danwinslow #1 Posted November 5, 2021 Any advice on getting one of these hooked up to a modern monitor via s-video or some kind of converter? Quote Share this post Link to post Share on other sites
Beeblebrox #2 Posted November 5, 2021 Saw this old AA thread. Maybe of help Quote Share this post Link to post Share on other sites
danwinslow #3 Posted November 5, 2021 (edited) Yeah, I had too. Got the manual off of it, but was wondering if anyone had done any LCD hookups. I assume a composite converter of some sort might work. Edited November 5, 2021 by danwinslow Quote Share this post Link to post Share on other sites
Beeblebrox #4 Posted November 5, 2021 I guess you'd have to acertain the outputs from the card itself and then what lcd tv inputs you currently have/wish to hook up to. At this stage have you attempted to connect to it? You mentioned composite so I assume you are wanting to connect to your TVs composite in? If yes and no luck then it's likely you will end up needing an upscaler or converter between the two. Are you taking PAL or NTSC btw? Quote Share this post Link to post Share on other sites
danwinslow #5 Posted November 5, 2021 NTSC Looks like there's a composite out and a DIN. I need to read up. Back later. Quote Share this post Link to post Share on other sites
Beeblebrox #6 Posted November 5, 2021 (edited) Sure. So just to clarify have you attempted to connect anything up yet using either a din to composite cable or composite to composite cable? Edited November 5, 2021 by Beeblebrox Quote Share this post Link to post Share on other sites
Faicuai #7 Posted November 6, 2021 4 hours ago, danwinslow said: Any advice on getting one of these hooked up to a modern monitor via s-video or some kind of converter? Here... (Have to go now, but will fill in later...) 1 Quote Share this post Link to post Share on other sites
Faicuai #8 Posted November 6, 2021 On 11/5/2021 at 3:42 PM, danwinslow said: Any advice on getting one of these hooked up to a modern monitor via s-video or some kind of converter? Ok, just have some extra time to fill in: You will NOT need s-video for Bit3 (nor XEP-80, for this matter). You will need either a COMPONENT (Luma) OR COMPOSITE inputs (will work very well with the latter, as long as the analog-decode stage of your CRT or LCD-TV or video-processor composite-port correctly decode in absence of chroma-burst, thus opening up all of available bandwidth for LUMA-only decode. This is usually well supported by a large # of viewing devices). Please, note that 480i vertical resolution WILL NOT be enough to fully scan Bit3 Fullview's 24 lines, unfortunately. We need's Avery help here (already offered one if my Bit3s as a guinea pig, but he has many other competing priorities, nowadays). For the above reason, the Bit3 will also be a heart-braker for many CRTs, out-there. Guaranteed. You can look at my Bit3 / XEP80 showdown for actual Bit3 photo-captures directly from LCD screen. Results are SHARPER to the naked eye. Cheers! Quote Share this post Link to post Share on other sites
