masteries
Low Cost Fujinet v1.6 for Coleco Adam - Atari 8 bits - (and I hope C64)
Greetings,
Some days ago I tested the Low Cost Fujinet v1.6 multiplatform version I manufactured
in a real Coleco Adam.
These images illustrates the Low Cost Fujinet v1.6 running in a Coleco Adam,
using a DB15 to RJ12
Also, the DB15 to SIO cable is illustrated, due to this Fujinet edition contains
both Coleco Adam and Atari 8 bits interface components at same time.
Here the first photographs:
I need to test some games, loading from the web and from the SD card.
These Low Cost Fujinet v1.6 units are available at marketplace:
  • Thanks 2
Posted (edited)
Update,
A video of the Low Cost Fujinet v1.6 in Coleco Adam mode, tested in a real Coleco computer:
Edited by masteries
41 minutes ago, masteries said:
Update,
Hi
Can the firmware be updated?
Thanks
1 minute ago, rietveld said:
Hi
Thanks
Yes, using the Fujinet flasher, via the USB port
useful to update it, and change platform to Atari 8 bits...
I can’t believe more people aren’t jumping on this. This is a transformative network and Internet solution that brings the Adam toward modern computing abilities. I ordered one. :)
I agree. In my case, I am weighing waiting to see what else develops as far as a couple other people who have stated that they are considering making a FujiNet ADAM device... both external in a case and internal using one of the Data Drive bays. I don't own or plan to own another supported 8-bit computer besides the ADAM, so the added benefit of Masteries' unit also working with other computers isn't enough for me to make a purchase... although the price point makes it very tempting.
I can only assume that people who already own one of the MicroFox VDD or numerous ADE SD Drive solutions and one of the MIB238 Interface solutions (with or without the WiFi Modem built on) may be content with that setup seeing as the SD Drive and WiFi Modem are the main items that the FujiNet ADAM provides.
It's a roll of the dice and hopefully I don't come up with craps by not jumping on one of the units that Masteries is selling especially since I am very impressed with all the software that Thomas Cherryhomes has developed for the ADAM version and want to see it running firsthand. I just want to see how things develop especially concerning the possible Internal FidoNet for ADAM.
I completely agree with you.
The fujinet is a game changer.  It replaces both the ADE and MIB board .  In addition to the local file storage it also offers remote cloud access via remote server
You can Telnet in 80 col without any additional hardware
I use my fujinet to check the weather and read the news daily.
I also play games against other online users across the Internet
There are two HUGE advantages of using the Fujnet over the MIB238
If I want to Telnet in 80 column with my MIB setup I will need to use an external display and i can only use a Baud of 4800 (9600 with modification to the MIB) before the Adam starts to drop characters
The fujinet uses the Netcat Terminal program to display a very readable. 80 columns on a stock TV or monitor, meaning that you don't need a separate display dedicated as a terminal display
You can also Telenet at speeds that are only limited by the host server and not hampered by the Adams speed.  Data is sent in packets and captured by the Fujinet and then sent to the Adam. This means you can go online at speeds much greater than the 9600 that would be pushing the limits of the Adam when just using a MIB board
A fix was worked out for the MIB238 to allow it to use speeds up to 19,200, but you also have to use TeleTerm v4 or the latest v7 by Eric Pearson. There was a design limitation with the original Micro Innovations’ MIB design that caused the issue and IIRC there is also a programming issue with AL V that prevents it working at higher baud rates properly. Tekman can provide the details better than I.
i connect the MIB238’s Terminal Port to a Laptop next to my ADAM and at times connect the Laptop to my 28” LCD via HDMI that the ADAM is also connected too. So, splitting hairs, 1 display but have to change the input from Composite to HDMI. 🤪
As I said, some may be content with the ADE / MIB238 combo no matter what the extra benefits of the FujiNet are. I’ll definitely be purchasing a FujiNet ADAM, as I’m sure many will, just waiting to see what all shakes out with other build options… especially an internal Data Drive Bay version. If no other options pan out, then hopefully Masteries still has his version for sale.
Unfortunately, my results with 80-column Fujinet with Netcat on my monitor wasn't as good as yours and can’t hardly read anything on the screen and is unusable for me. I think it was originally meant to be more of a proof of concept idea. Even the 64-column is hard for me to read and I have to use Netcat at 40 column to look good on my monitor. I still use the MIB238 terminal connection for crystal clear 80-column support. Also, all versions of MIB cards can use a terminal connection of 19.2k baud and never required the /INT modification that the serial modem port needed to get 19.2k baud with buffering.
New batch of Low Cost Fujinet v1.6 with Atari 8 bits and Coleco Adam hardware are under manufacturing,
Its a continous manufacturing
Netcat-80 is illegible on my 22" LCD as well. IIRC, rietveld is upscaling the composite output to ? VGA ? and probably that is why he is getting better video quality at 80 columns.
Netcat-64 is very legible on my display.
