MaDDuck #1 Posted March 9 (edited) I am tight on space and as such, I cannot have all of my collection setup all of the time. Two weeks ago, I unhooked and boxed up my WIIU, and dug out the TI for the first time in about two years! I don't have the same VGA monitor that I used to use on it anymore, so I had to pick up some new hardware to go from VGA to HDMI with sound. I hope that it all works when I hook it up fully by next week! Will this introduce any latency, or not? Hopefully it is a smooth easy setup! I will be using this device to do the conversion: https://www.ebay.com/itm/373594805649 And this to capture the audio line from a standard composite audio jack. https://www.ebay.com/itm/111539908069 Everything should arrive by next week. Edited March 9 by MaDDuck 5 Quote Share this post Link to post Share on other sites
+XLERB #2 Posted March 11 On 3/9/2022 at 10:12 AM, MaDDuck said: … I don't have the same VGA monitor that I used to use on it anymore, so I had to pick up some new hardware to go from VGA to HDMI with sound. I hope that it all works when I hook it up fully by next week! Will this introduce any latency, or not? Hopefully it is a smooth easy setup! Having similar space limitations, I bought a little composite-to-VGA adapter since my spare flat screen monitor is a few years old and only has a VGA input. They sell a similar gadget for composite-to-HDMI. When I turn on the computer, the adapter takes a second or two to sense the signal and adjust the display format, but there doesn’t seem to be any latency after that. So I can leave my huge old CRT monitor in the basement. If I really miss the blur and scan lines, Classic99 has thoughtfully replicated them. Quote Share this post Link to post Share on other sites
MaDDuck #3 Posted March 12 I have an F18A inside my 99, so I already have an extra sharp VGA signal. My current monitor (TV!) has only HDMI no VGA at alll. So I need to convert the VGA and sound to HDMI. Quote Share this post Link to post Share on other sites
MaDDuck #4 Posted March 14 The adapters showed up in the mail today!! Everything is hooked up and works perfectly, I love my F18A. The picture isn't stretched out, it is centered in the middle of the screen. I could not be happier! The only thing that would make it better is getting one of those multi-carts that arcade shopper sells... 2 Quote Share this post Link to post Share on other sites
+OLD CS1 #5 Posted March 15 On 3/14/2022 at 12:27 PM, MaDDuck said: getting one of those multi-carts that arcade shopper sells... I know where you can get those... Quote Share this post Link to post Share on other sites
