jblenkle Posted September 5, 2021 Share Posted September 5, 2021 OK, so I am starting with a b/w .BMP picture and use the program BMP2PP to convert it to ADAM's PowerPaint format. When I load it into PowerPaint, however, it becomes colorized. Does anyone know why it's doing this? I want it to stay b/w. Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted September 5, 2021 Share Posted September 5, 2021 Not sure what you're expecting here, but the ADAM only has 15 different colors, and only three "non-color" colors, namely black, white and gray, and the gray happens to be very close to white. If you submit a picture with too many shades of grey, it's going to start using other colors like blue to "simulate" darker shades of grey, and yellows/greens for lighter shades of grey where grey and white are too light to match. What you need is a picture converter that does dithering. Not sure if that exists on the ADAM. 1 Quote Link to comment Share on other sites More sharing options...
jblenkle Posted September 8, 2021 Author Share Posted September 8, 2021 On 9/5/2021 at 5:12 AM, Pixelboy said: Not sure what you're expecting here, but the ADAM only has 15 different colors, and only three "non-color" colors, namely black, white and gray, and the gray happens to be very close to white. If you submit a picture with too many shades of grey, it's going to start using other colors like blue to "simulate" darker shades of grey, and yellows/greens for lighter shades of grey where grey and white are too light to match. What you need is a picture converter that does dithering. Not sure if that exists on the ADAM. BMP2PP has dithering settings, but I'm not 100% sure exactly what "dithering" does. I have lowered the default settings to get rid of garbage in color pictures, but I'm not sure what this would do for black and white pictures. And yes, I has hoping for different shapes of gray, not just black, white and one shade of gray. But I gather from other responses on Facebook that this just isn't possible. Quote Link to comment Share on other sites More sharing options...
youki Posted September 8, 2021 Share Posted September 8, 2021 you can not have shade of gray on ADAM. There is only one gray. But will BMP2PP , make sure to select the ADAM Palette (not the colecovision one, not the msx one and not the Black&White one) in dithering method choose "both passes" then start the conversion . The result should something like that the attached image. If you choose "black & white" as palette, you will have a better result in the tool but it WON'T work on ADAM because it is for a different VDP version that the ADAM does not have. Quote Link to comment Share on other sites More sharing options...
jblenkle Posted September 11, 2021 Author Share Posted September 11, 2021 On 9/8/2021 at 9:54 AM, youki said: you can not have shade of gray on ADAM. There is only one gray. But will BMP2PP , make sure to select the ADAM Palette (not the colecovision one, not the msx one and not the Black&White one) in dithering method choose "both passes" then start the conversion . The result should something like that the attached image. If you choose "black & white" as palette, you will have a better result in the tool but it WON'T work on ADAM because it is for a different VDP version that the ADAM does not have. Thanks for that info...I will have to experiment more... Quote Link to comment Share on other sites More sharing options...
jblenkle Posted September 11, 2021 Author Share Posted September 11, 2021 3 minutes ago, jblenkle said: Thanks for that info...I will have to experiment more... On 9/8/2021 at 9:54 AM, youki said: you can not have shade of gray on ADAM. There is only one gray. But will BMP2PP , make sure to select the ADAM Palette (not the colecovision one, not the msx one and not the Black&White one) in dithering method choose "both passes" then start the conversion . The result should something like that the attached image. If you choose "black & white" as palette, you will have a better result in the tool but it WON'T work on ADAM because it is for a different VDP version that the ADAM does not have. But will BMP2PP , make sure to select the ADAM Palette (not the colecovision one, not the msx one and not the Black&White one) My BMP2PP doesn't have those palette options...it has: * Original * V9938 * Original/black and white *V9938/black and white Quote Link to comment Share on other sites More sharing options...
jblenkle Posted September 11, 2021 Author Share Posted September 11, 2021 On 9/8/2021 at 9:54 AM, youki said: you can not have shade of gray on ADAM. There is only one gray. But will BMP2PP , make sure to select the ADAM Palette (not the colecovision one, not the msx one and not the Black&White one) in dithering method choose "both passes" then start the conversion . The result should something like that the attached image. If you choose "black & white" as palette, you will have a better result in the tool but it WON'T work on ADAM because it is for a different VDP version that the ADAM does not have. OK, this is kind of discouraging after all the work I've been doing on these. I've been using v1.0 of BMP2PP. I just discovered there is a v1.1 and there is a distinct difference in the quality it produces. Quote Link to comment Share on other sites More sharing options...
youki Posted September 11, 2021 Share Posted September 11, 2021 yes, indeed, i use the v1.1 , i was not aware of other version. I use the same Bmp2PP since 2008! Quote Link to comment Share on other sites More sharing options...
NIAD Posted September 11, 2021 Share Posted September 11, 2021 8 hours ago, jblenkle said: OK, this is kind of discouraging after all the work I've been doing on these. I've been using v1.0 of BMP2PP. I just discovered there is a v1.1 and there is a distinct difference in the quality it produces. It’s the “Fun of Discovery” that Coleco loved to use in their game manuals especially when mixing old and modern platforms to get the job done. Quote Link to comment Share on other sites More sharing options...
jblenkle Posted September 12, 2021 Author Share Posted September 12, 2021 On 9/11/2021 at 8:35 AM, NIAD said: It’s the “Fun of Discovery” that Coleco loved to use in their game manuals especially when mixing old and modern platforms to get the job done. Actually, the improved quality only extends to the preview picture. The actual quality of the finished PP picture isn't that much better and is probably due to the BMP2PP Dithering settings which are set slightly different in v1.1 than I have them set in v1.0. Quote Link to comment Share on other sites More sharing options...
