A2600 #1 Posted December 24, 2003 Fisrt day using again the ST, since the day i put it away... Untill now that I get a Color monitor everything load up fine when I have set up on the floor when I take some crap off my desk and situated the machine nice on my desk with the monitor when I boot I get my little green desktop but now the same programs that booted while it was on the floor wont boot now!!!! All I get is "Drive: A is not responding Please check the disk drive, and insert a disk" PLEASE HELP Quote Share this post Link to post Share on other sites
A2600 #2 Posted December 24, 2003 Now I get: "Data on the disk in drive A: may be damaged. You must use the right kind of floppy disk; you must connect your hard disk properly" Quote Share this post Link to post Share on other sites
A2600 #3 Posted December 24, 2003 OHH BOY Now she is not reading of the Disk Drive or turning on the drive light and when she gets to the desktop doesnt even display the trash can just the mouse by itself!! I have a 1040STf just in case you wanted to know!! I think I have a Virus?!? Quote Share this post Link to post Share on other sites
atarian1 #4 Posted December 24, 2003 It sounds like something is wrong with the disk drive. Open it up an make sure the disk drive cable is securing in. It may have come loose during your computer move. Or, it could be your disk drive biting the dust. Connect any PC disk drive that can be configured to Drive 0 should do the trick. Make sure to twist the cable 180 degrees too. Quote Share this post Link to post Share on other sites
A2600 #5 Posted December 24, 2003 that can be configured to Drive 0 How do I know this and how can it be configured?? Quote Share this post Link to post Share on other sites
A2600 #6 Posted December 24, 2003 Fixed!! Everthing back to normal Quote Share this post Link to post Share on other sites
krupkaj #7 Posted December 24, 2003 that can be configured to Drive 0 How do I know this and how can it be configured?? Older floppies has jumper for drive select 0 or 1. Newer has only selder pads and you must solder a little. Quote Share this post Link to post Share on other sites
A2600 #8 Posted December 24, 2003 that can be configured to Drive 0 How do I know this and how can it be configured?? Older floppies has jumper for drive select 0 or 1. Newer has only selder pads and you must solder a little. Whats the ussual location?? Quote Share this post Link to post Share on other sites
herr professor #9 Posted December 25, 2003 I dont trust google to do the link right so I will repost this direct from the web. It was written by the author below, not me, so i've never had to do it. ***************************************** Alyre Chiasson a écrit : > > I need to short both the disk detect and the HD detect switches (I have > a 1040ST). My Mitsumi floppy drive has two black plastic pieces over > each of the holes if a disk was inserted. I was expecting to find two > leads after reading the modifications that one would have to make to a > sony floppy drive but find three leads in my case. Do I short them all, > or just a pair, if so which ones? I just had a look during the weekend, so for all interested, here are the changes you need to perform to a Mitsumi D359T6 floppy drive to use it on an Atari (ST/TT/Falcon). The Mitsumi drive was the only one I could find nowadays. It seems to be the cheapest and most widespread floppy drive used nowadays in most OEM, brandless and homebuilt PCs. To change the drive ID, this unit has no jumpers, however, on the connector PCB you'll find a small area with 3 rows of 4 tiny solderpads. You have to make 2 solder bridges, like this (viewed with the connector to the bottom and the front of the drive facing up) o o o o o o=o o o o o=o With this, the drive will be detected by the Atari, but you may experience problems with the Media change: when you swap disks, the Atari can ignore the swap, and writes to the new disk using FAT information of the old disk. This usually corrupts all the data on the disk, and makes it unrecoverable. The enable the media change detect, you can solder together 2 pins of the write protect/media change switch (top left of the drive, marked WP and MC). Bridge the MC and middle pins like this: |_____| W | | | M P | |=| C I haven't tested that part yet, but read a post from somebody claiming that this corrects the media change bug. I still use the fmc.prg in the AUTO folder as a precaution. If you want to do the HD mod, then you'll find that pin 2 of the mitsumi connector does not output +5V when a HD disk is inserted, as it should. A way around this, is to run a wire directly from the HD detect switch to pin 2 of the connector. The HD switch is the one opposite to the WP/MC switch, and has a pin marked HD. You should solder one end of the wire to this pin, and the other to the connector PCB, where the pin 2 is soldered to the board. I suspect that the HD detect and Media Change settings can probably be changed from the "4x3 solderpads" area, but I was unable to find a way to do so. Maybe someone else has some better information. Nick -- ||| Nicholas Bales, Toulouse, France ===|||================================================== / | The Atari ST Quick FAQ [email protected] -' ' `- http://quickfaq.atari.org directprovider.net -------------------------------------------------------------------------------- Mitsumi drives probaly havent changed signifigantly since this was written so you can give it a shot.... good luck! Quote Share this post Link to post Share on other sites
atarian1 #10 Posted December 25, 2003 that can be configured to Drive 0 How do I know this and how can it be configured?? Older floppies has jumper for drive select 0 or 1. Newer has only selder pads and you must solder a little. Whats the ussual location?? On TEACs, it's a solder pad on the bottom of the drive labeled DS0 and DS1. However, on the newer drives, I can't find them! Probably to save 2 cents. What a bunch of cheapskate drive manufacturers!!! Time to save up on old drives at the computer junkyard! Quote Share this post Link to post Share on other sites
