+dhe Posted August 4, 2021 Share Posted August 4, 2021 I've never been able to figure out how to do nested if's, in XB. I am trying to implement checking for a leap year. I can do that thing in c or pascal, but can't figure out how to do that in XB - even brute forcing it. Microsoft says the correct STEPS are: How to determine whether a year is a leap year To determine whether a year is a leap year, follow these steps: If the year is evenly divisible by 4, go to step 2. Otherwise, go to step 5. If the year is evenly divisible by 100, go to step 3. Otherwise, go to step 4. If the year is evenly divisible by 400, go to step 4. Otherwise, go to step 5. The year is a leap year (it has 366 days). The year is not a leap year (it has 365 days). Some example java code - which would look about the same in c or pascal ... So basically a top end IF with more IF's in a block. Can anyone help with how to do something like that in XB? public class Main { public static void main(String[] args) { // year to be checked int year = 1996; boolean leap = false; // if the year is divided by 4 if (year % 4 == 0) { // if the year is century if (year % 100 == 0) { // if year is divided by 400 // then it is a leap year if (year % 400 == 0) leap = true; else leap = false; } // if the year is not century else leap = true; } else leap = false; if (leap) System.out.println(year + " is a leap year."); else System.out.println(year + " is not a leap year."); } } 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted August 4, 2021 Share Posted August 4, 2021 Just add line numbers to each line: 'Leap Year Determination Program (LEAP.BAS) INPUT "Year (eg 1998)";yr leap$="N" IF yr MOD 4 = 0 THEN leap$ = "Y" IF yr MOD 100 = 0 THEN leap$ ="N" IF yr MOD 400 = 0 THEN leap$ = "Y" IF leap$ = "Y" THEN PRINT yr; " is a leap year" ELSE PRINT yr; " is NOT a leap year" END IF Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 4, 2021 Share Posted August 4, 2021 The bigger problem here is the lack of the MOD operator in XB. 3 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted August 5, 2021 Share Posted August 5, 2021 I think this will work: Using Rich's example. Use: IF yr / 4 = INT(yr / 4 ) THEN leap$ = "Y" etc. 4 Quote Link to comment Share on other sites More sharing options...
RXB Posted August 5, 2021 Share Posted August 5, 2021 Well mod is easy to duplicate in XB: PRINT 5/2=INT(D) PRINT D*2=INT(M) PRINT 5-D=INT(MOD) PRINT INT(MOD) MOD = INT(1) ANOTHER EXAMPLE: PRINT 23/7=INT(D) PRINT D*7=INT(M) PRINT 23-M=INT(MOD) PRINT INT(MOD) MOD = INT(2) Not really that complicated using XB. 3 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted August 5, 2021 Share Posted August 5, 2021 to add to Rich's post, DEF can get you close to MOD though you only get one parameter. 100 DEF MOD(XX)=YR-INT(YR/XX)*XX 200 FOR YR=2096 TO 2104 400 LEAP$="NOT LEAP"!RESET 410 IF MOD(4)<>0 THEN 500 420 IF MOD(100)<>0 THEN 450 430 IF MOD(400)<>0 THEN 500 450 LEAP$="LEAP" 500 PRINT YR;LEAP$ 550 NEXT YR 2 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 5, 2021 Share Posted August 5, 2021 5 hours ago, dhe said: Microsoft says the correct STEPS are: You're taking your example from Microsoft??? There have been many occurrences of leap year bugs: Microsoft Excel has, since its earliest versions, incorrectly considered 1900 to be a leap year, and therefore that February 29 comes between February 28 and March 1 of that year. The bug originated from Lotus 1-2-3, and was purposely implemented in Excel for the purpose of backward compatibility. Microsoft has written an article about this bug, explaining the reasons for treating 1900 as a leap year.[7] This bug has been promoted into a requirement in the Ecma Office Open XML (OOXML) specification.[8][9] 1 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 5, 2021 Share Posted August 5, 2021 1 hour ago, dgrissom said: I think this will work: Using Rich's example. Use: IF yr / 4 = INT(yr / 4 ) THEN leap$ = "Y" etc. Bad leap year algorithm (many languages)[edit] The following code is an example of a leap year bug that is seen in many languages. It may cause either a Category 1 or Category 2 impact, depending on what the result is used for. It incorrectly assumes that a leap year occurs exactly every four years.[6] bool isLeapYear = year % 4 == 0; The correct leap year algorithm is explained at Leap Year Algorithm. Uhoh, this looks familiar! 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted August 5, 2021 Share Posted August 5, 2021 (edited) Here it is with the important code all in one line: 10 INPUT Y 20 LY=-((Y/4)=INT(Y/4))+((Y/100)=INT(Y/100))-((Y/400)=INT(Y/400)) 30 PRINT "LEAPYEAR=";LY 40 GOTO 10 If LY=1 then it is a leap year, if 0 then it is not a leap year. To explain: -((Y/4)=INT(Y/4)) returns a value of 1 if true and 0 if false, so if the year is divisible by 4 then LY=1. Then ((Y/100)=INT(Y/100)) returns a value of -1 if true and 0 if false, so if the year is divisible by 100 then 1 is subtracted from LY, making it 0. Then -((Y/400)=INT(Y/100)) returns a value of 1 if the year is divisible by 400 (Edit) This is a tiny bit more compact: 20 LY=((Y AND 3)>0)-((Y/100)<>INT(Y/100))-((Y/400)=INT(Y/400)) Edited August 5, 2021 by senior_falcon 3 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 5, 2021 Share Posted August 5, 2021 PTM TEXT '1155P2122299352*' ADV9 CLR R3 MOVB @PTM+12,R3 SWPB R3 INC R3 CI R3,>34 JNE NEXT6 LI R3,>3100 MOVB R3,@PTM+12 JMP ADV10 NEXT6 SWPB R3 MOVB R3,@PTM+12 This is what I've been using since '99... Part of the first assembly program I'd ever coded to date that used compares and conditional jumps. I wrote it based on the assumption that nothing more than incrementing and limits were required to produce an accurate clock/calendar.⌚ I seem to recall running it through a minute-by-minute high-speed advance of 10 years, without once setting off the S-D mechanism. I'm still here, so it must-be accurate? 1 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted August 5, 2021 Author Share Posted August 5, 2021 Thank you all for your help. Senior_Falcon thanks most of all, you laid out the example in code and words, I think if I take each part one at a time, I can figure out, how to snap them together to make multiple if... Guess I've just been 'spoiled' by if {block if {block}} ! 2 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 5, 2021 Share Posted August 5, 2021 So, it seems that I owe this thread a debt of gratitude ...for helping me notice the not-so-much a bug, as more of a logic error. I was under the impression that leap year came every 3 years! ADV9 CLR R3 MOVB @PTM+12,R3 SWPB R3 INC R3 CI R3,>34 JNE NEXT6 LI R3,>0030 NEXT6 SWPB R3 MOVB R3,@PTM+12 So, before... the program worked correctly, but was wrong! Whereas now... the program works wrongly, but is correct. All done. 2 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted August 5, 2021 Share Posted August 5, 2021 8 hours ago, dhe said: I think if I take each part one at a time, I can figure out, how to snap them together to make multiple if... see post #6 if you are aiming for IF/THEN statements. 1 Quote Link to comment Share on other sites More sharing options...
SteveB Posted August 6, 2021 Share Posted August 6, 2021 On 8/5/2021 at 3:42 AM, senior_falcon said: 20 LY=((Y AND 3)>0)-((Y/100)<>INT(Y/100))-((Y/400)=INT(Y/400)) very elegant! I fell in love with those boolean expressions when a friend of my father showed it to me back in 1983 .. often much faster than IF-THEN. But I didn't know the "AND" trick for MOD. I guess I have to update my TiCodEd Standard-Library, currently sub mod(n,d,m) m = n - int(n/d) * d subend The AND calculation takes only one third of the time. Talking of IF-THEN, we did not really answer the original question this way... 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted August 6, 2021 Share Posted August 6, 2021 Guess I need to add MOD(number,divisor,remainder) to RXB in Assembly ROMs. NUMBER=5 DIVISOR=2 REMAINDER=1 or NUMBER=23 DIVISOR=7 REMAINDER=2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 6, 2021 Share Posted August 6, 2021 27 minutes ago, RXB said: Guess I need to add MOD(number,divisor,remainder) to RXB in Assembly ROMs. NUMBER=5 DIVISOR=2 REMAINDER=1 or NUMBER=23 DIVISOR=7 REMAINDER=2 Out of curiosity, is it not possible to make MOD an operator like AND and OR? Doing so you could have a proper statement of 2021 MOD 4, &c. Quote Link to comment Share on other sites More sharing options...
RXB Posted August 6, 2021 Share Posted August 6, 2021 52 minutes ago, OLD CS1 said: Out of curiosity, is it not possible to make MOD an operator like AND and OR? Doing so you could have a proper statement of 2021 MOD 4, &c. NO unlike others 2 parameters are needed and returns one the remainder. I guess MIN(low,high) or MAX(high,low) could be used instead. So you would need to assign a variable: X=MOD(number,divisor) X would be the result like X would equal 2 for X=MOD(23,7) Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 7, 2021 Share Posted August 7, 2021 4 hours ago, RXB said: NO unlike others 2 parameters are needed and returns one the remainder. I guess MIN(low,high) or MAX(high,low) could be used instead. So you would need to assign a variable: X=MOD(number,divisor) X would be the result like X would equal 2 for X=MOD(23,7) Rich if you are going to add MOD you might want a DIV function too, that returns two values, the dividend and the remainder. Forth uses this and it is baked in to the 9900 DIV instruction anyway. Just a thought. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted August 7, 2021 Share Posted August 7, 2021 7 hours ago, TheBF said: ... you might want a DIV function too, that returns two values, the dividend and the remainder. That would be the quotient and the remainder. ? ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 7, 2021 Share Posted August 7, 2021 1 hour ago, Lee Stewart said: That would be the quotient and the remainder. ? ...lee Yes it would. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
SteveB Posted August 7, 2021 Share Posted August 7, 2021 14 hours ago, RXB said: So you would need to assign a variable: X=MOD(number,divisor) X would be the result like X would equal 2 for X=MOD(23,7) Rich, would you need a new token for this? 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted August 7, 2021 Share Posted August 7, 2021 3 hours ago, Lee Stewart said: That would be the quotient and the remainder. ? For quite a while I believed that "rational numbers" got their name because they were in some sense "good", "understandable", while the "irrational numbers" were the opposite. But rational numbers are merely those that can be expressed by a ratio (a/b). Often, the simpler explanation is the better one. 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted August 7, 2021 Share Posted August 7, 2021 2 hours ago, SteveB said: Rich, would you need a new token for this? We have a ton of free tokens in XB: Spoiler *********************************************************** * BASIC KEYWORD TABLE * THE TOKEN IS ITS LEFT BINDING POWER *********************************************************** KEYTAB DATA CHAR1,CHAR2,CHAR3,CHAR4,CHAR5 DATA CHAR6,CHAR7,CHAR8,CHAR9,CHARA CHAR1 TEXT '!' BYTE TREMZ * ! TEXT '#' BYTE NUMBEZ * # TEXT '&' BYTE CONCZ * & TEXT '(' BYTE LPARZ * ( TEXT ')' BYTE RPARZ * ) TEXT '*' BYTE MULTZ * * TEXT '+' BYTE PLUSZ * + TEXT ',' BYTE COMMAZ * , TEXT '-' BYTE MINUSZ * - TEXT '/' BYTE DIVIZ * / TEXT ':' BYTE COLONZ * : TEXT ';' BYTE SEMICZ * ; TEXT '<' BYTE LESSZ * < TEXT '=' BYTE EQUALZ * = TEXT '>' BYTE GREATZ * > TEXT '^' BYTE CIRCUZ * ^ BYTE >FF CHAR2 TEXT '::' BYTE SSEPZ * :: TEXT 'AT' BYTE ATZ * AT TEXT 'GO' BYTE GOZ * GO * RXB MOTION TEXT 'IF' BYTE IFZ * IF TEXT 'ON' BYTE ONZ * ON * RXB ONKEY TEXT 'OR' BYTE ORZ * OR TEXT 'PI' BYTE PIZ * PI TEXT 'TO' BYTE TOZ * TO BYTE >FF CHAR3 TEXT 'ABS' BYTE ABSZ * ABS TEXT 'ALL' BYTE ALLZ * ALL TEXT 'AND' BYTE ANDZ * AND TEXT 'ASC' BYTE ASCZ * ASC TEXT 'ATN' BYTE ATNZ * ATN TEXT 'BYE' BYTE >03 * BYE TEXT 'CON' BYTE >01 * CONtinue TEXT 'COS' BYTE COSZ * COS TEXT 'DEF' BYTE DEFZ * DEF * GKXB added token TEXT 'DEL' BYTE >09 * DEL TEXT 'DIM' BYTE DIMZ * DIM TEXT 'END' BYTE ENDZ * END TEXT 'EOF' BYTE EOFZ * EOF TEXT 'EXP' BYTE EXPZZ * EXP TEXT 'FOR' BYTE FORZ * FOR TEXT 'INT' BYTE INTZ * INT TEXT 'LEN' BYTE LENZ * LEN TEXT 'LOG' BYTE LOGZ * LOG TEXT 'MAX' BYTE MAXZ * MAX TEXT 'MIN' BYTE MINZ * MIN TEXT 'NEW' BYTE >00 * NEW * RXB CALL NEW TEXT 'NOT' BYTE NOTZ * NOT TEXT 'NUM' BYTE >04 * NUMber TEXT 'OLD' BYTE >05 * OLD * RXB SAMS TEXT 'POS' BYTE POSZ * POS TEXT 'REC' BYTE RECZ * REC TEXT 'REM' BYTE REMZ * REMark TEXT 'RES' BYTE >06 * RESequence TEXT 'RND' BYTE RNDZ * RND * RXB CHANGED TEXT 'RUN' BYTE RUNZ * RUN * RXB SAMS TEXT 'SGN' BYTE SGNZZ * SGN TEXT 'SIN' BYTE SINZ * SIN TEXT 'SQR' BYTE SQRZ * SQR TEXT 'SUB' BYTE SUBZ * SUB TEXT 'TAB' BYTE TABZ * TAB TEXT 'TAN' BYTE TANZ * TAN TEXT 'VAL' BYTE VALZ * VAL TEXT 'XOR' BYTE XORZ * XOR BYTE >FF CHAR4 TEXT 'BASE' BYTE BASEZ * BASE TEXT 'BEEP' BYTE BEEPZ * BEEP TEXT 'CALL' BYTE CALLZ * CALL TEXT 'CHR$' BYTE CHRZZ * CHR$ * GKXB added token TEXT 'COPY' BYTE >0A * COPY TEXT 'DATA' BYTE DATAZ * DATA TEXT 'ELSE' BYTE ELSEZ * ELSE TEXT 'GOTO' BYTE GOTOZ * GOTO * RXB ONKEY TEXT 'LIST' BYTE >02 * LIST * GKXB added token TEXT 'MOVE' BYTE >0B * MOVE TEXT 'NEXT' BYTE NEXTZ * NEXT TEXT 'OPEN' BYTE OPENZ * OPEN TEXT 'READ' BYTE READZ * READ TEXT 'RPT$' BYTE RPTZZ * RPT$ TEXT 'SAVE' BYTE >07 * SAVE * RXB SAVE IV254 TEXT 'SEG$' BYTE SEGZZ * SEG$ TEXT 'SIZE' BYTE SIZEZ * SIZE * RXB CALL SIZE TEXT 'STEP' BYTE STEPZ * STEP TEXT 'STOP' BYTE STOPZ * STOP * RXB MOTION TEXT 'STR$' BYTE STRZZ * STR$ TEXT 'THEN' BYTE THENZ * THEN BYTE >FF CHAR5 TEXT 'BREAK' BYTE BREAKZ * BREAK TEXT 'CLOSE' BYTE CLOSEZ * CLOSE TEXT 'DIGIT' BYTE DIGITZ * DIGIT TEXT 'ERASE' BYTE ERASEZ * ERASE TEXT 'ERROR' BYTE ERRORZ * ERROR TEXT 'FIXED' BYTE FIXEDZ * FIXED TEXT 'GOSUB' BYTE GOSUBZ * GOSUB TEXT 'IMAGE' BYTE IMAGEZ * IMAGE TEXT 'INPUT' BYTE INPUTZ * INPUT TEXT 'MERGE' BYTE >08 * MERGE TEXT 'PRINT' BYTE PRINTZ * PRINT TEXT 'TRACE' BYTE TRACEZ * TRACE TEXT 'USING' BYTE USINGZ * USING BYTE >FF CHAR6 TEXT 'ACCEPT' BYTE ACCEPZ * ACCEPT TEXT 'APPEND' BYTE APPENZ * APPEND TEXT 'DELETE' BYTE DELETZ * DELETE TEXT 'LINPUT' BYTE LINPUZ * LINPUT TEXT 'NUMBER' BYTE >04 * NUMBER TEXT 'OPTION' BYTE OPTIOZ * OPTION TEXT 'OUTPUT' BYTE OUTPUZ * OUTPUT TEXT 'RETURN' BYTE RETURZ * RETURN TEXT 'SUBEND' BYTE SUBNDZ * SUBEND TEXT 'UALPHA' BYTE UALPHZ * UALPHA TEXT 'UPDATE' BYTE UPDATZ * UPDATE BYTE >FF CHAR7 TEXT 'DISPLAY' BYTE DISPLZ * DISPLAY TEXT 'NUMERIC' BYTE NUMERZ * NUMERIC TEXT 'RESTORE' BYTE RESTOZ * RESTORE TEXT 'SUBEXIT' BYTE SUBXTZ * SUBEXIT TEXT 'UNBREAK' BYTE UNBREZ * UNBREAK TEXT 'UNTRACE' BYTE UNTRAZ * UNTRACE TEXT 'WARNING' BYTE WARNZ * WARNING BYTE >FF CHAR8 TEXT 'CONTINUE' BYTE >01 * CONTINUE TEXT 'INTERNAL' BYTE INTERZ * INTERNAL TEXT 'RELATIVE' BYTE RELATZ * RELATIVE TEXT 'VALIDATE' BYTE VALIDZ * VALIDATE TEXT 'VARIABLE' BYTE VARIAZ * VARIABLE BYTE >FF CHAR9 TEXT 'RANDOMIZE' BYTE RANDOZ * RANDOMIZE BYTE >FF CHARA TEXT 'SEQUENTIAL' BYTE SEQUEZ * SEQUENTIAL BYTE >FF *********************************************************** Currently token symbols not assigned: >80, >AB, >AC, >AD, >AE, >AF, >B9, >C6, >E2, >E3, >E4, >E5, >E6, >E7, >F2 So I would pick >AB for MOD and >AC for DIV Quote Link to comment Share on other sites More sharing options...
SteveB Posted August 7, 2021 Share Posted August 7, 2021 4 minutes ago, RXB said: So I would pick >AB for MOD and >AC for DIV As I try to keep TiCodEd RXB-compatible I would need to add them as well in my tokenizer. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted August 7, 2021 Share Posted August 7, 2021 22 minutes ago, SteveB said: As I try to keep TiCodEd RXB-compatible I would need to add them as well in my tokenizer. No rush RXB 2021 is a long way off. Quote Link to comment Share on other sites More sharing options...
