - Rickster8 53.8 secs - Lupovax 55.5 secs - gezkc 58.6 secs - Wolfy62 61.7 secs - ed1475 64.1 secs - roadrunner 81.8 secs - fakecortex Game 2 34.6 secs - Sprazzi 37.2 secs - Rickster8 45.6 secs - gezkc 46.6 secs - Lupovax 49.7 secs - Wolfy62 57.4 secs - ed1475 57.6 secs - roadrunner 68.2 secs - fakecortex 1 1 Quote Link to comment Share on other sites More sharing options...
Rickster8 Posted July 29, 2021 Author Share Posted July 29, 2021 My DREADFUL Factor Update: ? Had a better game this time. I got the Razor 4th again and just narrowly beat it, then I got the Cigar which I beat as well, but then the Double Pronged ship got me. Those little VERY fast ships are a real bitch.... ? 7,222 - LEVEL 5 1 1 Quote Link to comment Share on other sites More sharing options...
jblenkle Posted July 29, 2021 Share Posted July 29, 2021 Dreadnaught Factor - 4,016 2 Quote Link to comment Share on other sites More sharing options...
mr_me Posted July 29, 2021 Share Posted July 29, 2021 5 hours ago, Rickster8 said: Had a better game this time. I got the Razor 4th again and just narrowly beat it, then I got the Cigar which I beat as well, but then the Double Pronged ship got me. Those little VERY fast ships are a real bitch.... ? Yeah, new enemy weapons show up as you advance in the game. I wish the game was designed so weapons are consistent per difficulty level. 2 Quote Link to comment Share on other sites More sharing options...
lupovax Posted July 29, 2021 Share Posted July 29, 2021 White Water Game 2 - 40.1 3 Quote Link to comment Share on other sites More sharing options...
+JasonlikesINTV Posted July 31, 2021 Share Posted July 31, 2021 Guys, I really suck at White Water. What's your best pro-tip advice for navigating the rapids in 3 sentences or less? Quote Link to comment Share on other sites More sharing options...
Rickster8 Posted July 31, 2021 Author Share Posted July 31, 2021 1 hour ago, JasonlikesINTV said: Guys, I really suck at White Water. What's your best pro-tip advice for navigating the rapids in 3 sentences or less? Avoid the whirpools..... ? 2 Quote Link to comment Share on other sites More sharing options...
sprazzi Posted July 31, 2021 Share Posted July 31, 2021 3 hours ago, JasonlikesINTV said: Guys, I really suck at White Water. What's your best pro-tip advice for navigating the rapids in 3 sentences or less? Rogerpoco did a write up just up above that is really good 2 Quote Link to comment Share on other sites More sharing options...
lupovax Posted July 31, 2021 Share Posted July 31, 2021 White Water Game 1 - 50.1 Dreadnaught Factor - 2013 3 Quote Link to comment Share on other sites More sharing options...
wolfy62 Posted August 1, 2021 Share Posted August 1, 2021 20 hours ago, JasonlikesINTV said: Guys, I really suck at White Water. What's your best pro-tip advice for navigating the rapids in 3 sentences or less? Use the top of the disc a lot and slide to the left or right slightly to steer your raft. Gotta stay in the Rapids to build speed and have the front of the raft facing directly downstream with the back of the raft at the same downward angle whenever possible. Avoid those stupid whirlpools they will mess up your time for sure. Just bounce those barrels out of the way rather than trying to avoid them to much. Sorry Jason,that's 4 sentences but I am hoping to help you out. Ita a great game! Not Dreadnaught great,but still great. 3 1 Quote Link to comment Share on other sites More sharing options...
cparsley Posted August 1, 2021 Share Posted August 1, 2021 I am extremely debating withdrawing from this season's HSC... The emu will only map 4 directions (N,E,W,S) so cant get the 16-direction of the pad so cant do the top times in white water, and the straw just about to break the back is Motorcross will not even run on the emulator, crashing after the game draws the course map. Ok, getting off the soap box, someone might need to do laundry. 4 Quote Link to comment Share on other sites More sharing options...
mark griff Posted August 1, 2021 Share Posted August 1, 2021 Here's the best I could do so far one day left wow I'm not use to playing game 5. Awfully tough I need a lot more practice 5 Quote Link to comment Share on other sites More sharing options...
jblenkle Posted August 1, 2021 Share Posted August 1, 2021 Dreadnaught Factor - 4,144 4 Quote Link to comment Share on other sites More sharing options...
mark griff Posted August 1, 2021 Share Posted August 1, 2021 Well I little improvement hats off to the one who completed this level. 5 ships is the best I can do 3 1 Quote Link to comment Share on other sites More sharing options...
mark griff Posted August 1, 2021 Share Posted August 1, 2021 Here's my game 1 WW 3 Quote Link to comment Share on other sites More sharing options...
mark griff Posted August 1, 2021 Share Posted August 1, 2021 Here is game 1 best and game 2 best 3 Quote Link to comment Share on other sites More sharing options...
mr_me Posted August 1, 2021 Share Posted August 1, 2021 (edited) 13 hours ago, cparsley said: I am extremely debating withdrawing from this season's HSC... The emu will only map 4 directions (N,E,W,S) so cant get the 16-direction of the pad so cant do the top times in white water, and the straw just about to break the back is Motorcross will not even run on the emulator, crashing after the game draws the course map. Ok, getting off the soap box, someone might need to do laundry. Haven't seen an Intellivision emulator that doesn't map all sixteen directions to an analog stick. If using the keyboard, do you not get NE when pressing the N key and the E key together. White Water seems to only use eight directions for the rafting part of the game. Edited August 1, 2021 by mr_me Quote Link to comment Share on other sites More sharing options...
mark griff Posted August 1, 2021 Share Posted August 1, 2021 Game 2 white water higj 3 Quote Link to comment Share on other sites More sharing options...
mark griff Posted August 1, 2021 Share Posted August 1, 2021 Game 1 white water high 4 Quote Link to comment Share on other sites More sharing options...
mark griff Posted August 1, 2021 Share Posted August 1, 2021 Dreadnought best wow is level 5 hard 2 Quote Link to comment Share on other sites More sharing options...
IntyFanMatt Posted August 1, 2021 Share Posted August 1, 2021 8 minutes ago, mark griff said: Dreadnought best wow is level 5 hard Sure is! And the sadistic game designer created 2 more levels, 6 & 7, if you feel like demoralizing yourself for fun. 3 Quote Link to comment Share on other sites More sharing options...
cparsley Posted August 1, 2021 Share Posted August 1, 2021 1 Quote Link to comment Share on other sites More sharing options...
cparsley Posted August 1, 2021 Share Posted August 1, 2021 3 hours ago, mr_me said: Haven't seen an Intellivision emulator that doesn't map all sixteen directions to an analog stick. If using the keyboard, do you not get NE when pressing the N key and the E key together. White Water seems to only use eight directions for the rafting part of the game. You can get 8 from a 4 way map (N+E = NE) but you can't do the INTV 16-way, NNE, ENE etc) Quote Link to comment Share on other sites More sharing options...
cparsley Posted August 1, 2021 Share Posted August 1, 2021 Quote Link to comment Share on other sites More sharing options...
