bf2k+
1050S Sdrive Max
I was just working with my SDrive Max (1050S) a little while ago when all of a sudden the screen went blank... turned white.  Any ideas?  SD Card looks OK.
1 hour ago, _The Doctor__ said:
Reflash it, make sure everything is seated properly?
I talked with the guy at VCC where I got it. He seems to think that the Arduino is toast (based on the pilot errors I made with the external power supply and the little switch on the front.) (Ouch)
Is it normally flashed thru the USB port on the device?  If so, where is the flasher and firmware/software available?
Yes I found it... thanks.
Plugging in the device does not load the drivers so I cannot select the COM port for the flash.  This makes me think that VCC is correct - the Arduino is toast.
Thanks for your help. I really appreciate it.
You used white out instead of delete to remove text???🤣
Isn't that the correct method? :)
