+Intellivision Master Posted August 4, 2021 Share Posted August 4, 2021 Would it be possible to have a dark mode option for Atari Age? I know some websites have a dark mode setting like YouTube & Reddit. Quote Link to comment Share on other sites More sharing options...
Albert Posted August 4, 2021 Share Posted August 4, 2021 There is a dark theme called "Deflection" you can select at the bottom of the page. Click on "Theme" and you can then select it. It is a completely different (commercial) theme so it doesn't match the default AtariAge theme, but functionally it is the same. ..Al 2 2 Quote Link to comment Share on other sites More sharing options...
+Intellivision Master Posted August 4, 2021 Author Share Posted August 4, 2021 4 hours ago, Albert said: There is a dark theme called "Deflection" you can select at the bottom of the page. Click on "Theme" and you can then select it. It is a completely different (commercial) theme so it doesn't match the default AtariAge theme, but functionally it is the same. ..Al Okay, great. Thank you. I never knew about this feature on here. Quote Link to comment Share on other sites More sharing options...
