manterola
1050 Duplicator: Duplicated
Hi,
   I'm a bit behind with my firmware efforts, I think @manterolais now in the lead!
   The DW START pair at the end of the sources specifies the 6502 power up/ reset vector(s) at the very top of memory for the firmware, so I don't think it should be removed.
   I think the problem is that the object file produced by the Macro Assembler would have gotten loaded into the 8-bits memory, then written out to an EPROM directly - maybe this is an undocumented step? The LOC and ORG directives allow assembling code with a given base address, but stored at another address (if I recall correctly).
   I only found one file had extra characters at the end, but it was enough to cause problems. Maybe this is an issue with the archive.
Yep. I needed to move the last four bytes (Start address twice) to the end of the 8kb by inserting zeros right after the DTI version and copyright text stuff (stamp?). Then I compared the files and the only difference was an FF instead 00.
So, we have the sources working.
That's great news!
There's an option in ATASM that will build a pure binary (no headers), but I'm not sure this can be done with AMA. On the other hand, writing a simple program to consolidate all the segments into 1 block should be easy, but for a ROM I think you should only have 2 segments in the object file, e.g. block of code plus start address.
Has anyone thought of converting the source for being used in mads or ca65...
I only mention this since we have the OS sources compilable in CA65 and the 1050 SRC in mads.
Making changes and burning on the TL866 is much faster that way :)
Not for mads or ca65 but I did that for atasm a while ago.
I've attached my sources, see Makefile for atasm command line flags used to build (the sources can both build 3.10 and 3.00).
so long,
Hias
duplicator-3.00-3.10-atasm.zip
so long,
Hias
Fantastic! The sources assembled at the first try, without any problem.
Much appreciated!
HI,
   Can anyone with a Duplicator 1050 and also a US Doubler try/test the attached Duplicator 1050 firmware? Version upped to 3.20 to avoid confusion.
   The (fixed?) bug is described by @ijor in:
@manterola has kindly tested the 3.20 firmware, and it seems to work fine, but he doesn't have a US Doubler to test with for this bug fix. This should also work for MegaSpeedy owners (though I have no idea how to update the firmware for the Duplicator 1050 slot on a MegaSpeedy). Possibly any clones of the Duplicator 1050 too, but obviously a little less certain of that.
Sources are at: https://github.com/e474/Disk-Duplicator-1050-Firmware
duplicator-3.20.rom
