myriadcs
Fujinet Bridcked?
Today I set up new environment, I've built new firmware
commit 7f0dca365a658c50bdccc746b5ba0f26338277f0 (HEAD -> master, origin/master, origin/HEAD)
Merge: dfc7374e 2d0c9e5d
flashed and now my Fujinet is not working.
When I connect USB cable all 3 leds blinks and go dark. FN is no longer recognized by computer.
I bought that while ago and *I think* it's 1.3 hardware revision. ESP32 itself has following details:
ESP-WROVER-B
XX0H28
Here is flashing log:
Building in debug mode
Retrieving maximum program size .pio/build/fujinet-v1-8mb/firmware.elf
Checking size .pio/build/fujinet-v1-8mb/firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM:   [==        ]  21.6% (used 70764 bytes from 327680 bytes)
Flash: [===       ]  30.7% (used 1911213 bytes from 6225920 bytes)
Configuring upload protocol...
AVAILABLE: esp-prog, espota, esptool, ftdi, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esptool
Looking for upload port...
Use manually specified: /dev/ttyUSB0
Uploading .pio/build/fujinet-v1-8mb/firmware.bin
esptool.py v3.1
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32-D0WD (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: b8:f0:09:89:d1:78
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 16MB
Flash will be erased from 0x00001000 to 0x00007fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x001e2fff...
Flash params set to 0x0240
Compressed 27536 bytes to 16762...
Writing at 0x00001000... (50 %)
Writing at 0x00007979... (100 %)
Wrote 27536 bytes (16762 compressed) at 0x00001000 in 0.5 seconds (effective 467.9 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 117...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (117 compressed) at 0x00008000 in 0.0 seconds (effective 532.7 kbit/s)...
Compressed 8192 bytes to 31...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (31 compressed) at 0x0000e000 in 0.1 seconds (effective 717.2 kbit/s)...
Compressed 1911344 bytes to 1100164...
Writing at 0x00010000... (1 %)
Writing at 0x00019da2... (2 %)
Writing at 0x000294db... (4 %)
Writing at 0x00032cf1... (5 %)
Writing at 0x0003cff3... (7 %)
Writing at 0x000463f0... (8 %)
Writing at 0x000539ae... (10 %)
Writing at 0x00064890... (11 %)
Writing at 0x00070023... (13 %)
Writing at 0x00075f05... (14 %)
Writing at 0x0007bf1a... (16 %)
Writing at 0x00082752... (17 %)
Writing at 0x00089d19... (19 %)
Writing at 0x0008fe6a... (20 %)
Writing at 0x00095e26... (22 %)
Writing at 0x0009b70c... (23 %)
Writing at 0x000a1679... (25 %)
Writing at 0x000a79c1... (26 %)
Writing at 0x000ae887... (27 %)
Writing at 0x000b4a03... (29 %)
Writing at 0x000ba744... (30 %)
Writing at 0x000c015b... (32 %)
Writing at 0x000c6073... (33 %)
Writing at 0x000cbc64... (35 %)
Writing at 0x000d19ce... (36 %)
Writing at 0x000d7b45... (38 %)
Writing at 0x000dd9e8... (39 %)
Writing at 0x000e3bf4... (41 %)
Writing at 0x000ea691... (42 %)
Writing at 0x000f05e8... (44 %)
Writing at 0x000f61b3... (45 %)
Writing at 0x000fbb67... (47 %)
Writing at 0x001018ab... (48 %)
Writing at 0x00106a46... (50 %)
Writing at 0x0010be60... (51 %)
Writing at 0x001112b6... (52 %)
Writing at 0x0011697e... (54 %)
Writing at 0x0011be14... (55 %)
Writing at 0x001216b4... (57 %)
Writing at 0x0012724e... (58 %)
Writing at 0x0012d14a... (60 %)
Writing at 0x00134b36... (61 %)
Writing at 0x0013d4ae... (63 %)
Writing at 0x00144e03... (64 %)
Writing at 0x0014bd5d... (66 %)
Writing at 0x00151d49... (67 %)
Writing at 0x00158757... (69 %)
Writing at 0x0015ed77... (70 %)
Writing at 0x00165d9d... (72 %)
Writing at 0x0016c9b9... (73 %)
Writing at 0x00173147... (75 %)
Writing at 0x0017907c... (76 %)
Writing at 0x00181ce9... (77 %)
Writing at 0x00187ecd... (79 %)
Writing at 0x0018dfe7... (80 %)
Writing at 0x0019477a... (82 %)
Writing at 0x0019a408... (83 %)
Writing at 0x001a07fa... (85 %)
Writing at 0x001a770d... (86 %)
Writing at 0x001af5f2... (88 %)
Writing at 0x001b6306... (89 %)
Writing at 0x001bde77... (91 %)
Writing at 0x001c549a... (92 %)
Writing at 0x001caab7... (94 %)
Writing at 0x001d08d7... (95 %)
Writing at 0x001d5fd1... (97 %)
Writing at 0x001db74b... (98 %)
Writing at 0x001e1997... (100 %)
Wrote 1911344 bytes (1100164 compressed) at 0x00010000 in 17.1 seconds (effective 893.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
============================================================================ [SUCCESS] Took 42.21 seconds ============================================================================
Environment     Status    Duration
fujinet-v1-8mb  SUCCESS   00:00:42.212
============================================================================ 1 succeeded in 00:00:42.212 ============================================================================
I guess soldering in JTAG connector and flashing via that is only option now?
Looks like it was loose cable. I managed to get it recognized and flashed again.
16:09:25.150 > FujiNet 0.5.d5ab7817 2021-09-13 22:48:24 Started @ 5
16:09:25.150 > Starting heap: 4113035
16:09:25.150 > PsramSize 3918339
16:09:25.150 > himem phys 4456448
16:09:25.150 > himem free 4456448
16:09:25.152 > himem reserved 262144
16:09:25.182 > Detected Hardware Version: 1.0
16:09:25.182 > E (708) SPIFFS: mount failed, -10025
16:09:25.184 > Failed to mount SPIFFS partition, err = -1
16:09:25.245 > SD mounted.
16:09:25.245 > fnConfig::load
16:09:25.247 > Load fnconfig.ini from SD
16:09:25.252 > fnConfig::load read 938 bytes from config file
16:09:25.255 > Config file dosn't exist on SPIFFS
16:09:25.255 > Copying SD config file to SPIFFS
16:09:25.257 > copy_file "/fnconfig.ini" -> "/fnconfig.ini"
16:09:25.257 > copy_file failed to open destination
16:09:25.258 > copy_file copied 0 bytes
16:09:25.258 > Failed to copy config from SD
16:09:25.368 > WIFI_EVENT_STA_START
16:09:25.368 > WiFi connect attempt to SSID "MyNetwork"
16:09:25.368 > esp_wifi_connect returned 0
16:09:25.368 > disk UNMOUNT
16:09:25.368 > disk MOUNT
16:09:25.368 > ATR MOUNT
16:09:25.368 > Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
16:09:25.370 >
16:09:25.370 > Core  0 register dump:
16:09:25.370 > PC      : 0x401ff180  PS      : 0x00060930  A0      : 0x801ff13d  A1      : 0x3ffb2fd0
16:09:25.371 > A2      : 0x3ffb3260  A3      : 0x00000000  A4      : 0x00000000  A5      : 0x00000000
16:09:25.372 > A6      : 0x3ff96458  A7      : 0xff000000  A8      : 0x801ff180  A9      : 0x3ffb2fb0
16:09:25.373 > A10     : 0x00000000  A11     : 0x3ffb300c  A12     : 0x0000000a  A13     : 0x3ffcb190
16:09:25.374 > A14     : 0x00000000  A15     : 0x00000000  SAR     : 0x00000017  EXCCAUSE: 0x0000001c
16:09:25.375 > EXCVADDR: 0x00000064  LBEG    : 0x4008e221  LEND    : 0x4008e231  LCOUNT  : 0xfffffffd
16:09:25.376 >
16:09:25.376 > Backtrace:0x401ff17d:0x3ffb2fd0 0x401ff13a:0x3ffb3040 0x400ed48d:0x3ffb3060 0x400ed18a:0x3ffb3090 0x400db276:0x3ffb30b0 0x400db570:0x3ffb30d0 0x400d3e86:0x3ffb30f0 0x400d3f8f:0x3ffb3110 0x4022aa8b:0x3ffb3140 0x400953f1:0x3ffb3160
16:09:25.583 >   #0  0x401ff17d:0x3ffb2fd0 in _fseeko_r at /builds/idf/crosstool-NG/.build/xtensa-esp32-elf/src/newlib/newlib/libc/stdio/fseeko.c:116 (discriminator 14)
16:09:25.583 >   #1  0x401ff13a:0x3ffb3040 in _fseek_r at /builds/idf/crosstool-NG/.build/xtensa-esp32-elf/src/newlib/newlib/libc/stdio/fseek.c:89
16:09:25.583 >       (inlined by) fseek at /builds/idf/crosstool-NG/.build/xtensa-esp32-elf/src/newlib/newlib/libc/stdio/fseek.c:99
16:09:25.583 >   #2  0x400ed48d:0x3ffb3060 in DiskTypeATR::mount(__sFILE*, unsigned int) at lib/sio/diskTypeAtr.cpp:195
16:09:25.583 >   #3  0x400ed18a:0x3ffb3090 in sioDisk::mount(__sFILE*, char const*, unsigned int, disktype_t) at lib/sio/disk.cpp:239
16:09:25.583 >   #4  0x400db276:0x3ffb30b0 in sioFuji::insert_boot_device(unsigned char) at lib/sio/fuji.cpp:1480
16:09:25.583 >   #5  0x400db570:0x3ffb30d0 in sioFuji::setup(sioBus*) at lib/sio/fuji.cpp:1500
16:09:25.583 >   #6  0x400d3e86:0x3ffb30f0 in main_setup() at src/main.cpp:108
16:09:25.583 >   #7  0x400d3f8f:0x3ffb3110 in app_main at src/main.cpp:171
16:09:25.583 >   #8  0x4022aa8b:0x3ffb3140 in main_task at /home/user/.platformio/packages/framework-espidf/components/freertos/port/port_common.c:133 (discriminator 2)
16:09:25.583 >   #9  0x400953f1:0x3ffb3160 in vPortTaskWrapper at /home/user/.platformio/packages/framework-espidf/components/freertos/port/xtensa/port.c:168
16:09:25.583 >
16:09:25.583 >
16:09:25.583 > ELF file SHA256: e3819770e4ba2b10
16:09:25.583 >
16:09:25.583 > Rebooting...
It says Hardware Version 1.0 and indeed that's what it's on board but i think it's already modified with some fixes. There is resistor on SIO connector
It's not working but at least something is working, need to figure out what is missing now :)
so I guess something with SPIFFS partition is not ok (or it's wrong assumption?)
This time I've used Official Flasher and Downloaded firmware, it flashed ok with different error in logs :)
[16:35:18]ets Jun  8 2016 00:22:57
[16:35:18]
[16:35:18]rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[16:35:18]configsip: 0, SPIWP:0xee
[16:35:18]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[16:35:18]mode:DIO, clock div:2
[16:35:18]load:0x3fff0018,len:4
[16:35:18]load:0x3fff001c,len:1044
[16:35:18]load:0x40078000,len:8896
[16:35:18]load:0x40080400,len:5828
[16:35:18]entry 0x400806ac
FN is sensitive to the USB cable quality - it's a connoisseur and wont tolerate riff-raff spec! 😁
  • Haha 2
I find that Micro USB cables are one of the most unreliable connections, I have tons of broken one, half-broken and just ephemeral broken...
54 minutes ago, myriadcs said:
@tschak909 I flash latest firmware (built from git head) and get an error like in post 2. Any idea what I may be missing?
In post 1 it shows you are building for hardware fujinet-v1-8mb. If this is not custom built hardware you should pick fujinet-v1.
I don't think the message in post 3 is an error, it's the bootloader messages. Bootloader messages are displayed at 115200 baud and fujinet debug output at 921600.
6 minutes ago, myriadcs said:
I've built regular fujinet-v1 and it's exactly same error
Ok, lets try to eliminate the plaformio problems and use fujinet flasher to update the device. After flashing it with fujinet flasher, what debug output does it show and what do the 3 leds do?
Spoiler
Please paste your debug output into a spoiler tag (eye icon) so it doesn't fill up the page.
When I click Flash ESP I got an error
Using '/dev/ttyUSB0' as serial port.
Unexpected error: expected str, bytes or os.PathLike object, not NoneType
I think It should download latest firmware itself, right? I can download one of Firmware from https://fujinet.online/firmware-dl/ but which one? firmware.bin?
Spoiler
$ Downloads/ESPHome-Flasher-1.3.0-Ubuntu-x64.exec
/usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so: undefined symbol: g_task_set_name
Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
Fontconfig warning: "/etc/fonts/fonts.conf", line 5: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/fonts.conf", line 6: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/fonts.conf", line 6: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/fonts.conf", line 6: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/fonts.conf", line 7: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/fonts.conf", line 7: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/fonts.conf", line 9: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-hinting-slight.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/10-hinting-slight.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/10-hinting-slight.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/10-hinting-slight.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/10-hinting-slight.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/10-hinting-slight.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/10-hinting-slight.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/30-metric-aliases.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/30-metric-aliases.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/30-metric-aliases.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/30-metric-aliases.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/30-metric-aliases.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/30-metric-aliases.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/30-metric-aliases.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/40-nonlatin.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/40-nonlatin.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/40-nonlatin.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/40-nonlatin.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/40-nonlatin.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/40-nonlatin.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/40-nonlatin.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/45-generic.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/45-generic.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/45-generic.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/45-generic.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/45-generic.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/45-generic.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/45-generic.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/45-latin.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/45-latin.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/45-latin.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/45-latin.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/45-latin.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/45-latin.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/45-latin.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/49-sansserif.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/49-sansserif.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/49-sansserif.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/49-sansserif.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/49-sansserif.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/49-sansserif.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/49-sansserif.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/50-user.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/50-user.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/50-user.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/50-user.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/51-local.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/51-local.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/51-local.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/51-local.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/51-local.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/51-local.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/51-local.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/60-generic.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/60-generic.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/60-generic.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/60-generic.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/60-generic.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/60-generic.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/60-generic.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/60-latin.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/60-latin.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/60-latin.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/60-latin.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/60-latin.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/60-latin.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/60-latin.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/65-fonts-persian.conf", line 34: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/65-fonts-persian.conf", line 35: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/65-fonts-persian.conf", line 35: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/65-fonts-persian.conf", line 35: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/65-fonts-persian.conf", line 36: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/65-fonts-persian.conf", line 36: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/65-nonlatin.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/65-nonlatin.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/65-nonlatin.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/65-nonlatin.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/65-nonlatin.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/65-nonlatin.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/65-nonlatin.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/69-unifont.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/69-unifont.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/69-unifont.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/69-unifont.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/69-unifont.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/69-unifont.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 8: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/80-delicious.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/80-delicious.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/80-delicious.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/80-delicious.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/80-delicious.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/80-delicious.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/90-synthetic.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/90-synthetic.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/90-synthetic.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/90-synthetic.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/90-synthetic.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/90-synthetic.conf", line 6: invalid attribute 'version'
Fontconfig error: Cannot load config file from /etc/fonts/fonts.conf
(ESPHome-Flasher-1.3.0-Ubuntu-x64.exec:61068): Gtk-WARNING **: 13:22:29.368: /lib/x86_64-linux-gnu/libibus-1.0.so.5: undefined symbol: g_task_set_name
(ESPHome-Flasher-1.3.0-Ubuntu-x64.exec:61068): Gtk-WARNING **: 13:22:29.368: Loading IM context type 'ibus' failed
(ESPHome-Flasher-1.3.0-Ubuntu-x64.exec:61068): Gtk-WARNING **: 13:22:29.396: /lib/x86_64-linux-gnu/libibus-1.0.so.5: undefined symbol: g_task_set_name
(ESPHome-Flasher-1.3.0-Ubuntu-x64.exec:61068): Gtk-WARNING **: 13:22:29.396: Loading IM context type 'ibus' failed
(ESPHome-Flasher-1.3.0-Ubuntu-x64.exec:61068): Gtk-WARNING **: 13:22:29.397: /lib/x86_64-linux-gnu/libibus-1.0.so.5: undefined symbol: g_task_set_name
(ESPHome-Flasher-1.3.0-Ubuntu-x64.exec:61068): Gtk-WARNING **: 13:22:29.397: Loading IM context type 'ibus' failed
(ESPHome-Flasher-1.3.0-Ubuntu-x64.exec:61068): Gtk-WARNING **: 13:22:29.398: /lib/x86_64-linux-gnu/libibus-1.0.so.5: undefined symbol: g_task_set_name
(ESPHome-Flasher-1.3.0-Ubuntu-x64.exec:61068): Gtk-WARNING **: 13:22:29.398: Loading IM context type 'ibus' failed
Exception in thread Thread-1:
Traceback (most recent call last):
  File "threading.py", line 926, in _bootstrap_inner
  File "esphomeflasher/gui.py", line 163, in run
  File "esphomeflasher/__main__.py", line 92, in run_esphomeflasher
TypeError: expected str, bytes or os.PathLike object, not NoneType
