+sm3 Posted September 28, 2021 Share Posted September 28, 2021 So I'm a part-time Atari 8-bit user. In the Commodore world, if you have disk drives in the chain connected that are not turned on, you are supposed to unplug the serial connection. Is this the same with an Atari 8-bit as well? I usually use SIO2PC and have it running through my 1050 drive, which I admit, is not always turned on. Thanks. Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted September 28, 2021 Share Posted September 28, 2021 It should not be a problem. The SIO lines are typically wired through the devices. Think of your devices as just wire taps. Quote Link to comment Share on other sites More sharing options...
+sm3 Posted September 28, 2021 Author Share Posted September 28, 2021 15 minutes ago, kheller2 said: It should not be a problem. The SIO lines are typically wired through the devices. Think of your devices as just wire taps. Alright, thanks for the confirmation. I’ve been doing this with both the 1050 and 810 so thought I should ask. Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted September 28, 2021 Share Posted September 28, 2021 4 hours ago, sm3 said: Alright, thanks for the confirmation. I’ve been doing this with both the 1050 and 810 so thought I should ask. As long as your device ids are unique (or conflicting devices powered off). Quote Link to comment Share on other sites More sharing options...
Sugarland Posted September 28, 2021 Share Posted September 28, 2021 But if you do have an issue, try removing the unpowered drive from the chain. Recently had two unpowered Indus drives here in the chain and an SIO2PC-USB at the end of the chain. Worked at some point then got errors later on. Unsure why. Moved the SIO2PC directly to the back of the (100% stock) 130XE and issue was gone. Quote Link to comment Share on other sites More sharing options...
+Larry Posted September 29, 2021 Share Posted September 29, 2021 Interesting @Sugarland -- what model computer was this with and what was the USB device (Lotharetk, Atarimax, etc.)? There used to be a fairly common problem with some SIO2PC devices at the end of a chain. But AFAIK, this was only with the serial version and only with one IC -- the original 1489 (not Max 232 nor 14C89). I had this issue myself. Quote Link to comment Share on other sites More sharing options...
+sm3 Posted September 29, 2021 Author Share Posted September 29, 2021 Yeah, I'm using the SIO2PC USB version. I haven't had any issues doing what I'm doing, just wanted to check and see if it was OK. I usually only have one real powered off drive in the chain of my setup (1050 or 810) depending on if I'm using my 800XL or 800. Quote Link to comment Share on other sites More sharing options...
Sugarland Posted September 30, 2021 Share Posted September 30, 2021 18 hours ago, Larry said: Interesting @Sugarland -- what model computer was this with and what was the USB device (Lotharetk, Atarimax, etc.)? There used to be a fairly common problem with some SIO2PC devices at the end of a chain. But AFAIK, this was only with the serial version and only with one IC -- the original 1489 (not Max 232 nor 14C89). I had this issue myself. A fully stock 130XE. The SIO2PC-USB is one I got in about 2015 from Lotharek. It has one IC that has "FTDI 1533-C 4905901 FT232RQ" The FT might be ET but I think it's FT. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted September 30, 2021 Share Posted September 30, 2021 Not turned on, no, turned on and unused, yes, has a small footprint that older limited ram hardware / software may not like.. Quote Link to comment Share on other sites More sharing options...
