Sign in to follow this
RCmodeler
Can 2600 be built from scratch?
Well, yes, and no. The Atari 2600 used mostly off the shelf parts, but the main chips (TIA, CPU and RIOT) are not quite as easy to find. There are still places that have new, old stock 2600 chips, like Best Electronics, as well as some of the people here on AA. That 2600 could be built from scratch relatively easily, provided you have those three chips. The rest of the parts are common resistors, diodes, capacitors, etc... and can be obtained at any good electronics store.
I would imagine that with modern FPGA technology, it would be possible to recreate the three main chips, possibly even on a single FPGA. It is also no doubt possible to create an "Atari on a chip" with modern technology, that would require very little additional hardware to work. I think those little joysticks with 20 Atari games in them that they sell these days have something like that, but I don't think that it is a true "Atari on a chip", I think therre is some sort of microprocessor based emulation, or at least a different implementation of the system, since I heard that one person that has one noticed that Asteroids doesn't flicker. I have never taken one of those joystick consoles apart, however, so I'm not sure how they work.
I know that the Atari could be created with off the shelf parts back in the 80's, since Coleco made clones, as well as their Atari 2600 adapter for the Colecovision, and IIRC, didn't Atari lose some lawsuit over those things? I've never taken a Coleco 2600 cart adapter apart, so I don't know how they did it, but I do know that it's basically a complete Atari 2600 that just pipes the video through to the Colecovision. Same thing with the adapter for the 5200. Anyone know if the Coleco adapter used the same main chips as the real 2600, or did they use something different?
Ian Primus
[email protected]
The 6507 CPU and 6532 RIOT chips where off the shelf components, but the TIA was a custom Atari part. Coleco reverse engineering this chip and made thier own clone of it which is used in the Colecovision 2600 adaptor as well as Coleco's Gemini 2600 clone. Atari did sue Coleco over this but according to what I have read it was settled out of court and Coleco was allowed to continue the sale of these items.
Dan
If I remember right, there was a lawsuit in the early eighties that Atari lost. It was either with Activision, over licensing rights, or with Coleco/Intelivision over the 2600 plug in. I don't remember wich, but Atari wanted money for it, and basically lost on account of the system being made from off the shelf parts.
Weather those parts are still available, just depends on their usefull ness in other things, like little kids toys, maybe that talking GI Joe has a 6502 in it?
http://www.mindspring.com/~2600onachip/ < this guy is designing a atari 2600 on a chip. He is slow with updates (6 months between updates is no exception), but he has come to this point:
Current results:
So far, the TIA and PIA synthesizable cores have been completed and are 100% functional. The TIA design took me approximately 150 hours and the PIA about 10.
As for the 6502 core, I have completed the architecture (ALU, registers, datapath) and I'm working on the microcode, the most time consuming part of the design.
I would think that anything is possible given enough money thrown at it. Building a 2600 from scratch should be possible but it would probably be easier to just get parts out of non-working 2600 systems and then taking the parts that still work from them and putting it all together.
I think it's quite remarkable that Coleco made a TIA clone if they didn't have any schematics (unlike the guy who's doing the 2600-on-a-chip).
Most games that use TIA tricks work on the Gemini and the adapter, don't they?
What about the Intellivision System Changer?
Remeber that this was at the height of the video game industry so Coleco probably had the money to throw a couple of engineers at the job full time.
Dan
If you have those 3 main chips, you could build a working 2600 from ground up. But I'd get those one chip design and tuck it inside a pocket TV, add a cart port and control pads and not worry about wasting too much space.
Yeah, I'd like to do that also. There's even some 2600jrs built with just one chip,
but they're very rare. I haven't found one yet. One RCA lcd tv even has an internal ribbon cable
and one of the signals is composite video. It might just be possible to build a portable into a GBA case.
I doubt it'd be feasable to create a TIA clone out of standard off-the-shelf transistors. But that'd be cool if you could.
*remembers the DeLorean in Bck to the Future 3, with the computer strapped to the hood*
Errr... maybe not.
