Frozone212 #1 Posted January 30 This is my first fan game and i'm still exploring BASIC so go easy on me It's meant to be a joke game, there is no winning. The epitaph quote is taken from the AVGN games video at 3:12 AVGN for commodore PET.d64 Quote Share this post Link to post Share on other sites
Frozone212 #2 Posted January 31 no one? tough crowd Quote Share this post Link to post Share on other sites
carlsson #3 Posted January 31 Ok, do you want your listing to be picked apart with hints of what is happening? The FOR loops on lines 2-3 obviously never loop because you have no NEXT statement. LET T=0:IF T=0 means it will always execute. Also LET is optional on the PET. M1=X+RND(X/10) probably doesn't work the way you expect. RND takes one argument that is negative to initiate a new seed, 0 or 1 for a random number in the sequence. Possibly what you want is M1=X+RND(1)*X/10 if you want a random number between 0 and X/10. Lines 8-9 obviously will set T=1 regardless, at least unless you GOTO directly to line 9 later on. The GET A$ statement on lines 14-15 follow the same structure as you have tried before. GET reads the keyboard for an instant keypress. If it doesn't get a key, it continues with the empty string. Either you mean INPUT A$ on those lines, or you need a line: 14 GET A$:IF A$="" THEN 14 to wait for a keypress. That said, the IF statements on lines 14-15 will only work if you hammer on the N or E keys at the right moment. The INPUT A$ statement on line 16 has no effect. Same about the INPUT A$ on line 19. As an interesting side effect, I noticed that if I leave the INPUT blank, the program exists. I don't know why it does as I never have observed that behavior before. Perhaps it is PET specific? LET E=INT(1) on line 18 makes little sense since 1 would be an integer anyway. On line 21, you're getting a TYPE MISMATCH because you've closed the string and then follows a line of asterisks. Not sure if made a mistake loading the program? Line 28 has two IF statements following eachother. The variable A$ can't have both values at the same time, but since you GOTO the line directly following, it will work the same. Your interactive fiction is mildly amusing, but it sure isn't much of a game. 😕 Quote Share this post Link to post Share on other sites
Frozone212 #4 Posted February 1 I don't know how to use PET basic to make a functioning game. All i can do at the moment is text adventures. That's disheartening Quote Share this post Link to post Share on other sites
motrucker #5 Posted March 8 On 2/1/2022 at 5:15 PM, Frozone212 said: I don't know how to use PET basic to make a functioning game. All i can do at the moment is text adventures. That's disheartening Here are a bunch of books on the subject. Take note - this is a great source! https://commodore.bombjack.org/kim-pet/books-kim-pet.htm Quote Share this post Link to post Share on other sites
