Brian's Man Cave #1 Posted November 11, 2021 Hey, I have another scroll problem The game scrolls ok while going in one direction, but I find that when I turn to scroll the other way... things get cut off. Here is a video of what I mean, you will see the word Jail change to Jal and then ail. https://youtu.be/Dtu90gr6yuU Any ideas what could be going on here? Quote Share this post Link to post Share on other sites
Zendocon #2 Posted November 12, 2021 Without seeing the code, I can only tell you I ran into the same problem when I first started using scrolling. I most recently performed left-right scrolling in the I/O Tape Viewer screen in Little Man Computer, so I can show you my snippet of code if it would help. It has to do with when you shift everything from one card to the next. With a little trial-and-error, you should be able to get everything moved over correctly. Quote Share this post Link to post Share on other sites
Brian's Man Cave #3 Posted November 12, 2021 3 minutes ago, Zendocon said: Without seeing the code, I can only tell you I ran into the same problem when I first started using scrolling. I most recently performed left-right scrolling in the I/O Tape Viewer screen in Little Man Computer, so I can show you my snippet of code if it would help. It has to do with when you shift everything from one card to the next. With a little trial-and-error, you should be able to get everything moved over correctly. Here is the code I am using to draw the street: draw_street: procedure if dir = 2 then IF offset_x + SPEED >= 8 THEN offset_d = 1:offset_x = -1 + SPEED ELSE offset_x = offset_x + SPEED end if gosub bum gosub people_moving SCROLL offset_x, offset_y, offset_d offset_d = 0 IF offset_x = 1 THEN #muv = #muv - 1 item_pos = item_pos - 1 item_loc = item_loc + 1 if item_pos <= 1 then item_pos = 20 left_screen_at = 2 new_item = 0 end if if #muv <= 1 then #muv = 19 if street = 0 then SCREEN screen_0, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 1 then SCREEN screen_1, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 2 then SCREEN screen_2, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 3 then SCREEN screen_3, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH end if end if if dir = 1 then IF offset_t = 0 THEN offset_u = 2:offset_t = 8 - SPEED ELSE offset_t = offset_t - SPEED END IF gosub bum gosub people_moving SCROLL offset_t, offset_y, offset_u 'WAIT offset_u = 0 IF offset_t = 8 - SPEED THEN #muv = #muv + 1 item_pos = item_pos + 1 item_loc = item_loc - 1 if item_pos >= 22 then item_pos = 2 left_screen_at = 1 new_item = 0 end if if #muv >= 260 then #muv = 241 'increase x 20 if street = 0 then SCREEN screen_0, #muv+19, 19, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 1 then SCREEN screen_1, #muv+19, 19, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 2 then SCREEN screen_2, #muv+19, 19, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 3 then SCREEN screen_3, #muv+19, 19, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH end if end if end Quote Share this post Link to post Share on other sites
skywaffle #4 Posted November 16, 2021 I don't know if you had resolved this yet, but typically when I am doing scrolling in games, I have my SCROLL command run, a WAIT statement after this (at some point in the loop), and then update the SCREEN. When you use SCROLL to shift the screen, the shift does not occur immediately, but will after the WAIT. Quote Share this post Link to post Share on other sites
skywaffle #5 Posted November 16, 2021 Off topic, but you can further simplify your code and avoid all the redundant conditional statements for drawing the screen for the various streets by using a table containing offsets for the starting point of each area. This can be very beneficial if your game grows larger. For example, if your all four street map data (screen_0, screen_1, screen_2, and screen_3) are made up of 40x12 tiles, you could have something like this: stage_offset: DATA 0 ' Street 0 DATA (40*12) ' Street 1 DATA (40*12) + (40*12) ' Street 2 DATA (40*12) + (40*12) + (40*12) ' Street 3 If the sizes are different, just make the changes accordingly, just keeping in mind to carry over the offset from the previous line. Instead of having all the conditional statements, have a single SCREEN command like this: SCREEN street_maps, stage_offset(street) + #muv+19, 19, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH Quote Share this post Link to post Share on other sites
Brian's Man Cave #6 Posted November 16, 2021 (edited) 4 hours ago, skywaffle said: I don't know if you had resolved this yet, but typically when I am doing scrolling in games, I have my SCROLL command run, a WAIT statement after this (at some point in the loop), and then update the SCREEN. When you use SCROLL to shift the screen, the shift does not occur immediately, but will after the WAIT. @skywaffle Zendocon sent me his code and I noticed that he was using the wait statement. I put it in my code and it looks like it might be solving the problem... however the people walking by are now all jittery. I have a script that has people walking, so I think there is an offset issue now. Essentially I have a counter (slow_people) that increases + 1 until 40 to move the person. if slow_people = 40 then if pep_dir = 2 then pep_walk_x = pep_walk_x - 3 if pep_dir = 1 then pep_walk_x = pep_walk_x + 3 slow_people = 0 end if Edited November 17, 2021 by Brian's Man Cave 1 Quote Share this post Link to post Share on other sites
skywaffle #7 Posted November 17, 2021 I always update all sprites on screen after the SCROLL statement, and before the WAIT. Whenever you shift the backtab, you will also need to offset your people by 8 pixels. Quote Share this post Link to post Share on other sites
Brian's Man Cave #8 Posted November 17, 2021 8 hours ago, skywaffle said: I always update all sprites on screen after the SCROLL statement, and before the WAIT. Whenever you shift the backtab, you will also need to offset your people by 8 pixels. I believe that is my issue! I just need to rework my people script. 1 Quote Share this post Link to post Share on other sites
Brian's Man Cave #9 Posted November 18, 2021 On 11/17/2021 at 9:37 AM, skywaffle said: I always update all sprites on screen after the SCROLL statement, and before the WAIT. Whenever you shift the backtab, you will also need to offset your people by 8 pixels. @skywaffle so I update the sprites after the scroll and after the screen draws the next line of tiles? Quote Share this post Link to post Share on other sites
skywaffle #10 Posted November 18, 2021 In my projects, my flow is something like below: START: Update the scroll offset variable. Check if the offset > 7 and if so, set a variable for screen shifting (IF OFFSET_X > 7 THEN OFFSET_X = OFFSET_X - 8: SCREEN_SHIFT = 1) SCROLL OFFSET_X, 0, SCREEN_SHIFT Update SPRITE positions WAIT Check sprite collisions IF SCREEN_SHIFT <> 0 THEN SCREEN_SHIFT = 0: SCREEN etc GOTO START Quote Share this post Link to post Share on other sites
Brian's Man Cave #11 Posted November 18, 2021 (edited) @skywaffleHmm, I must be missing something. When you say update the sprite positions does that mean to draw them to the screen? I put in the gosub bum and gosub people to re draw the sprites... but they are still gittery. if dir = 2 then IF offset_x + SPEED >= 8 THEN offset_d = 1:offset_x = -1 + SPEED ELSE offset_x = offset_x + SPEED end if SCROLL offset_x, offset_y, offset_d gosub bum gosub people wait offset_d = 0 IF offset_x = 1 THEN #muv = #muv - 1 item_pos = item_pos - 1 item_loc = item_loc + 1 if item_pos <= 1 then item_pos = 20 left_screen_at = 2 new_item = 0 end if if #muv <= 1 then #muv = 19 if street = 0 then SCREEN screen_0, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 1 then SCREEN screen_1, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 2 then SCREEN screen_2, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 3 then SCREEN screen_3, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH end if Edited November 19, 2021 by Brian's Man Cave Quote Share this post Link to post Share on other sites
skywaffle #12 Posted November 19, 2021 I update the variables for any sprite positions and then redraw all sprites at that point. Is the jitter occurring each frame, or only on the frame the backtab is shifted? Quote Share this post Link to post Share on other sites
Brian's Man Cave #13 Posted November 19, 2021 46 minutes ago, skywaffle said: I update the variables for any sprite positions and then redraw all sprites at that point. Is the jitter occurring each frame, or only on the frame the backtab is shifted? Its happening continuous as the screen is scrolling. I am assuming there is an offset that needs to happen? Quote Share this post Link to post Share on other sites
nanochess #14 Posted November 19, 2021 6 hours ago, Brian's Man Cave said: Its happening continuous as the screen is scrolling. I am assuming there is an offset that needs to happen? You need to subtract offset_x and offset_y from the sprite X and Y coordinates when using the SPRITE statement. Quote Share this post Link to post Share on other sites
Brian's Man Cave #15 Posted November 20, 2021 5 hours ago, nanochess said: You need to subtract offset_x and offset_y from the sprite X and Y coordinates when using the SPRITE statement. @nanochess the problem I am having is that while the screen scrolls I have people continuously walking from either the right side or the left side… when they are walking in the same direction as the scroll, they fall behind off the screen. Quote Share this post Link to post Share on other sites
nanochess #16 Posted November 20, 2021 9 hours ago, Brian's Man Cave said: @nanochess the problem I am having is that while the screen scrolls I have people continuously walking from either the right side or the left side… when they are walking in the same direction as the scroll, they fall behind off the screen. I see. You should make sure these walk at the same speed as scroll. And when scrolling you should subtract the scroll displacement from the base X coordinate of the people (not the same as offset_x) This means that if a person is walking to right, and you scroll to right, he/she would keep static at the same X coordinate because both movements nullify visually. Quote Share this post Link to post Share on other sites
Brian's Man Cave #17 Posted November 20, 2021 2 hours ago, nanochess said: I see. You should make sure these walk at the same speed as scroll. And when scrolling you should subtract the scroll displacement from the base X coordinate of the people (not the same as offset_x) This means that if a person is walking to right, and you scroll to right, he/she would keep static at the same X coordinate because both movements nullify visually. So what is the scroll displacement if it’s not offset_x? Quote Share this post Link to post Share on other sites
nanochess #18 Posted November 20, 2021 3 hours ago, Brian's Man Cave said: So what is the scroll displacement if it’s not offset_x? In pseudo-code: Scrolling to right. IF need-to-scroll THEN Enemy_x = enemy_x - 1 ' IF enemy is static it would disappear at left ' we suppose player moves with scrolling, so we don't change its position Offset_x = offset_x + 1 If offset_x = 8 then offset_x = 0: offset_d = 2 END IF SCROLL offset_x,offset_y,offset_d SPRITE 0,$0308+player_x-offset_x,$0108+player_y-offset_y,$0806 SPRITE 1,$0308+enemy_x-offset_x,$0108+enemy_y-offset_y,$0806+1*8 WAIT Offset_d = 0 Quote Share this post Link to post Share on other sites
Brian's Man Cave #19 Posted November 20, 2021 (edited) 1 hour ago, nanochess said: In pseudo-code: Scrolling to right. IF need-to-scroll THEN Enemy_x = enemy_x - 1 ' IF enemy is static it would disappear at left ' we suppose player moves with scrolling, so we don't change its position Offset_x = offset_x + 1 If offset_x = 8 then offset_x = 0: offset_d = 2 END IF SCROLL offset_x,offset_y,offset_d SPRITE 0,$0308+player_x-offset_x,$0108+player_y-offset_y,$0806 SPRITE 1,$0308+enemy_x-offset_x,$0108+enemy_y-offset_y,$0806+1*8 WAIT Offset_d = 0 Its almost working, do I need to adjust the enemy_x = enemy_x - 1 if there is speed involved? Also my characters move by +3 increments. also the people can either come from the right side or the left side regardless of what direction your character is going. draw_street: procedure if dir = 2 then offset_x = offset_x + speed IF offset_x >= 8 THEN offset_x = offset_x - 8 scrollflag = 1 'if pep_dir = 1 then pep_walk_x = pep_walk_x + 8 pep_walk_x = pep_walk_x - 1 end if SCROLL offset_x, offset_y, scrollflag gosub bum gosub people wait IF scrollflag THEN #muv = #muv - 1 item_pos = item_pos - 1 item_loc = item_loc + 1 if item_pos <= 1 then item_pos = 20 left_screen_at = 2 new_item = 0 end if if #muv <= 1 then #muv = 19 if street = 0 then SCREEN screen_0, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 1 then SCREEN screen_1, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 2 then SCREEN screen_2, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 3 then SCREEN screen_3, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH scrollflag = 0 end if end if if dir = 1 then offset_x = offset_x - speed IF offset_x >= 8 THEN offset_x = offset_x + 8 scrollflag = 2 'pep_walk_x = pep_walk_x - 8 pep_walk_x = pep_walk_x + 1 end if SCROLL offset_x, offset_y, scrollflag gosub bum gosub people wait IF scrollflag THEN #muv = #muv + 1 item_pos = item_pos + 1 item_loc = item_loc - 1 if item_pos >= 22 then item_pos = 2 left_screen_at = 1 new_item = 0 end if if #muv >= 260 then #muv = 241 'increase x 20 if street = 0 then SCREEN screen_0, #muv+19, 19, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 1 then SCREEN screen_1, #muv+19, 19, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 2 then SCREEN screen_2, #muv+19, 19, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 3 then SCREEN screen_3, #muv+19, 19, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH scrollflag = 0 end if end if end Edited November 20, 2021 by Brian's Man Cave Quote Share this post Link to post Share on other sites
nanochess #20 Posted November 21, 2021 4 hours ago, Brian's Man Cave said: Its almost working, do I need to adjust the enemy_x = enemy_x - 1 if there is speed involved? Also my characters move by +3 increments. Yes, it should be by "speed" increments. I've corrected the two locations where pep_x is added/subtracted to be near offset_x. Remember the displacement is in pixels, not per card. 4 hours ago, Brian's Man Cave said: draw_street: procedure if dir = 2 then offset_x = offset_x + speed Pep_walk_x = pep_walk_x - speed IF offset_x >= 8 THEN offset_x = offset_x - 8 scrollflag = 1 'if pep_dir = 1 then pep_walk_x = pep_walk_x + 8 end if SCROLL offset_x, offset_y, scrollflag gosub bum gosub people wait IF scrollflag THEN #muv = #muv - 1 item_pos = item_pos - 1 item_loc = item_loc + 1 if item_pos <= 1 then item_pos = 20 left_screen_at = 2 new_item = 0 end if if #muv <= 1 then #muv = 19 if street = 0 then SCREEN screen_0, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 1 then SCREEN screen_1, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 2 then SCREEN screen_2, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH if street = 3 then SCREEN screen_3, #muv, 0, 1, BACKGROUND_ROWS, #LANDSCAPE_WIDTH scrollflag = 0 end if end if if dir = 1 then offset_x = offset_x - speed Pep_walk_x = pep_walk_x + speed IF offset_x >= 8 THEN offset_x = offset_x + 8 scrollflag = 2 'pep_walk_x = pep_walk_x - 8 end if SCROLL offset_x, offset_y, scrollflag Quote Share this post Link to post Share on other sites
