JB #1 Posted August 26, 2003 GAH! My INTV's RF adapter was acting up. Evidence indicated it was likely a loose connection. Easy to fix, right? ... Guess who didn't do their research. I knew the INTV had solder holding it's RF shield shut. But I wasn't prepared for the huge globs I saw. A few hours later, the system's open. A visual inspection finds a joint that MIGHT be bad under the RF modulator. Fix that, hook it up, symptoms unchanged. Pry the modulator open, only to find oout I can't get at the underside of the internals. Which means I can't fix the %#@^&. All that work, wasted. Rather than go to the extra effort to remove the modulator from teh board so I can get at the underside, I'm just scheduling it for an AV mod. I'll likely be doing some parts shopping this weekend. At least if I screw up, I know it was essentially a dead system anyways. Minor amusement: There's some 2 feet of wire connecting the AC adapter to the power switch because Mattel didn't think power switches belonged on the left half of the machine. Quote Share this post Link to post Share on other sites
Brad2600 #2 Posted August 26, 2003 Try a hammer? Just kidding. I'm not too fond of the INTV design..mostly my biggest gripe is the controllers. Quote Share this post Link to post Share on other sites
video game addict #3 Posted August 26, 2003 I've got a working one you can have. It's got one trashed controller, otherwise its in decent shape. It's an original INTV 1 Just whatever the shipping costs are and its yours. Quote Share this post Link to post Share on other sites
Ze_ro #4 Posted August 26, 2003 A while back when I was less knowledgable, I had a "broken" ColecoVision. It displayed garbage on the screen, and I assumed that the RF modulator inside the unit was to blame. So, I opened the bugger up and took a look. As with your INTV, the RF modulator was soldered quite securely into place... I eventually got enough solder off, and pried apart the metal to the point where I could inspect the actual circuitry. I couldn't find anything wrong. So, I packed everything back up as well as I could, tried it out again (Of course, it wasn't fixed... but I was happy to see that things weren't any MORE broken than before). At that point, I stuck it in the basement for a year or so. Eventually I read something on the internet about older video game systems (In particular, the Atari 2600) not working properly with automatic RF switches like those used for NES's... I then realized that I had been hooking my ColecoVision up using the automatic switch that came with my Jaguar. I slapped my forehead and picked up a manual RF switch and hooked things up... and it worked! My ColecoVision was finally working properly and displaying a picture... however, when it got to the blue skill select screen, it immediately went into the game without me pressing anything, and my character immediately started moving to the right. I disconnected the controller, but the character still moved on it's own. In my efforts to try to fix something that wasn't actually broken, I had likely caused the damage that broke the joystick circuitry in the system. That's a lesson I won't soon forget. Incidentally, I was experimenting with this "broken" CV, and I found that using Genesis joysticks allowed me to actually play the game without characters automatically moving. Of course, things were a little tricky without the number pad (for some reason, mashing the D-pad and buttons on the Genesis controller actually ended up causing numerous number pad presses, but you could never rely on this). A few weeks of using the CV like this, and the video circuitry died out completely. Sigh... --Zero Quote Share this post Link to post Share on other sites
JB #5 Posted August 26, 2003 I've got a working one you can have. It's got one trashed controller, otherwise its in decent shape. It's an original INTV 1 Just whatever the shipping costs are and its yours. Nah. I wanna make this one work. Thanks for the offer, though. Quote Share this post Link to post Share on other sites
King Atari #6 Posted August 27, 2003 I hear that INTV 1's, or at least early models, have a tendency to overheat, so be careful of that, too. Quote Share this post Link to post Share on other sites
JB #7 Posted August 27, 2003 I hear that INTV 1's, or at least early models, have a tendency to overheat, so be careful of that, too.Yah. 3 chips have simple heatsinks. Kida scary for a machine of the era to NEED those. And I'm sure being stuffed in a steel box next to the AC adapter didn't help matters. ... I've also heard that the CPU they used was really prone to failure to begin with. Quote Share this post Link to post Share on other sites
