Sign in to follow this
Pocket
[HELP] Lynx programs
Hi !
I'm looking for 2 Lynx programs to generate sound on Lynx :
HSFX
WAV2LSF
Thank you for your help ! :)
Thanks TailChao.
And you, what program do you use to generate sound on your game ?
Zonik is soundless on the lynx hardware, but will make use of an upgrade I designed.
Hello, what is the best things to have sound and music for lynx coding ?
Go with HSFX and the other amiga dev utilities.
HI there,
I'm also trying to work on lynx stuff and sound is a p**n in the ***...
Well thx for your prompt answers Tailchao. As far as Harry's concerned I think (but I may be wrong) that Fagemul has sent him a mail but never got any reply...
After some time trying to figure out how to use .lsf files within the code we managed to get some sound (hurrah). But still, that will not do the trick for music. So how do you guys manage(d) to put all those stuff in your games? I mean I know there are some tools around but are there some tricks or other things to avoid???
Romu
Hi,
I have a small tool for finding instrument sounds and a music library for C-developement and BLL-developement.
If you send me your email I can send you the code.
You may browse this forum looking for abcmusic to find out more about it.
Karri
abccreator.o is run in Lynx
You move the cursor using the joypad and press A or B on buttons.
(B autorepeats).
Basically you create an ASCII description of what you want to play.
Like:
tune = "CDEFG";
channel = 0;
abcmusic(channel, tune);
You can also mix in instrument commands like
On = octave n=0..6
Xn = XOR taps n=0..511
In = integrate n=0..1
Vn = volume n=0..127
Tn = time n=0..255
Rn = ramp up (attack) n=0..127
Hn = hold n=0..255
Kn = kill sound (decay) n=0..127
To find good values for instruments use abccreator.o
You can then write your own tune like:
tune = "O1 X7 I0 V40 T22 R40 H2 K1 |:CCCE DDDG FFDD C4:"
The sounds you can use are:
CDEFGABcdefgab
~ - lower
= - higher
Length of a note can be extended by 2,3,4
|: = start of a chorus
: = repeat chorus
' ' = spaces are ignored. They are not required anywhere. I added them for readability.
The tune should end in character 0.
You can run tunes on multiple sound channels simultaneously by calling abcmusic several times:
silence();
abcmusic(0, tune0);
abcmusic(1, tune1);
abcmusic(2, tune2);
abcmusic(3, tune3);
If you don't know how to use the linker to add abcmusic.m65 to your compilation you can add
#asm
as the first line in abcmusic.m65 and
#endasm
as the last.
Then you just add
#include "abcmusic.m65"
to your C-program.
Karri
I just heard that Panther does not like my code :(
Well. In case you still want to try it out I compiled the tools required to work with it on a friends Windows XP machine.
You can pick them up for a few days from:
http://sipo.fi/winlynx.zip
These are just command-line tools (cc65, link65, lyxass, sprpck etc.). You need to add
C:lynxnewcc65bin
to your path. You need to unzip the archive to C:
And you may also need to change
RM=rm -f
to
RM=del
and
CP=cp
to
CP=copy
in the abcmini/makefile.
Compiling everything is done by
cd abcmini
make
(There is a WindowsXP compatible make utility in C:lynxnewcc65bin)
Karri
