suberbanator
P Box Faceplate
I have to repair a faceplate broken in a move
what the question is does anyone know what type of plastic they were constucted of
i know i can use epoxy but if posible the proper cement i think would be better
thanks for any input
  • Sad 1
pretty sure this isnt plastic
oZMr_5aiuKntpv1-mmtbQi-Ni1SdGKKTeuJmWYQadGSotNB6uNEdDAMr80reaC1-0Og5H-PN9YxZcxDL7qUu9eoEWEthnKs44_T_ZuRYsvu7av_Tby2lAjfQpaoqqiHpPc6zLsyccl1431I6d_pQj4oJdshWtZrPQ3Ab_8Q_Iia9SRM6-mAgw6xXidR0ZjL05dzb8wyOBKfayvlVDt8N05BpR6PjOCxFJgEsMxhdKGUSSApT7ZcjIK4f68flx-GakGcyuSHklxx4jBP9gMNqSGMpOuCDTwkz1Mu-FYVf-UqHw1sYJZX88eL7U3xKcSCFr5r51DZScUn3OjaVvPEHdtsMeycBSX5-Ry-vLnZpDxI69WhfA7P36EaKOcnght-9CpC_o-76Vkbs1o4r80WOdI7aGbk4hOqgRDXlwAKeVU98B3fCIkgd2WGkD71L2D0Dso9Emq5qCVvqOLsy_WVmoRD_WFpQC2DSfyo6pBml70id5BuAj45-8P9tiamvlxOVU8sOmRUIFPOOEtBakiJOt4VorQM7ps6i8Tm533ogZdUGLbP-vRT1rXukVp_tkqBPxWCPxbR2ZSt2pQxQmRhHZ1vnMlxmNKUsxPrPnbj1WttldKyUlH1yRu-vDyRHq_d9i-P-x0DooUPDCxtXqnIbaf7YiFjemlP_VWA4gksDLT_ASQYNWtov6nRaNcSmygPbQzTUYxCHB5cfT5QmhTq_kQ=w785-h1046-no?authuser=0
Also a curse on the UPS store that thought a pbox in the bottom of a cardboard box with one layer of bubblewrap was acceptable.
  • Sad 2
Posted (edited)
Looks like high density polyurethane foam.
If so, the best "glue" would be 2 part polyurethane resin. Mix in a dixie cup, paint on both sides of the damaged foam, put together and clamp in place. Clean edges with a razor blade while still noncured to minimize surface blemishes. Sand lightly with 1000 grit or finer paper once cured.
Edited by wierd_w
I've had good luck with JB Weld Plastic Bonder #50133.  Found it on Amazon and at Auto Zone.
A little sanding afterwards and some spray paint will make look brand new.
i saw the pic before it disappeared.  dang- RIP to that poor pbox shell.
10 hours ago, wierd_w said:
Bondo is just fiberglass resin mixed with chalk and talc. :)
I used to mix Elmer's glue and chalk in elementary.
  • Haha 1
3 minutes ago, wierd_w said:
Not the kind of response I expect to a joke.
I really want to understand how that happens.  Some people are posting images which devolve into gobbledy-gook.  How are you guys inserting those images?
Nope, but I was being serious. Its mostly limestone and talc by weight, with just enough resin to make it sticky.
Some sodium silicate to discourage caking in the mixing hopper when they mix it.
I was not.
Well... how does it taste???🍽️
Does it go well with Play-Doh?:P
I don't have either on-hand.🖐️
Just lotion...🧴:grin:
  • Haha 1
i pasted in from google, wonder if it's them allowing it for a short time then blocking it
I looked at the photo details and they are a google link (I still see it)  I need to prob attach them here.. here's the photo again attached
