Milli Vee
Adam and SGM issue
I have an issue with the SGM and the stand alone Adam. When I use the AUX video out I have no sound from the SGM but if I use the RF out I do. I do have normal adam and colecovision sound out the aux video so I know that it is not a cable issue. Is this a me thing or? The sound works just fine on the Colecovision and the SGM.
Have you done the sound modification on your ADAM?
5 minutes ago, Milli Vee said:
Nope - what modification and why?
Oh, gawd...you would ask me that...I forget the specifics, and the video is apparently no longer up, but you have to cut a wire inside the ADAM and solder it to the leg of C8(???) C88(???) or you don't get any expansion module sound and the SGM is an expansion module.
3 minutes ago, Milli Vee said:
Ok - maybe I should have asked how
I just did the SGM sound fix . I have very little experience with a soldering iron but found it took longer to take the Adam apart than to fix it. It is a very easy fix and I am so glad I did it.
TBH I think this fix can be done without soldering if you just extend the green wire a bit and attach a very small aligator clip. Then just attach the clip[ to the cap.
