Zuluop
Stained SNES PCB - is this normal?
Just bought this (see attachments) SNES cart off eBay. However opening the cartridge revealed a stained backside of the PCB. Any idea if this is normal or have you seen this before?
as you can see the front side of the PCB looks good.
Thanks ūüôā
If it works fine I wouldn't worry about it. Though I would change the battery.
Edited by DragonGrafx-16
Yeah I would like to change the battery (on several SNES games) but it has been 30 years since I used a soldering iron. So what would i need to buy aside from the correct battery of course? Links to specific items would be great.
(Note: The plan is to practice soldering first before doing it on the actual SNES PCBs)
Thanks in advance :)
14 hours ago, Steven Pendleton said:
Probably flux residue.
Yeah you are probably right - should I remove it with 99% isopropyl alcohol?
I don't know. I've never dealt with it. I just know that it exists, my SuperGrafx's motherboard is covered in it, and that's probably what it is. Not sure if that's a bad thing or not, but I should probably clean my SuperGrafx motherboard.
I agree to leave it as is. I've had plenty of PCB boards (including Genesis boards, SNES, and TG16) boards that have had that residue on it as well. I tried cleaning the Genesis board with alcohol and it caused a permanet white residue to show up and it made it look even worse.
I use a rather cheap soldering iron for replacing CMOS batteries and it works great. Here is a link to it.
https://www.amazon.com/Weller-WLC100-40-Watt-Soldering-Station/dp/B000AS28UC/ref=sr_1_29?dchild=1&keywords=soldering+iron&qid=1631207349&refinements=p_72%3A1248909011&rnid=1248907011&s=hi&sr=1-29
Great thanks - what else is needed aside from the battery pack? What kind of tin is needed and if anything else?
Thanks again.
I never bother with battery holders in my cartridge games. When would you even change the battery next? In 25 years?
Nah I came to the same conclusion :) Would rather re-solder in 25 years if needed.
Yeah and with a battery holder there is a chance the battery would come loose and you lose your save data.
Would you solder with lead or without lead in the tin?
19 minutes ago, DragonGrafx-16 said:
Either should work.
Hehe ok, since it has been 25 years since I last did it I might as well use lead free tin even though it may be more difficult :)
√ó
√ó
