Help with what mods I have
Brockmd
5 hours ago, Nezgar said:
Since one is likely "onmimon" the "80C" is likely Omniview.
Anyway I can confirm this? Any info on these mods?
xl boss is confirmed. I will try to load the website at home. My phone can’t handle it and work computer gives me the “bad boy” for trying to access. ☹️
Well, there's two ways to confirm:
1. Extract the EPROMs and read out the contents using an EPROM programmer. Compare the resulting dump to known OS's, CRC32 checksum etc.
2. Run an OS dumping utility from the Atari under each OS, save the data to a file. There is such a tool inlcuded with RealDOS, as well as one included with WUDSN ROM checker: http://www.wudsn.com/index.php/productions-atari800/tools/atariromchecker
Either way then use some method such as SIO2PC-USB or an SD card card solution to get the resulting files to a PC for analysis / upload (ie to here :) )
The manuals for Omnimon/Omniview are available at archive.org:\
https://archive.org/details/NewellIndustriesOmnimonOmniviewManual/mode/2up
