zoo237 Posted August 14, 2021 Share Posted August 14, 2021 I got this old Colecovision from Creig’s list which is pretty dirt, controlle is fine, everything works perfect as it should except the joystick which only works if I push it to the right SOMETIMES if I’m playing a game and push the controller to the left hard enough it might make my character move slightly to the left, the other directions don’t work at all Here’s what the inside looks like Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted August 15, 2021 Share Posted August 15, 2021 The contacts under the directional guide may be corroded. Try some deoxit to see if it improves any when you push a contact down. If so, and if it's still not good enough, you may have to de-solder the top part and then scrub both the underside and the contact nub below it with contact cleaner until both are shiny again. Quote Link to comment Share on other sites More sharing options...
nick3092 Posted August 16, 2021 Share Posted August 16, 2021 If you don't want to desolder or don't have the tools to do so, I've come up with an alternate method that works pretty good. I take some card stock and cutting it into thin strips to fit under the tabs, spraying Deoxit under those tabs, putting the strip under the tab, push down in the tab with my finger, and pull the strip out. Keep repeating the process till no more black marks appear on the strips on both sides. Card stock is thick enough that it doesn't tear easily when wet. And the paper fibers act like an extremely mild abrasive for helping mechanically clean the contacts along with the deoxit. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted August 16, 2021 Share Posted August 16, 2021 6 hours ago, ChildOfCv said: The contacts under the directional guide may be corroded. Try some deoxit to see if it improves any when you push a contact down. If so, and if it's still not good enough, you may have to de-solder the top part and then scrub both the underside and the contact nub below it with contact cleaner until both are shiny again. I actually take this a slight step further. I use my fiberglass pen to rough up the rivet contacts. Then I apply a layer of solder over them. Doing that and cleaning up the underside of the spring pad and they are likely good to go for life. Just have to be careful not to apply too much solder as if it domes up too much it will make contact all the time and cause the spring pad to crack from the added pressure. So I just make sure to apply a thing layer that is as flat as I can get it. Quote Link to comment Share on other sites More sharing options...
