Sign in to follow this
Mariano DM
Synassembler and SpartaDOS
Hello, I'm having this problem both in emulator and real Atari (Rambo 320 and U1M respectively)
I can boot syn assembler with X or X /C
but I cannot save the binary or the code after I assemble.
Do I need to change my CONFIG.SYS ?, I'm using the one in SIDE2
Edited by Mariano DM
image size
I'm not sure, but the SpartaDOS X manual lists error 150 as "150  Sparta:  Directory  not  found"
Maybe try variations like
D1:STACK.ASM
1:STACK.ASM
D1:>STACK.ASM
1:STACK.ASM
Or other devices like E: P: C :
No end " might help in spartados.
So "D:FILE.DAT
Not sure whether that was it... but I remember the issue.
The "Image" in the first post is not visible (at least for me). So I am not sure what version of SDX is this.
There was a problem with pathname end detection before, but it should be fixed as of 4.49e. Generally the problem is that path and file names should be EOL-terminated, but many programs neglect the termination, assuming that the DOS will be magically able to detect the end of a file name, no matter what binary garbage follows. Before 4.49e this magic sometimes led the DOS to believe that what follows is a path separator, and (consequently) that the file name given is a directory name. Thus error 150 "Path not found".
As I said, the magic should get improved as of 4.49e. If it still fails, a test case would be most appreciated.
