Sign in to follow this
Atari_Owl
CT60 it works!! But...
Howdy.
Anybody out therewith a CT60 can help me?
I built my cables, etc and its all working rather nicely.
Except....
1. All my icons are screwy/corrupted
2. I cannot get rid of the CT60TEMP.ACC it keeps re-appearing
3. My Nembench is very slow compared with the website.
Anybody have any ideas?
Cheers.
my CT060 work fine but I dont see where is your problem :(
do you use nvdi, a alt/os ( magic/mint ) ?
why do you whant to rid the tem acc ?
Well! If your icons seem corrupted, I would suggest that your TOS roms are faulty or loose, check them out! If they are fine, try running a TOS select program which loads TOS versions into ram.
Hi Thanks for th input.
I tracked down the icon problem to my SpeedoGDOS.prg
As soon as i removed that from the AutoFolder, everything was fine.
The temp thing is very confusing and whilst the acc is now running, i cannot get the ct60conf.cpx to work when i'm in ct60 mode. As soon as the temp window comes up the whole machine crashes or reboots.
I can access all the options from the F30 mode but its still annoying.
Also Kronos is crashing the machine on the VDI test.
I currently DON'T have NVDI.
My speed thing was sorted out by going back to BIN 0.98e.
