arcadeshopper #26 Posted April 13 I guess assembler no other option possible I think ... XB256 have smooth scrolling capabilities bat not for a wide background (I guess only background in loop) . Maybe after compile the result woud be fast enought ... but it's just a guess... I saw your lines demo and it's seems that line tracing could be feasible with an acceptable velocity. I know that raster is completely different from vector graph technology but battlezone was released for different 8-bit platform and I wonder that it would be be possible for TI99... My dream is to implement the game in assembler but but my knowledge is far from to be enough ... the initial idea came from your smooth scrolling examples/demos but another thing is to implement the game in assembler (... maybe in XB basic .. xb256 or TML which manage bitmap "natively"). I found this interesting link https://6502disassembly.com/va-battlezone/ (for me the listing is like hieroglyphs but maybe for you is simply ) ... battlezone was developed on 6502 processor ... so why not for TMS9900 ? 6502 CPU (@1.5MHz). Handles the game logic and system diagnostics.2901 ALUs. The 2901 is a 4-bit ALU that can be cascaded, allowing four of them to be combined to make a 16-bit math co-processor. The ALU can perform basic arithmetic and bitwise operations (add, subtract, exclusive-or, etc.). Battlezone includes a board with the 2901s, some ROM, and an interface that allows the 6502 to send and receive bytes of data. This is known as the "math box".The 16 bit math box is why.. the 9900 has to do both.. with wait states and 8 bit multiplexer Also the xy display and the vector system is totally different to operate then the 9918 Sent from my Pixel 6 Pro using Tapatalk 1 1 Quote Share this post Link to post Share on other sites
+Vorticon #27 Posted April 13 3 hours ago, whoami999ster said: any very simple example in assembler would be very appreciated for the 4 method you suggest ... i.e tracing a rectangle or triangle This is the assembly listing of Vortex which is small enough and well commented to give you one example of rectangles and triangles bitmap drawing. Vortex.txt 6 1 Quote Share this post Link to post Share on other sites
whoami999ster #28 Posted April 13 5 hours ago, arcadeshopper said: 6502 CPU (@1.5MHz). Handles the game logic and system diagnostics. 2901 ALUs. The 2901 is a 4-bit ALU that can be cascaded, allowing four of them to be combined to make a 16-bit math co-processor. The ALU can perform basic arithmetic and bitwise operations (add, subtract, exclusive-or, etc.). Battlezone includes a board with the 2901s, some ROM, and an interface that allows the 6502 to send and receive bytes of data. This is known as the "math box". The 16 bit math box is why.. the 9900 has to do both.. with wait states and 8 bit multiplexer Also the xy display and the vector system is totally different to operate then the 9918 Sent from my Pixel 6 Pro using Tapatalk = mission impossible ! ... but still I wonder how 8-bit/raster VIC20 was able to implement battlezone... maybe was not the most famous version ... but still Quote Share this post Link to post Share on other sites
whoami999ster #29 Posted April 13 2 hours ago, Vorticon said: This is the assembly listing of Vortex which is small enough and well commented to give you one example of rectangles and triangles bitmap drawing. Vortex.txt 15.14 kB · 9 downloads thanks a lot !!!! 1 Quote Share this post Link to post Share on other sites
arcadeshopper #30 Posted April 13 = mission impossible ! ... but still I wonder how 8-bit/raster VIC20 was able to implement battlezone... maybe was not the most famous version ... but still It uses characters.. same way armor attack on the trs80 model 3 does. Less screen space too Sent from my Pixel 6 Pro using Tapatalk Quote Share this post Link to post Share on other sites
apersson850 #31 Posted April 13 (edited) Disregard, I missed an important thing. Edited April 13 by apersson850 Quote Share this post Link to post Share on other sites
whoami999ster #32 Posted April 14 (edited) could be a starting point BZ0.AVI Edited April 14 by whoami999ster 3 Quote Share this post Link to post Share on other sites
Tursi #33 Posted April 14 The fastest line draw I managed on the TI could do about 67 lines per second (drawing from the center out to the screen edges) in monochrome. Even if you were happy with 10 frames per second, that's only about 6 lines per frame, and both erasing and re-drawing count, so isn't going to manage Battlezone very well. Now, this does read VDP and write the byte back, as was mentioned earlier. You can get faster writes to CPU memory, but you still need to copy that data to VDP. (It looks like I did some experiments using a dirty buffer, but with minimal success.) Shorter lines will draw faster, of course, but even if you tripled performance, that still won't manage much of a game. So, you probably need to dismiss vectors, unless you want to try for the F18A specifically. The F18A GPU is much, much faster than the TI's 9900 and has direct, background access to video RAM and much faster ways to calculate pixels and clear the screen. (We really need to measure how much faster someday...) At any rate, it might be able to do a vector display for you. But, you can get a pretty good fake out of pre-defined characters. I actually think that Vic-20 Battlezone video looks pretty good for the system. But that's the direction I'd be looking if I were working on it. 1 Quote Share this post Link to post Share on other sites
TheMole #34 Posted April 14 Rasmus has done this test in the past, right? This is without F18A: This is with F18A: 1 Quote Share this post Link to post Share on other sites
whoami999ster #35 Posted April 14 2 hours ago, TheMole said: Rasmus has done this test in the past, right? This is without F18A: This is with F18A: very clear Quote Share this post Link to post Share on other sites
whoami999ster #36 Posted April 14 4 hours ago, Tursi said: The fastest line draw I managed on the TI could do about 67 lines per second (drawing from the center out to the screen edges) in monochrome. Even if you were happy with 10 frames per second, that's only about 6 lines per frame, and both erasing and re-drawing count, so isn't going to manage Battlezone very well. Now, this does read VDP and write the byte back, as was mentioned earlier. You can get faster writes to CPU memory, but you still need to copy that data to VDP. (It looks like I did some experiments using a dirty buffer, but with minimal success.) Shorter lines will draw faster, of course, but even if you tripled performance, that still won't manage much of a game. So, you probably need to dismiss vectors, unless you want to try for the F18A specifically. The F18A GPU is much, much faster than the TI's 9900 and has direct, background access to video RAM and much faster ways to calculate pixels and clear the screen. (We really need to measure how much faster someday...) At any rate, it might be able to do a vector display for you. But, you can get a pretty good fake out of pre-defined characters. I actually think that Vic-20 Battlezone video looks pretty good for the system. But that's the direction I'd be looking if I were working on it. I'm completely agree... I didn't expect to implement vector graphic on TI but as always the true is always in the middle ... thanks a lot to all of you for the precious suggestions and availability Quote Share this post Link to post Share on other sites
+Vorticon #37 Posted April 14 I tried doing 3D wire graphics in Fortran99 on the TI without pre-rendering. Let's just say that the result is forgettable... 3 1 Quote Share this post Link to post Share on other sites
whoami999ster #38 Posted April 14 (edited) 4 hours ago, Vorticon said: I tried doing 3D wire graphics in Fortran99 on the TI without pre-rendering. Let's just say that the result is forgettable... I would say ... unforgettableeeee .... .... no way to manage "online drawing" ... I already give up ... It's a pity because the background scrolling it's very nice and promising ... did you see my bz0.avi above ? Edited April 14 by whoami999ster 1 Quote Share this post Link to post Share on other sites
+Vorticon #39 Posted April 14 1 hour ago, whoami999ster said: Did you see my bz0.avi above ? I did and it looked awesome! Quote Share this post Link to post Share on other sites
Elia Spallanzani fdt #40 Posted April 16 Go with 64x192 + sprites https://atariage.com/forums/topic/251540-formula-18a-formula-99-formula-99-development/page/5/?tab=comments#comment-4926676 Quote Share this post Link to post Share on other sites
whoami999ster #41 Posted April 17 22 hours ago, Elia Spallanzani fdt said: Go with 64x192 + sprites https://atariage.com/forums/topic/251540-formula-18a-formula-99-formula-99-development/page/5/?tab=comments#comment-4926676 facile a dirsi ... Quote Share this post Link to post Share on other sites
+dhe #42 Posted April 17 Wonder if strange cart might be a good target? Quote Share this post Link to post Share on other sites
Asmusr #43 Posted April 17 4 hours ago, dhe said: Wonder if strange cart might be a good target? Yes I think the StrangeCart would be able to draw the vector graphics at 15-20 FPS. As mentioned before the F18A could also easily do it, at 60 FPS, with lines, with filled polygons, or even with texture mapping. Both options have co-processors performing way beyond what the TMS9900 could do, but I think the more acceptable option would be that the co-processor is inside a cartridge rather than inside the machine. With an F18A version people would say that "Bah, it's just 21st century hardware doing all the work", but with the StrangeCart people, including myself, would say "Whoa, this game runs on a bare console". 🙂🙂🙂 3 1 Quote Share this post Link to post Share on other sites
Elia Spallanzani fdt #44 Posted April 18 american saracen uh? 1 Quote Share this post Link to post Share on other sites
+Vorticon #45 Posted April 18 I thought that video was on the TI and my jaw hit the floor. I call click bait! 😄 1 Quote Share this post Link to post Share on other sites
Elia Spallanzani fdt #46 Posted April 18 The interesting bit: " I've found an algorithm to split up triangles into character based graphics very nicely (so every 8x8 region of a solid color is transferred as a character index rather than a bitmap)." 1 Quote Share this post Link to post Share on other sites
Elia Spallanzani fdt #47 Posted April 19 P.s. I think one could start with this to make a tank game. Quote Share this post Link to post Share on other sites
matthew180 #48 Posted April 28 I think Atari proved what was necessary BITD, i.e. an AM2901-based 16-bit ALU (mathbox) co-processor, coupled with a vector display (no need to calculate lines or clear/write to a frame buffer). Some might have called that "cheating" back in 1980 as well, since the 8-bit CPUs were not really doing all the processing either. Any MCU or FPGA used today to augment our retro-computers are easily more powerful than the entire original system, so there is simply nothing to discuss as far as that is concerned. Just use a modern computer and throw that old computer in the trash... Since the whole reason any of us are here is to enjoy and have fun with our retro computers, what anyone does with theirs, and what enhancements anyone uses, it totally up to the person using the system, writing the software, or playing the game. Some people like to push or use only original hardware, and if that if the goal for a BattleZone port then I think you will have a lot of disappointment. As I mentioned above, Atari showed what was necessary with real 1980 hardware, and the 99/4A does not have the graphic muscle to pull it off. Now, if you are willing to consider using some modern enhancements to provide the same capability that the BattleZone MathBox provided to the 6502 in the original game, then I think it is justifiable to use something like the F18A to implement the MathBox functionality and a pseudo-vector display, and still call it a *fair* port. Even with the F18A, you still have to write the code in 9900-assembly, and you can always burn cycles if you think it would be more fair to slow it down a bit. To me, it seems reasonable to think that a 9900 could have done just as well as the 6502 in the original, all else being equal. Something to keep in mind, pretty much all arcade-machine computers have custom graphics hardware support which give them their better color, scrolling, sprites, etc. capabilities. Any port to a single-CPU system of similar era hardware, is going to be inferior or require additional *faking it*. 4 Quote Share this post Link to post Share on other sites
+mizapf #49 Posted April 28 1 hour ago, matthew180 said: Something to keep in mind, pretty much all arcade-machine computers have custom graphics hardware support which give them their better color, scrolling, sprites, etc. capabilities. Any port to a single-CPU system of similar era hardware, is going to be inferior or require additional *faking it*. I remember how impressed I was when I first saw Sega Outrun back in 1988, running in a racing cabinet with force feedback wheel. I was on holiday in Salou, Spain; this was somewhere near the beach. Outrun is also emulated in MAME; it states: 2 x Motorola MC68000 10 MHz Zilog Z80 4 MHz Video: 320x224 60 Hz So they spent quite a lot of computing power for this modest resolution. 3 Quote Share this post Link to post Share on other sites
Asmusr #50 Posted April 29 (edited) For Battlezone, provided it's OK to require 32K and a large cartridge ROM, I think I would go for a solution like this: Use bitmap mode with 2/3 of the screen as playfield. Monochrome only, set all colors to black or a static gradient. Draw the background mountains a few screens wide and store in ROM. Draw the objects at all different orientations and scales and store in ROM. For simplicity and to save space, let's restrict horizontal movement to 8 pixel boundaries. During the game: Copy background at scroll position to a 4K linear screen buffer in 32K RAM Copy objects from ROM into buffer (using OR/SOCB) Copy buffer to VDP Execute copy routines from scratchpad using unrolled loops. Use sprites for explosions, crosshair, etc. I think 10 FPS would be possible, but I haven't done the math in detail. By linear screen buffer I mean a buffer where each scanline follows the next top to bottom. It's simpler to write to than a character based buffer, and it's possible to copy it to the VDP just as fast as a character based buffer, using a trick with 8 registers. To speed things up, only using 1/3 of the screen could be an option. Edited April 29 by Asmusr 6 Quote Share this post Link to post Share on other sites
