stuartelectronics Posted July 28, 2021 Share Posted July 28, 2021 So I was working on my first Atari 2600 game witch is a maze game and I ran into a few problems. A major problem is I can not get the walls to work! I know that you have to do if collision(player1, playfield) then goto player1HitWall I need the same thing player 0 then later in the code i have this player0HitWall a = e b = f player0x =player0x -1 player0y =player0y +1 goto main how ever this code is not very good can some one please help me find a better code because this is just make the player fly across the screen. Also i need the ball (the item you get to give you points) to go to all the corners of the screen and then the center of the maze. and i also need there to be more than one enemy and i want them to have a certain path they take ill post the code here: rem jungle jam code START a = 75 b = 00 c = 75 d = 25 z = 0 p = 0 player0x = 75 player0y = 40 player1x = 75 player1y = 80 ballx =50 bally =40 COLUP0 = $60 COLUBK = $16 NUSIZ0 = $60 end main f=f+1 rem sprites if f = 10 then player0: %00111100 %00011000 %00011000 %01100110 %01011010 %00111100 %00011000 %00011000 end if f = 10 then player1: %01100110 %00100100 %00011000 %10111101 %01000010 %01100110 %00111100 %00011000 end playfield: XXXXXXXXXXX..XXXXX..XXXXXXXXXXX X....X.........X.........X....X X....X....X.........X....X....X XX...XX...XXXXXXXXXXX...XX...XX X.........X.........X.........X XX.XXXX...XXX.....XXX...XXXX.XX X....X.....X.......X.....X....X XX.............X.............XX X....XX..X.....X.....X..XX....X X....X...................X....X XXXXXXXXXXX..XXXXX..XXXXXXXXXXX end COLUP1 = $02 COLUP0 = $80 COLUPF = $11 if f=10 then f=0 if joy0right then REFP0 = 0 if joy0left then REFP0 = 8 drawscreen if player1y < player0y then player1y = player1y + 1 if player1y > player0y then player1y = player1y - 1 if player1x < player0x then player1x = player1x + 1 if player1x > player0x then player1x = player1x - 1 if collision(ball, player0) then goto gold if switchreset then goto START if joy0right then player0x = player0x + 1 if joy0left then player0x = player0x - 1 if joy0up then player0y = player0y - 1 if joy0down then player0y = player0y + 1 if player1y < player0y then player1y = player1y + 1 if collision(player0, playfield) then goto player0HitWall if collision(player1, playfield) then goto player1HitWall if collision(player1, player0) then goto ouch if player0y < 30 then goto player0HitWall if player1y > 66 then goto player1HitWall goto main rem this is were the wall trouble is. player0HitWall a = e b = f player0x =player0x -1 player0y =player0y +1 goto main player1HitWall c = g d = h player1x =player1x -1 player1y =player1y +1 goto main rem this is were the ball trouble is gold if score = 0 then score = score + 10 bally = bally + 0 goto main if score = 20 then ballx = ballx + 30 score = score + 10 if score = 30 then bally = bally +35 else goto main if score = 30 then ballx = ballx +10 else goto main if score = 50 goto win else goto main ouch end win rem ***************************************************** rem * Music Starter using sdata rem * Based on code posted in the Ballblazer thread at AtariAge: rem * http://www.atariage.com/forums/index.php?s=&showtopic=130990&view=findpost&p=1615280 rem * Code adapted by Duane Alan Hahn (Random Terrain) rem * Code further modified by Kirk Israel rem * Explanation: rem * The 256-byte limitation is removed when using sdata. rem * You can fill a whole 4k bank with music if you want. rem ***************************************************** set smartbranching on rem ***************************************************** rem * Create aliases for variables rem ***************************************************** dim duration=a dim datareader1=x ; just a reminder dim datareader2=y ; just a reminder rem * Volume off AUDV0=0 AUDV1=0 rem * Initialize duration and set up music duration = 1 goto MusicSetup rem ***************************************************** rem * Main game loop starts here. rem ***************************************************** MainLoop goto GetMusic GotMusic drawscreen goto MainLoop rem ***************************************************** rem * Music rem ***************************************************** GetMusic rem * Check for end of current note duration = duration - 1 if duration>0 then GotMusic rem * Retrieve channel 0 data temp4 = sread(musicData) temp5 = sread(musicData) temp6 = sread(musicData) rem * Check for end of data if temp4=255 then duration = 1 : goto MusicSetup rem * Play channel 0 AUDV0 = temp4 AUDC0 = temp5 AUDF0 = temp6 rem * Set duration duration = sread(musicData) goto GotMusic rem ***************************************************** rem * Music Data Block rem ***************************************************** rem * Format: rem * v,c,f (channel 0) rem * d rem * rem * Explanation: rem * v - volume (0 to 15) rem * c - control [a.k.a. tone, voice, and distortion] (0 to 15) rem * f - frequency (0 to 31) rem * d - duration MusicSetup sdata musicData = x 0, 0, 0, 24, 8, 12, 29, 22, 0, 0, 0, 48, 8, 12, 26, 2, 255 end goto GotMusic Quote Link to comment Share on other sites More sharing options...
+KaeruYojimbo Posted July 30, 2021 Share Posted July 30, 2021 You'll have better luck getting responses if you post this in the Batari Basic subforum. I don't have time to look through it now and people who are a lot better at this stuff than I am hang out over there. Quote Link to comment Share on other sites More sharing options...
