Sign in to follow this
philgood1351fr
Atari 130 XE Ram Problems
Hi, checked what have already been discussed here with no luck so I ask you my friends for advices....
My 130 XE always boots on Memory test. the 2 ROMS are OK, but RAM is all red except 4. Unsoldered the 8 chips, put supports then tried with differents chips according to what I read here in past topics.
Tried with KM 4164-B-10, TMM 41256AP-12, TMS4164-20NL chips but no luck (same results on tests).
Diodes are all ok (5v).
Tried to swap 1st 64 bank with 2nd 64 bank by crossing resistors R110 and R111 but black screen.
Anyone can help on this ? Are my replacement chips are the good ones ?
I checked the MT4264 voltage, and notice that I have 5v on some pins and 3.6 on some other. Even 1 pin (pin 3 or 4 that have 1.9 and this one has a dropping voltage during the Ram test). Anyone have the correct voltage for each memory pin ?
Thanks for your advices.
Phil
Edited by philgood1351fr
The only pin guaranteed to have +5V on it is pin 8, the power supply pin,
all the others are switching on and off at different speeds hence the varying voltages you are seeing.
You will not be able to measure voltages on any of these pins with a voltmeter, you need a scope.
Could be an MMU problem or Freddie chip
Edited by TGB1718
only the very late 800XLs were made using the Freddie chip, then all the XEs
Yup, far as I am aware only the Atari 800XLF boards and then XE models have s Freddie chip.
4 hours ago, philgood1351fr said:
Right. Thanks.
I bought the DRAM tester and the Freddie Chip.
@philgood1351frCool. Make sure with the DRAM tester (if you bought the one I linked to above), that you read the instructions and test DRAMs the right hand socket. If you put them in the left one you can fry the likes of 4164 and 4264 chips, etc. I taped over the left socket to stop any accidental usage. (Just don't trust myself). The only instructions you get on that Ebay link is in the listings - they don't include them with the unit.
Great re Freddie chip.
good luck
Yes, I printed the manual on Ebay. And I saw the difference between left and right test pins.
Pretty sure I'll put a blank scotch over the left one too as I mainly tests 5v chips....
here is the complete manual if needed.
Thanks.
DRAM_Tester_UserGuide.pdf
