ballyalley
ATR Disk Directory Listing to a File
I'm looking for a program for Windows that will create an automatic disk directory listing in a text file of all of the ATR disk images in a file directory on my hard drive.  Does such a program exist?
Adam
Windows folks will tell you the best way but I can tell you at the very least you would be able to do it via cygwin(linux env) and atarisio program "adir" and shell commands. Example: "find . -iname \*.atr | xargs adir > filelist.txt"
Edited by invisible kid
I wrote a directory lister in python that outputs an html file like this. It's much too buggy to share right now, but one day...
1644948985_ScreenShot2021-07-24at13_06_40.thumb.png.7e8c805cc2203f8d2631fffbacce78cf.png
  • Like 4
I blogged a few years ago about getting DOS2 directories from atr images to illustrate how to build your own tools using perl for working with disk images:
Extracting data from DOS 2.0/2.5 disks - Atari_Ace's Blog - AtariAge Forums
To accomplish what you ask, you can use that little prototype tool and do:
for %i in (*.atr) do perl atr.pl -dir %i
It's not a turnkey solution of course, but you can adapt it to do what you want if you have a little programming knowledge.
If you're more specific about what you want for the output, I can modify it to your requirements.
Do I understand that you want to list all the ATR files in a windows folder to a text file? I can't say I know of anything automatic, but you could always open a command prompt, navigate to the directory, and issue the DIR command with a pipe to a text file, like this
Dir /B *.atr > atrfiles.txt
you can also have it recursively list every ATR in the directory and all subdirectories
dir /B /S *.ATR > atrfiles.txt
But note that this will also give you the full path to each file, not just the name.
Edited by Teflon
Hi,
   If you want to list the contents of each ATR file, you can use the DOS command line tool adir from https://www.horus.com/~hias/atari/
   I'm guessing you would need to use a batch file ".BAT" or ".CMD" type file to automate processing only .ATR files, but you're probably best off Googling how to do this, unless someone else on AA can come up with an example to share?
   Hope this helps!
Just had a play with ADIR.exe , as @E474 says, you can automate with a batch file.
I can't remember from a command prompt how to do the dir and pipe it into a batch command
(easy on linux) but someone here may know.
What I did was DIR /B *.atr > adir.bat
then edit the adir.:bat to add the adir command and the redirection of the output to a file
adir -t DOSxl2_3.atr >test.out
adir -t games.atr >> test.out
adir -t mydos.atr >> test.out
adir -t mydos1.atr >> test.out
adir -t mydos2.atr >> test.out
adir -t mytest.atr >> test.out
adir -t test.atr >> test.out
Run the batch file .\adir.bat
Here's the result:-
directory of image 'DOSxl2_3.atr'
  DOS     SYS 0046
661 free sectors
directory of image 'games.atr'
1012 free sectors
directory of image 'mydos.atr'
  DISASM  ASM 0668
  DOS     SYS 0037
 <DUP     SYS>0054
251 free sectors
directory of image 'mydos1.atr'
  DOS     SYS 0037
  DUP     SYS 0054
919 free sectors
directory of image 'mydos2.atr'
  DOS     SYS 0018
  DUP     SYS 0027
  BUG65   COM 0037
  CENT        0002
  CENT_EQUM65 0002
  CENT800 M65 0013
  CENT800 OBJ 0003
  CENT800 SRC 0023
  CENT800AM65 0011
  CENTPRTASRC 0004
  DRAW    BAS 0014
  MAC65   COM 0054
  SYSEQU  H   0009
  SYSEQU  M65 0006
  TEMP        0003
  TEMP1       0020
462 free sectors
directory of image 'mytest.atr'
708 free sectors
reading image 'test.atr' failed
I assume the test.atr is a faulty image
A lot of atari disks don't have a dos file structure, most of the commercial games were like that for instance, some will display some kind of message in the directory listing, most will just give you an error.
I don't think adir supports spartados format disks and I'm not sure if it can display mydos format directories with subdirs either.
These are all the kinds of things that don't work in my lister either which is why I haven't shared it yet.
Just checked and no it doesn't work with SDX disks.
Also adir won't work with menu disks either, I wrote one to directory Alphaload menu disks, long, long, ago :)
from the README
adir
'adir' lists the DOS 2.x directory of an image. By default the output
is similar to what you get when doing a directory listing from within
DOS 2.x. Filenames plus their sector size is output in 4 columns.
Usage: adir [option] file.atr...
Option may be one of:
-<num> set number of columns. eg: 'adir -1 dos.atr'
-t  enable 'tree mode', recurse into (MyDOS) subdirectories
-r  enable raw debugging output:
    The first number is the file-slot within a directory sector (0-7).
    The second number is the file attribute (in hex).
    After the filename the starting sector and the number of sectors
    (both in decimal) are shown.
Note: you can also pass multiple ATR files to adir, for example
"adir file1.atr file2.atr file3.atr". In Linux you can also use
the pathname expansion feature of your shell and get a listing
of all files: "adir *.atr".
Edited by TGB1718
So it can do mydos disks! cool.
I just did a quick test of that
Spoiler
directory of image 'SillyPack2k17.atr'
  AUTORUN AR0 0065
 :BONUS       0008
      HAPPYDAYTXT 0003
      HAPPYDAYXEX 0078
      NABUCHODTXT 0005
      NABUCHODXEX 0003
      README  TXT 0010
      README  XEX 0031
      REALTIMETXT 0028
      REALTIMEXEX 0043
      SV2K17INTXT 0003
      SV2K17INXEX 0079
 :DEMO        0008
      PROZACDRTXT 0011
      PROZACDRXEX 1384
      REHARDENTXT 0006
      REHARDENXEX 0297
      TEMPLATETXT 0004
      THEROCKYTXT 0006
      THEROCKYXEX 0392
      WEPLASH TXT 0012
      WEPLASH XEX 0048
  DOS     SYS 0037
  DUP     SYS 0054
 :GAME        0008
     :ALIENS      0008
          ALIENSFRMIC 0077
          F       FNT 0009
          MUZ     DAT 0033
          S       TXT 0002
          S       XEX 0108
          TITLE   DL  0002
     :BOSCO       0008
          B128NTSCXEX 0652
          B128NTSEXEX 0652
          B128PAL XEX 0650
          B164NTSCXEX 0426
          B64NTSCSXEX 0426
          B64PAL  XEX 0424
          BOSCO   TXT 0010
          BOSCO   XEX 0650
      TEMPLATETXT 0005
 :GFX         0008
      ALIENSFRTXT 0002
      ALIENSFRXEX 0052
      ANTICTROG2F 0059
      ANTICTROPNG 0070
      ANTICTROTXT 0004
      ANTICTROXEX 0095
      ANTICTRPPNG 0501
      BALOONS G2F 0064
      BALOONS PNG 0127
      BALOONS TXT 0002
      BALOONS XEX 0161
      BUKA    G2F 2536
      BUKA    PNG 0089
      BUKA    TXT 0002
      BUKA    XEX 0060
      DRAGON  HPM 0154
      DRAGON  PNG 0213
      DRAGON  TXT 0004
      DRAGON  XEX 0611
      FULCRUM BMP 1476
      FULCRUM RAW 0123
      FULCRUM TXT 0001
      FULCRUM XEX 0134
      GREETS  G2F 0049
      GREETS  PNG 0130
      GREETS  TXT 0002
      GREETS  XEX 0109
      MYDEAR  BMP 0624
      MYDEAR  G2F 2536
      MYDEAR  GIF 1284
      MYDEAR  JPG 0333
      MYDEAR  PNG 0028
      MYDEAR  TXT 0002
      MYDEAR  XEX 0044
      ORDER   G2F 2593
      ORDER   GIF 7408
      ORDER   PNG 0120
      ORDER   TXT 0002
      ORDER   XEX 0122
      PHARAO  G2F 0064
      PHARAO  PNG 0132
      PHARAO  TXT 0002
      PHARAO  XEX 0145
      RICKSREVTXT 0005
      RICKSREVXEX 0109
      SHAMAN  G2F 0092
      SHAMAN  PNG 0100
      SHAMAN  TXT 0002
      SHAMAN  XEX 0110
      TEMPLATETXT 0001
 :INTRO16K    0008
      INB     TXT 0003
      INB     XEX 0080
      LP2K17IETXT 0003
      LP2K17IEXEX 0097
      OLDSCHOOTXT 0004
      OLDSCHOOXEX 0112
      TEMPLATETXT 0005
 :INTRO256    0008
      BART    A65 0005
      BART    DAT 0002
      BART    PNG 0013
      BART    TXT 0002
      BART    XEX 0003
      BLUES   TXT 0003
      BLUES   XEX 0003
      HOMER   A65 0006
      HOMER   DAT 0002
      HOMER   PNG 0013
      HOMER   TXT 0004
      HOMER   XEX 0003
      IVI256  PNG 0073
      IVI256  XEX 0003
      IVI256RATXT 0007
      IVI256RAXEX 0003
      JULIASM TXT 0003
      JULIASM XEX 0003
      NABUCHODASM 0039
      NABUCHODTXT 0008
      NABUCHODXEX 0003
      TEMPLATETXT 0005
      TWOTWISTTXT 0004
      TWOTWISTXEX 0003
      ZG      A65 0018
      ZG      TXT 0002
      ZG      XEX 0002
 :MSX         0008
     :COVOX       0008
     :GTIA        0008
      LEFTOVERRMT 0029
      LEFTOVERTXT 0002
      LEFTOVERXEX 0048
      LMPOKS  RMT 0014
      LMPOKS  TXT 0002
      LMPOKS  XEX 0034
      SEVENTH RMT 0057
      SEVENTH TXT 0002
      SEVENTH XEX 0075
      SNDSNOW RMT 0032
      SNDSNOW SAP 0050
      SNDSNOW TXT 0003
      SNDSNOW XEX 0052
      STRANGEGSAP 0045
      STRANGEGTXT 0003
      STRANGEGXEX 0048
      TEMPLATETXT 0003
      UCIECZKARMT 0049
      UCIECZKATXT 0003
      UCIECZKAXEX 0067
      WEZINNA RMT 0041
      WEZINNA SAP 0053
      WEZINNA TXT 0002
      WEZINNA XEX 0056
 :WILD        0008
      ATARISV G2F 2757
      ATARISV PNG 0077
      ATARISV TXT 0002
      ATARISV XEX 0021
      BLADE   BMP 1537
      BLADE   TXT 0002
      BLADE   XEX 0388
      BMX     BMP 2050
      BMX     PNG 0756
      BMX     TXT 0003
      BMX     XEX 0374
      FILM    TXT 0004
      FILM    XEX 0132
      GRETROFITXT 0004
      GRETROFIXEX 0080
      README  TXT 0011
      README  XEX 0032
      ROBBOSOLTXT 0003
      ROBBOSOLXEX 0124
      TEMPLATETXT 0005
0 free sectors
very nice.
The source is there, so adding SpartaDOS FS shouldn't be too difficult ;)
Thanks to everyone who contributed to help answer my questions.  I didn't expect so many people to chip in and give it a go-- although I should have known better, as this is AtariAge and everyone is always very helpful to me here.  I'm busy now and family is coming into town today, so I can't dive into trying these ideas; but I will give it a go in the next few weeks.
I'm attempting to get a directory listing of 971 ATR disk images in DOS 2.0S and DOS 2.5 format that are part of the BELLCOM Public Domain & Shareware Library.  You can read more about that collection, if you don't mind reading a thread, here:
https://atariage.com/forums/topic/125131-bellcom-pd-catalog-disk/
I want to upload the ATR images that I've collected on my hard drive to Archive.org, and I figured including such a listing would be helpful to include in the archive before its uploaded.
Adam
